Should the idle core temp equal to water temp?
992 (0.21/day)
Memory 2x24gb Gskill 8800c38
Display(s) Sammsung G7 32”
Case Dynamic XL
Power Supply Corsair AX1600i
Mouse Model O-
Not sure about this but my water temp is 23c from a cold boot and my core temp is 28c lowest, most of them is in the 30s. Should it be around the water temp? If yes what cause it? I have a mora 420, cpu block and ram block with dual d5 pump and flow is 261 L/h.
This is my system from cold boot. Min temp is idle temp. The other is other guy’s system and his core temp is around his 15c water. Cpu pakcage is around the same for both system 60w at idle.
Both system use supercool direct die.
Toothless
Tech, Games, and TPU!
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Man, did you forget the source of heat will never be the same as your water? IHS, paste, cold plate. It's not 100% efficient.
18,585 (2.70/day)
System Name AlderLake
Lei
1,143 (0.94/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
He's direct die cooling.
2,193 (1.26/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
What you want to compare is your water temp vs your ambient air temp. If you can stay relatively close to your ambient your golden. Comparing to your idle CPU temps to water temp is fun but once you load up your CPU it blows everything up.
9,340 (5.44/day)
Louisiana
Keyboard G710+x3
All core 6GHz ?
I'd think you were doing pretty well but just showing realtemp or coretemp can't tell which one and also wouldn't compare either monitoring apps with hwinfo.
Toothless
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Lei
1,143 (0.94/day)
usually in my shirt
Doesn't matter. The source will always be warmer.
Yeah, but after delidding and seeing someone else's good temps, you aim for the sky
@mrthanhnguyen
Put your pc under load for sometime, let the water warm up. Then without turning the PC off, stay idle until water reaches ambient again. How close are the temps now?
It's either your mobo warms the cpu a bit, or your TIM is either too much or crappy.
Sometimes my coolant is warmer than the gpu. And my thermometer is accurate as hell. (I know bcz my hdd and thermometer read the same when I cold boot after a long night)
351 (0.09/day)
Oztralia down under
System Name K9
Processor i9 9900K @ 5.1Ghz and 32deg C - delid + Grizzly Conductonaught LM
Motherboard Gigabyte Aorus Z390 Gaming X
Cooling Custom water cooling loop - GPU + mobo (+VRM's) + CPU
Memory G Skill - Trident Z RGB DDR4 - 3866Mhz x 32Gb @ 3800Mhz
Video Card(s) Gigabyte Aorus 11Gb GTX 1080 Ti Waterforce Extreme @ 2250Mhz
Storage Samsung 500Gb M2 970 EVO + Samsung 850 Pro SSD + ADATA 512Gb SSD + Samsung 1Tb & 3T + WD 1Tb + 3Tb
Display(s) ASUS 27" ROG Swift 1440p @ 165Hz & BenQ 27" LED
Case Thermaltake Core P7 - Open frame
Audio Device(s) Logitech Z906 - 5.1ch
Power Supply EVGA 1200W
Mouse Roccat LeadR + Razer Nagar V2 Pro
Keyboard Corsair K70 LUX with Cherry Red switches
Software Win 10 Pro 64bit
Benchmark Scores v/fast
hi all,
Mine is always 2 - 5 deg C difference.
And it's been that way since my first wc plunge with a i7-4770K then i7-4790K then i7-7700K and currently a i9-9900K.
And the i9-9900K has a pure copper IHS.
All the above were de-lided with Thermal Grizzly Conductonaut liquid metal .
  • Like
Reactions: Lei
Toothless
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
@mrthanhnguyen
You're not, ever, going to have perfectly equal temperatures between the processor and water. Delidded or not. You're not smarter than physics.
992 (0.21/day)
Case Dynamic XL
Mouse Model O-
Im not looking for equal. At least 3c delta but I have like 7c delta.
Lei
1,143 (0.94/day)
usually in my shirt
Where the thermometer in your loop? The water is warmer on the cpu, than after the radiator
How big is the other guy's reservoir?
Use liquid metal...
Throw a burning match in teaspoon of water. The water vaporates and match is dead wood.
Processor can get colder than water and then water starts giving heat to processor. That's what's physics do. At idle, metal loses heat faster than water does.
9,340 (5.44/day)
Louisiana
Keyboard G710+x3
Funny mine is lol
My water temp sensor shows 32c and so does a lot of my core temps :eek:
I'm not bare die or doing 6GHz though :laugh:
Hotter chip ?
  • Haha
Reactions: Lei
2,784 (0.56/day)
No. Let me explain why by basic physics.
The CPU creates energy, in the form of heat. Energy can only disperse from high concentration to low. It disperses faster the higher the difference. In this way the CPU generates heat, that increases its temperature. That energy transfers into the water loop, more energy the more the temperatures differ, until such time as you reach a steady state between CPU and cooler.
If you then take a sensor for air temperature it should be lower than the water loop. Both actually start at ambient...and the reason for the huge radiator surface area is that as the water is closer to air temperature you need to transfer that energy over a much larger surface area because the delta in temperatures is smaller...
TL;DR
You're good. q(energy transfer) = -k(thermal conductivity)*deltaT(difference in temperatures)
Less physics minded, to transfer heat by conduction you need a difference in heat between surfaces (delta T above).
Edit:
You can also have a bad loop. Temperature is a measure of energy...but you can have a delta that is fractional and assuming you run a cool CPU it'd show the same. That said...why in Hades would you spend money on a liquid cooler for than...unless you're morally opposed to a fan...
unclewebb
7,901 (1.32/day)
Intel CPU temperature sensors are designed and intended to be used for only one purpose. To control thermal throttling at 100°C. They have never been 100% accurate when a CPU is idle. They are not calibrated for that purpose.
It is also very normal for the true core temperature to be slightly hotter than the water temp or the air temp or anything else. The source of the heat will always be hotter than anything surrounding it.
Most Intel temperature sensors are only accurate to +/- 5°C.
  • Like
Reactions: Lei
581 (0.59/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
You will never have equal temps from cold boot. Either the water is warmer or the CPU. My computer have been on for about 12 hours now. and CPU, GPU and water temp all read 29C. They do not read 29C when I cold boot my computer in the morning.
Not true unless you have the worst flowrate in the history of watercooling. The water everywhere, in a decently built loop, will be within the margin of error of any temperature sensor normally used in a custom loop.
Lei
1,143 (0.94/day)
usually in my shirt
My reservoir is 5 gallons. You're welcome
The flowrate is fine, but lake freezes from top and fish peacefully swim under, so temp is not the same everywhere.
Toothless
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
You've never heard of water moving below freezing?
11,960 (1.72/day)
System Name Compy 386
Motherboard Asus
Cooling Air for now.....
Memory 64 GB DDR5 6400Mhz
Display(s) 55" Samsung 4K HDR
Audio Device(s) ATI HDMI
Mouse Logitech MX518
Keyboard Razer
Software A lot.
You are assuming the processors thermal sensor is accurate.
Without placing a thermocouple between the die and plate there is no way to know exactly how accurate it is.
The lower the Delta T the less thermal flux, there MUST be some gradient.
Lei
1,143 (0.94/day)
usually in my shirt
Arctic Ground Squirrel body temperature drops to -2.9°C for upto 9 months. It can clear its blood and body fluids from water to prevent icing. It can also go brain dead and regenerate the synapses.
They mate in late April (now :D )
One male may have more than one wife, and vice versa.
They're sleeping most of the year, so I guess no time to pick up the right date.
Female sleep in August, male next month. And male wakes up 3 weeks earlier.
Male ones kill the kids of other squirrels and eat them (whoever enters my territory shall die or be my son)
After waking up, within 2 hours all their dead brain cells recuperate.
They have the lowest body temperature of all mammals.
Yeap, to know how their brain recovers after hibernation, scientists took their brains out and sliced them into Doritos right after they woke up.
Their neck never drops below 0.7°C
Every 2 to 3 weeks during hibernation, they shiver and bring their temp back to normal 36.4°C for 12~15 hours, then freeze again.
Imagine how your life would be, if you were awake only 3 months of a year. Be born, mature, sleep, wake up, mate, conquer.
Toothless
9,567 (2.47/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Wake up and bang? I'll take that over working my life away.
  • Haha
Reactions: Lei
992 (0.21/day)
Case Dynamic XL
Mouse Model O-
Now I turn on c state and all power saving feature then cpu and voltage clock down so core temp is around water temp within 3c.
9,340 (5.44/day)
Louisiana
Keyboard G710+x3
There you go
I'd bet some inactive cores are showing at water temp now to :cool:
31c atm
phill
16,799 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
Just a quick question - what is your ambient temp? Roughly...
  • Like
Reactions: Lei
