- Oct 9, 2007
- 46,892 (7.62/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
SilverStone today introduced the RM44, a workstation or small-business server case, which is designed to be used both as a tower, or as a 4U rackmount. The case supports SSI-EEB, SSI-CEB, E-ATX, ATX, Micro-ATX, and Mini-ITX form-factors; a single ATX power-supply, eight full-height expansion slots, and cooling that includes two 80 mm rear exhausts, and three 120 mm front intakes. As you can see from the pics below, the case can even be used to build the most inconspicuous high-end gaming PC. A steel reinforcement running along the length of the case holds a couple of 3.5-inch drives or three 2.5-inchers, and can firmly hold your add-on cards in place. included is a stand that lets you orient the case as a tower, while rails let you mount it in a rack. The case measures 440 mm x 176 mm x 468 mm (WxHxD). Front-panel connectivity includes two USB 3.2 type-A, and a USB 3.2 type-C. The company didn't reveal pricing.
![](https://www.techpowerup.com/img/xY8Wj3PU7qYuJLxz_thm.jpg)
![](https://www.techpowerup.com/img/R6TxcCfhnh3ttnqJ_thm.jpg)
![](https://www.techpowerup.com/img/9pcTEQMkFwxhRP3L_thm.jpg)
![](https://www.techpowerup.com/img/hN19lyztrT6dvhUm_thm.jpg)
![](https://www.techpowerup.com/img/ZTABK3jPvi3wb75U_thm.jpg)
