- Nov 17, 2007
- 2,228 (0.36/day)
- Larisa, Greece
System Name | StarCruiser Dark Knight v.2 |
Processor | Intel® Core™ i5-3570K |
Motherboard | P8Z77-V LX |
Cooling | 1x custom W/C loop/ inflow:6x120 /outflow:4x120, 2x200 |
Memory | Viper 3 Black Mamba (4x4GB) |
Video Card(s) | Powercolor LCS 5870 |
Storage | 1X 128GB OCZ, 2 x 1.500 Gb Seagate |
Display(s) | Samsung 24" LC24F396 |
Case | custom MDF case (I BUILT IT) check sig.....NOW |
Audio Device(s) | Onboard |
Power Supply | Tagan 900 watt |
Software | Win 7 RC / Open office / Games |
Specs:
THERMALTAKE VH6000SWA ARMOR+ WINDOW SILVER
c2duo 6420@3.6 oc
asus maximus formula se
asus 8800gtx ND5 cooler
asus ageia 128mb pci
2 x 1gb geil 900MHz oc
audio: supremeFX II
1 x 150 gb raptor 10.000rpm sata in hardcano
2 x 500 gb wd 7.200rpm sata2
1 x nec dvdrw
1 x samsung dvdrw
psu 700watt toughpower
Mods:
or cooling the 8800GTX:
THERMALTAKE CL-G0099 TMG ND5 NVIDIA COOLER
AKASA AK-455-5G HI PERFORMANCE THERMAL COMPOUND 5GR W/ SPREADER CARD .......fan controller:
AEROCOOL GATEWATCH II BLACK.......fans:
AC RYAN ACR-BF8973 BLACKFIRE4 UV LEDFAN 120MM UVBLUE-GREEN / 4X UV LED x2
I removed the bottom HDD cages and installed 2 x A.C.Ryan green-purple fans, and then I installed an fan with a preinstalled thermostat for the airflow output, which shows inflow while running. Then Getting all the controller wires in place was a pain.... I setup 3 fan controllers (2x4 fan wires + 1x1 cpu fan wire) and thats not including all the thermometer wires ...I first used a cable canal (like the ones we use on walls) to hide the cases' cables and then tried to route the others...Left power cables for last. Anyway, what I really hoped for, is finally a reality.... low temperatures all around inside the case.for example e6420@2.13ghz idle temp: 12 C, e6420@3.2ghz (oc) idle temp 18 C, 8800gtx@565/1350/1800 idle temps gpu:55C, mem:42C ................................................................... I was a bit worried about the heat spread inside the case instead of out of the case, when using this cooler ...according to reviews, anyway! But, with all this airflow, I soon found out that this was not a problem. Not with this case! and about 300cfm maximum air intake!and 250 outflow!
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F1_275_208.jpg&hash=d055abaa3a657e97b8c9a8451a44a8e4)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F2_275_208.jpg&hash=ca59cb31037c570d8ca06a8e57a7ba58)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F3_275_208.jpg&hash=43ec2bc89a1808462d01e1ff3968d4cb)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F4_275_208.jpg&hash=5871feb90ccee50faa18893fe6a9be26)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F5_275_208.jpg&hash=fa1626ce5f8ee50664b3575b636dd6b5)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F6_275_208.jpg&hash=2338489974a09742408cecdb4b9303b4)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F7_275_208.jpg&hash=b03653a95425b8f2377bf180192ae30c)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F8_275_208.jpg&hash=9695388477800c9e8edfc8bdaf2e9715)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F9_275_208.jpg&hash=4484d15995c45bc186c5c754f85a05f5)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F10_275_208.jpg&hash=0f1f9378149b26d6e32dd531981a4d4a)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F11_275_208.jpg&hash=7b591c2c554e810a152b056012a86c84)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F12_275_208.jpg&hash=14dd1ea76764c768ecf479680ccd503e)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F13_275_208.jpg&hash=2a5a0442024a2df02d8cc335c755f41f)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F14_275_208.jpg&hash=9a518e98d2e97fdc7b59c337a9a0f115)
![](/forums/proxy.php?image=http%3A%2F%2Fwww.techpowerup.com%2Fgallery%2F1394%2F15_275_208.jpg&hash=d1a4e9c2170b307501303aef1dfaa206)
Specs:
c2duo 6420@3.6 oc
audio: supremeFX II
1 x nec dvdrw
1 x samsung dvdrw
Mods:
