Silkland Launches First 6.6 Feet (2 Meter) VESA-Certified 80Gbps DisplayPort 2.1 Cable on Amazon
Nomad76
1,497 (3.59/day)
Silkland, a tech brand specializing in cables and accessories, has announced the launch of its new 80 Gbps DisplayPort 2.1 cable (Model Number: S1334). As the first 6.6 feet (2 meter) VESA-certified cable available on Amazon, the cable is designed to enhance both visual and audio experiences, catering specifically to the needs of high-end gamers and professionals.
The 6.6 feet VESA Certified 80 Gbps DisplayPort 2.1 Cable offers an impressive 80 Gbps bandwidth, supporting ultra-high resolutions and refresh rate like 16K@60 Hz, 8K@240 Hz, 4K@960 Hz with DSC, and uncompressed 8K@60 Hz, 4K@240 Hz, 2K@540 Hz. Compatible with UHBR 20, dynamic HDR10+, 3D, and HDCP 2.3, this cable ensures exceptional visual quality. Additionally, it offers backward compatibility with DP 1.4 and DP 1.2.
Designed for gaming enthusiasts, this cable incorporates multiple advanced technologies to ensure stable data transfer and smooth visuals without lag, tearing, or flickering. The MST technology enables multi-monitor setups, supporting dual 4K@240 Hz and triple 4K@144 Hz, expanding the gaming environment. Dynamic HDR improves dark scenes, while 32-bit audio and lossless surround sound deliver an immersive experience.
Moreover, the cable offers wide compatibility with devices featuring DP ports, including popular DP 2.1 gaming monitors such as Odyssey G8/G9, ROG Swift and Acer, as well as the latest graphics cards like RTX 5090D, 5080, 5070 Ti, 5070 and AMD 7900 XTX.
The 10 feet (3 meter) Silkland 54 Gbps DisplayPort 2.1 Cable has also been added to the list of VESA-certified products recently (Model Number: S1318). This is the longest Certified DP 2.1 cable on Amazon.
With the introduction of its new certified cables, Silkland is dedicated to creating top-quality cables and providing outstanding customer service. The brand offers a 24-month warranty and quick technical support to resolve any issues.
Just say 2 meters what the heck is a feet
It´s sad.
I can´t take a company serious that has an empty "contact" page on their website.
If the homepage is unprofessional i have to question their vesa certification claims as well.
Yeah. Stupid prehistoric measurement system. Civilized world uses metric system. Even USA's scientists a'la NASA use metric.
Good news is that 2m and 3m cables are 2x and 3x price of the 1m cables. More expensive for sure, but reasonable.
Your ignorance is appalling. A feet equals two scapulas or six noses.
Man, these people...
Yeah... I can't believe there are people not able to comprehend simple math in imperial system, like 12"=1ft; 3ft = 1yd etc. Multiplying and converting those is soooo simple...
Who would want to just easily add zeros without any equations?!!! ...but seriously - imperial system is dumb AF!
As for those cables - I was wondering if at some point there will be DP 2.1 cords longer than 1-1,2m. If push comes to shove, we could use hybrid optical ones. I got such one (10m HDMI 2.1) for less then 100$ and works like a charm - connects my PC with a TV in the next room.
And all electronics use inches. So what. to be precise, fractions of inches.
Last time i checked some small smd stuff it was still fractions from inches.
· Screw terminal 2.54 mm pitch. The screw terminal component is crucial and comes as a simple two-position screw terminal containing 2.54mm pitch pins. Such a pitch allows it to align with the typical 0.1-inch perf boards.
· 2.54 mm screw terminal blocks. It comes as a side-entry screw terminal block and contains a 2.54mm or 0.1-inch pitch. It can become an excellent alternative to the typical 0.1-inch female or male headers that most printed circuit boards feature. The reason this becomes possible entails the terminals proving capable of releasing and holding wires through adjustment of screws, which allows for temporary connections to the PCB.
· 2.54mm terminal blocks. The 2.54 terminal block is an important component in a PCB that helps keep loose wiring in check when making PCB-to-wire connections. The spacing allows them to fit perfectly into breadboards (solderless).
· Veroboard pitch. It implies a 2.54mm hole size drilled into the copper track rows that feature this PCB design.
I think those SMD capacitors, resistors uses metrics
It's inherited from the old England of the crown era so unlikely.
Yeah, I was brought up using imperial and metric. Practically everyone in the UK says their height in feet and inches, also weight in stones and pounds and distance in miles.
Also when people go to a bar or nightclub, it's a pint of lager, cider or Guinness or whatever.
At school we learnt both in the 1980s/90s, not sure about now like.
