Should I RMA my HDD again?
XmutanoX
19 (0.01/day)
Recently i had problems with one of my HDD being extremely slow and yellow warning on Crystal Disk, after that I switched my windows and boot drive to another HDD (ST2000DM008) which I only used for games and steam, but when i started using it for Windows i noticed A LOT of stuttering doing the almost everything, especially when installing something or sending files to it. I ran some tests on HD tune and got these results which I interpreted as a bad HDD and sent it to RMA.
After almost a month, I got a new HDD from RMA and been using for the last 2 weeks, but since it arrived i've been feeling the HDD has the same problems from the old one (even thought they sent the same HDD but the serial number is different) and a lot of stuttering/freezing programs happening, especially when installing a game or transfering files, also when i try to install ANY game from steam it keeps going to 0 mb/s and disk usage drops like hell (this never happened until this new HDD
So i got to test this new HDD and for my suprise the results seem pretty similar to the old HDD I sent to RMA and even some speeds look WORST than the old one, so can anyone actually help me looking at these results and actually telling me if the HDD has a problem or not before I open RMA again? Because if I need to use warranty again for something they already sent me I need to be absolute sure to fight for a decent HDD to be sent to me this time. These are the new results
FreedomEclipse
~Technological Technocrat~
24,387 (3.75/day)
Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
XmutanoX
19 (0.01/day)
This is the test using a new cable and another SATA port and still the same results, I will try next to change the sata power cable but i don't think the results will change. Also I like to remember that the steam problem is just one of the problems i'm having, I also get a LOT of stuttering/freezing when the HDD is doing some installations or transfering and also when gaming. Also it's pretty weird that by the end of the test the speed just goes UP and try to estabilize even with the sudden drops
633 (0.13/day)
System Name Smooth-Operator
Processor AMD Ryzen 7 3800x
Motherboard Asrock x570 Taichi
Cooling AMD Wraith Prism
Memory 2x16GB 3200MHz CL16@CL14 DDR4
Video Card(s) Sapphire Radeon RX 580 8GB NITRO+
Storage 2x4TB WD HGST 7K6 7200RPM 256MB
Display(s) Samsung S24E370DL 24" IPS Freesync 75Hz
Case Fractal Design Focus G Window Blue
Audio Device(s) Creative X-Fi Titanium PCIe x1
Power Supply Corsair HX850 80+ Platinum
Mouse Gigabyte Aorus M3
Keyboard Zalman ZM-K300M
Software Windows 10 x64 Enterprise/Ubuntu Budgie amd64
By specification hdd is a decent piece of hardware but... this is seagate, i do not trust them at all. Once i purchased new seagate drive and it failed three weeks later. RMA without hesitation. This drive shouldn't have symptoms which you describe it has.
520 (0.17/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
The best tool to use if it is a Seagate drive is Seatools. ^^
7,607 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
My five cents? The head overheats... It is not meant for such torture test.
phill
17,115 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
Is the drive being actively cooled, fan in front of it etc? Is the model of drive a Barracuda drive?
XmutanoX
19 (0.01/day)
The seagate tools doesn't have any read/write visual test, it just says PASS or FAIL which doesn't help at all in this condition, last time i used for the HDD i RMA'd and it passed everything besides the FIX ALL which made me ask for a new, despite all previous tests also presenting a problem with the last HDD, now the new one is showing the exact same results
1,865 (0.34/day)
London
System Name Jaspe
Processor Ryzen 1500X
Motherboard Asus ROG Strix X370-F Gaming
Cooling Stock
Memory 16Gb Corsair 3000mhz
Video Card(s) EVGA GTS 450
Storage Crucial M500
Display(s) Philips 1080 24'
Case NZXT
Power Supply Enermax 425W
What's the temps on the drive while testing? You didn't mention... or I missed it.
XmutanoX
19 (0.01/day)
The only fan directly at it is the front case fan, but the temperature is reasonable I think, right now is showing 38 C which is after the stress test, during the test it gets to 45 C AT MOST which is well under the 55 C limit for HDDs
You can see the temperatures on the tests, it's on the right of the model of the drive and next to a bunch of buttons
1,865 (0.34/day)
London
System Name Jaspe
Cooling Stock
Case NZXT
41-43c seem a bit high to me.
I have the 4TB version and is at 30c.
XmutanoX
19 (0.01/day)
Apparently I discovered from another forum that a lot of those HDDs of 2TB or higher from Seagate are SMR and they don't put this information ANYWHERE, and SMR HDDs tend to behave exactly like mine is doing now. I'm trying to find a way to actually check if mine is SMR or not and hope that seagate would try to solve my problem with this one or else i'm a lot of trouble since this is my only HDD and i need it for Windows and games right now :/
Even at 50 C it shouldn't be happening any problems, especially for a new HDD from RMA, apparently the problem can be this SMR thing which the problem now is finding a way to test if it really is that, maybe if it is I can demand an explanation and solution from Seagate
phill
17,115 (3.43/day)
Somerset, UK
If I'm honest it's still a little high, I aim to keep drives around the 25C to 30C mark even under use. My Synology server is about that most of the time but they are only 5400 RPM. I wouldn't hope that 7200 RPM drives are going to increase the temps that much if the air flow around the drives is good :)
XmutanoX
19 (0.01/day)
So i borrowed another HDD for testing, the model is ST1000DM003, installed windows and everything for running it normally, my first test was downloading from steam and guess what: no drop problems on download
so i ran the HD tune on both HDs both using their respective windows installation and these are the results:
So basically, using windows on the HDD being benchmarked causes a bunch of drops which everyone knows it, but the problem on the ST2000DM008 persists even when windows is on another HDD, the speed keeps going up and down for almost the WHOLE test, with a HUGE spike to the top in the middle and for no reason at the end it just goes up and "estabilizes", is this enough to open RMA again or should i just give up because this model is just bad?
1,246 (0.19/day)
Repentigny, QC, CANADA
System Name CTG Computer
Processor AMD Ryzen 5 7600
Motherboard Asrock B650M PRO RS WIFI
Cooling Thermalright PA120 SE
Memory 2x 16gb G.SKILL F5-6000J3038F16GX2-FX5
Video Card(s) Gigabyte RX6800XT Gaming OC
Storage WD Black SN850X 2TB
Display(s) MAG274QRF-QD | Asus vg248qe
Case SAMA IM01
Audio Device(s) Creative SoundBlasterx G6
Power Supply Corsair SF750
Mouse Logitech G pro Wireless
Keyboard Corsair Strafe RGB MK2
Software Windows 11 Pro x64
don't this 2TB model (DM008) use SMR? instead of PMR like the ST1000DM003 ?
PMR: Perpendicular Magnetic RecordingThis is the technology inside of most hard drives. With PMR data is written to and read from circular tracks on a spinning platter.
SMR: Shingled Magnetic RecordingThis type of drive overlaps recording tracks to store data at a lower cost than PMR technology. The downside occurs when data is deleted and that space is reused. If existing data overlaps the space you want to reuse, this can mean delays in writing the new data. These drives are great for archive storage (write once, read many) use cases, but if your files turn over with some regularity, stick with PMR drives.
That sounds simple, but here are two things you should know:
  1. SMR drives are often the least expensive drives available when you consider the cost per gigabyte. If you are price sensitive, you may believe you are getting a great deal, but you may be buying the wrong drive for your use case. For example, buying SMR drives for your NAS device running RAID 6 would be ugly because of all the rewrites that may be involved.
  2. It is sometimes really hard to figure out if the drive you want to buy is an SMR or PMR drive. For example, based on the cost per gigabyte, the 8TB Seagate external drive (model: STEB8000100) is one of the least expensive external drives out there right now (source: diskprices.com). But, the 8TB drive inside is an SMR drive, and that fact is not obvious to the buyer. To be fair, the manufacturers try to guide buyers to the right drive for their use case, but a lot of that guiding information is lost on reseller sites such as Amazon and Newegg, where the buyer is often blinded by price.
IMO, don't use an HDD for OS, just buy an SSD for the OS..
XmutanoX
19 (0.01/day)
the problem is having also a HDD for games, since idk if SMR HDDS are also bad for having games installed on them or i can just keep it as a games HDD while having a SSD for OS and have no problems at all, can someone
AsRock
TPU addict
19,162 (2.98/day)
UK\USA
Yeah but the UK isn't all that hot to begin with, in fact a HDD to cool can make problems too.
The program i like using, their is a trail version to( some options disable after amount of days, also tell your min\max temps and such too.
RMA it again.
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I don't think Seagate used SMR on any of their Barracuda drives, at least not the small 2TB ones. The SMR drives were used on their archive drives. Either way, SMR wouldn't give read issues, only write issues. And they start out fast, then get really slow after the PMR cache is used up. His results are the opposite.
1,246 (0.19/day)
Case SAMA IM01
I saw that a 256mb cache version is a good sign. Maybe i am wrong but if multiple same drive have the same behavior, than a 1tb older model, thats why i suspect. I have a customer who has a 3tb dm003 or 005, no issue at all with os on this drive
XmutanoX
19 (0.01/day)
So anyway, should i or should i not RMA this 2TB HDD? it clearly has a read problem even without an OS on it
633 (0.13/day)
RMA it asap. Drive is faulty so that's your only way to go with it. Well, ok, there is other way, buy new drive and send this one on RMA but i imagine you don't want to do this.
DrakeFrst
2 (0.00/day)
New York
It definitely seems like throttling to me but if you're saying that temps are ok - just RMA it, way easier than trying to figure out what's wrong with it. either corrupt,bad sectors, too used and needs a defragmentation or whatever, too much to figure out.
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
SMR drives only really show that they are SMR during writes. Read tests won't really be able to determine if the drive is SMR.
This is a 5TB SMR next to a 4TB PRM drive. Note now you really can't tell the difference from an HDTune benchmark.
Also know that these are both 5900RPM drives, hence the lower read speeds and higher access times.
Also, I know if you search for the model number of the 5TB drive it will come up as a Barracuda drive, it is not actually a Barracuda drive. Seagate simply labels it a "Desktop Drive", retails have tacked the Barracuda name onto it. But what has actually happened is these are drives that are supposed to be used in external enclosures. People have shucked the drives from the enclosures(or intercepted shipments before they even went into external drives) and are selling the bare drives and calling them Barracuda drives.
Yes, I would.
This graph, where you are testing the drive without Windows running from the drive is very wrong looking. There is something very strange going on with this drive. You should have a steady slope downward, like what I posted above. But it looks like for some reason at the ~1500GB mark, the drive just shoots up and starts reading instanely fast. Also, there are a lot of access times that are near 0, which should only happen with an SSD. In fact, at the ~1500GB mark, it seems like this drive just start to read exactly like an SSD does, but that shouldn't happen unless there is some kind of SSD cache happening.
I'd also be insterested in seeing an error scan of the drive too, as well as a speed map once the error scan is finished.
But either way, I think an RMA is in order, because something ain't right with that drive.
XmutanoX
19 (0.01/day)
When i have the time I will try to do an error scan on it to check if something comes up, i did a quick one but it came clean so i'm gonna try the long scan this time, also what's a speed map?
Ok i made error scans on both HDs, they both had no errors and these are their speed maps:
1TB HD (the borrowed one)
2TB HD (faulty one)
I also noticed that this 2TB HD is the only one that gets beyond 40C everytime it's on stress for some reason
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Yeah, somethings not write with that drive, and heck the 1TB drive is even on its way out. But that 2TB is definitely screwed up. It almost looks like the head is getting stuck at a certain point.
RMA it.
