SilentiumPC Introduces The Armis AR5X TG RGB Chassis
crazyeyesreaper
Not a Moderator
9,828 (1.68/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
Introducing the latest addition to the Armis lineup, Armis AR5X TG RGB, the most refined mid-tower chassis from SilentiumPC. This top-of-the-line variant of AR5 series provides unparalleled balance of perfect external size and design, features, quality and price for a wide variety of PC system configurations.
The Armis AR5X TG RGB comes with dual tempered-glass panels, one on left side and another one in the front, and is fully RGB-enabled with four ring-type Sigma HP Corona RGB 120 mm fans creating subtle yet stunning illumination effects.
Having a minimalistic, tempered-glass front panel, does not compromise the cooling properties, as the signature Armis side-vents provide airflow levels comparable to fully mesh fronts.
Three Sigma HP Corona RGB 120 mm fans located in the front are pushing the air towards the fourth fan in the rear, assuring outstanding cooling right out of the box. Up to 8 fans can be installed in total.
Extra effort was put into improving the internal structure design. Entirely new motherboard tray features a gentle styling touch - distinctive hexagonal patter that discreetly matches other openings in the chassis. Functionality upgrades revolve around simplified interior design with emphasis on ease of component installation and straightforward cable management.
Armis AR5X TG RGB supports ATX, microATX and mini-ITX mainboards and offers ample space for latest VGA cards with a length of up to 350 mm as well as CPU air coolers with a maximum height of 162 mm. Users are able to install All-in-One water-cooling systems with 120/140, 240/280 and even 360 radiators in the front. Thoughtful 2.5/3.5" drive spaces allow users to conveniently install up to 2x SSDs and 2x HDD/SSD while the redesigned bottom chamber offers more space for power supplies.
Easy to remove and clean dust-filters are installed in the vents in the front, the top-cover and on bottom of the case. Mounting of backplate-based coolers is made really easy thanks the large, dedicated cutout in the motherboard tray.
The RGB illumination can be adjusted manually using the dedicated button on the front panel or via compatible motherboard software such as ASRock RGB LED, Asus Aura, EVGA RGB or MSI Mystic Light. The core and the brains of the system is the built-in advanced Aurora Sync PRO RGB/PWM controller which acts as an intelligent hub for up to 6 compatible devices. It allows for plethora of manually triggered effects such as Breathe or Wave, as well as further expandability (i.e. SilentiumPC Navis RGB or Fera RGB CPU coolers).
In addition, the Aurora Sync PRO controls the fan speed of up to 6 fans using a single PWM signal from the motherboard.
The SilentiumPC Armis AR5X TG RGB is available as of today for a competitive price point of 79,00€ (incl. VAT).
Brcly_Kallistra
8 (0.00/day)
Okay, so it's a standard tempered glass gaming chassis, but the vents look decent, and the fans are on the inside of the metal frame, instead of the outside.
This looks like it can compete with most other chassis, and that lower price point looks appealing.
FreedomEclipse
~Technological Technocrat~
24,611 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Isnt that the walmart PC case?
712 (0.21/day)
Croatia
Processor Ryzen 5 3600 PRO
Motherboard AsRock B450 Pro4
Cooling Thermalright Peerless Assassin 120
Memory Silicon Power XPower Zenith 2x8GB @3200 MHz
Video Card(s) Gigabyte RTX 2070 Super Gaming OC 8GB
Storage Crucial P5 Plus 1TB / Crucial MX 500 1TB
Display(s) Dell P2419H
Case Fractal Design Pop Air /w 3x Thermalright TL-C12C
Audio Device(s) Creative Sound Blaster Z + Edifier R1000T4
Power Supply Super Flower Leadex III 650W
Mouse Microsoft Intelimouse Pro
Keyboard IBM KB-8926
Benchmark Scores Turns on on the first try! Usually.
Nah, this one actually has some ventilation holes on the side of the front panel, that one was basically air-starved.
6,500 (1.56/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
SO what exactly is new about this case again ?????
I musta missed it in between whoofin down my burger & takin a sip of me beerz :D
Deleted member 67555
No those are In~win cases that are cheapened with plastic windows.
That is a fantastic price for included rgb fans that are both manual or software addressable.
