SilverStone Intros FHS 140X, a Thick 140mm Fan with High Static-Pressure
47,200 (7.56/day)
SilverStone today introduced the FHS 140X, a powerful 140 mm fan meant to be used with radiators or heatsinks, or as high-pressure ventilation in server/workstation builds. This fan is 38 mm-thick, while standard 140 mm fans are supposed to be 25 mm in thickness. The impeller is geared for high airflow, and is turned by a high-power motor. This combination results in a stellar 10 mm H₂O static-pressure, and maximum airflow of 222.95 CFM, which it achieves at its top speed of 3,400 RPM. All this comes at a maximum noise output of 50 dBA, and a little over 13 W of power-draw (so you need to plan your fan-control setup carefully). The fan is clad completely in black, including the impeller and frame. A metal grill comes included, which you're recommended to place near the inlet. The company didn't reveal pricing.
2,201 (1.25/day)
System Name DadsBadAss
Motherboard MSI Z790 Tomahawk Wifi DDR4
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP- 2x Koolance PMP 450S
Memory 4x8gb HyperX Predator RGB DDR4 4000
Storage WD SN850x 1TB NVME M.2/Adata XPG SX8200 PRO 1TB NVMe M.2
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply Seasonic Focus PX-850 w/CableMod PRO ModMesh RT-Series Black/Blue
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win11pro
May the fingertip decapitations begin anew!
41,963 (6.61/day)
The Fan Showdown Enters the Forum
6,881 (1.47/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
loudest fan I can remember was vantec tornado 92mm
Air Flow: 110.5 CFM
Noise Level: 55 dBA
2,067 (1.02/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
Software Windows 10 Pro X64
Benchmark Scores Who cares
Nice but 50db is a bit loud, though i suppose even at lower speed it will still be better than most 140mm fans and not so loud.
1,656 (0.79/day)
Motherboard MSI X670E Carbon
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Display(s) Samsung G8 OLED
Case Silverstone FT04
Base on my own experience on their 140 and 180 fans.
Silverstone's fan bearings had very obvious 'tick' sound at low speed.
They are not designed to run very quiet at low speed.
2,067 (1.02/day)
System Name BigRed
Processor I7 12700k
Case Corsair 7000D
No way i would have 50db fans in my PC.
32 (0.02/day)
Australia
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS Crosshair X670E Extreme
Cooling Alphacool Core 1 CPU / Alphacool Core 7900XTX Nitro / Hardware Labs GTS360 & GTS180x2
Memory 2×32GB G.Skill Flare X (6000MHz @ 30-40-40-96)
Video Card(s) Sapphire RX 7900XTX Nitro+
Storage 2TB Kingston KC3000 / 2×4TB Kingston KC3000
Display(s) Samsung Odyssey G8 (3440x1440 175Hz OLED)
Case Fractal Design Torrent
Audio Device(s) HyperX Cloud Alpha Wireless
Power Supply Corsair RMx1200 Shift
Mouse Logitech G Pro Superlight 2
Keyboard Keychron Q6 Max (Gateron Jupiter Red)
These are not meant for consumer cases but rather things like rack mount server chassis. I'm using Silverstone's RM43-320-RS chassis as a home server and it includes three of the 120mm versions of this fan in it. It's freaking loud when the hard drives start warming up but it is admittedly very good at cooling everything down even at low speeds.
2,201 (1.25/day)
Software Win11pro
Air Flow: 110.5 CFM
Noise Level: 55 dBA
It's like taking a step back in time right?!
6,044 (2.89/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
"In my PC", guys product picture shows them mounted in a case with server motherboard installed. Noise is not an issue there. This is pretty much an industrial grade fan.
1,965 (0.62/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
The latest Intel® suggests a need within the consumer market.
2,544 (2.05/day)
Sounds great... I mean maybe not sounds, but seems great :D
Their minimum speed is a bit high at 800rpm and it will probably be on the expensive side, it would be great if they would do a cheaper version that goes to a more regular 1500~2000rpm range and would do a lower minimum speed at least in 400rpm range. That would be more usefull for desktop, 800rpm is not terrible but along with the probable high price doesn't make much sense to pay and not have better range of fan control.
Thick fans for the win!
64 (0.05/day)
Air Flow: 110.5 CFM
Noise Level: 55 dBA
If you forget all fan Like Delta, Nidec, Sanyo ect and others high 120mm per 38mm in 2005 Era yes it one but many toped 60dBA and little more at 4000 to 6000+ RPM. There was a good store in US that haved many, Sidewinder Computers.
That's was in old good time
65 (0.06/day)
This powerful server fan will retail for less than $30 when it is expected to be available later this month.
The ticking noise was the result of fan motor IC not tuned correctly to match the harmonics of the fan noise frequency at lower speeds. This happened with our first production batches of the Air Penetrator 184i so if you have one of those, please get in touch with us directly (for Norther America: usasupport@silverstonetek.com, others: support@silverstonetek.com) to get a replacement! If you have other fans of ours that are making usual noises, let us know about them as well.
65 (0.06/day)
Thank you for your interest in our fan! We have no plans for a slower version of this fan at the moment. Fan blade shape or geometry are often designed to optimize for specific range of speeds or usage purpose. So in the case of our FHS140X, it was designed for ariflow and pressure focused applications (server case fan) up to 3400rpm. Slowing it down significantly may result in a fan that is slightly or no better than thinner profile fans optimized for their respectively speeds in regards to performance/noise ratio, which is important for consumer desktop fans. If you are still looking for a high performance 140mm desktop fan, please check out our "Shark Force 140" as an alternative.
1,656 (0.79/day)
Cooling MO-RA 3 420
Memory 32GB 6000MHz
Storage 4x 2TB Nvme
Wasn't expect to get a rep here, but sure the help is appreciated.
And yes those are the AP 184i PRO I was talking about.
