Silverstone SST-PS08B Micro-ATX Case Detailed
47,180 (7.56/day)
Silverstone released an entry-level micro-ATX case, the Precision Series PS08B. Built primarily of SECC-steel and ABS plastic, the case measures 168mm (W) x 355mm (H) x 400mm (D), weighing about 3.5 kg. The PS08B includes a handy innovation - the 3.5-inch drive cage is shifted towards the left-hand side facing front, which allows graphics cards to pass right through. As a result, cards as long as 14.1-inch (35.8 cm) can be installed, provided they're less than 5.7-inch (14.47 cm) tall. The case features a total of two 5.25-inch, four 3.5-inch, and two 2.5-inch drive bays.
The motherboard tray of the PS08B supports micro-ATX and mini-ITX form-factors. A large cutout decks the CPU socket area, for easy access to CPU coolers with back-plates. Ventilation includes one 120 mm front intake, and one 80 mm rear exhaust. The utility panel includes USB 3.0 (standard header) and audio jack (HD audio header). Slated for market release in late-October, the PS08B is priced at 3,980¥ (US $50).
9,901 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
fail, no cables at all
41,888 (6.61/day)
47,180 (7.56/day)
9,901 (1.85/day)
Jakarta, Indonesia
Case Icute Super 18
HammerON
The Watchful Moderator
8,400 (1.47/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling MSI MAG CoreLiquid E360
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 XLR8
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard ASUS ROG Strix Scope II Wireless
Software Win 11 Pro
5,614 (1.03/day)
San Diego, CA
System Name White Boy
Cooling CORSAIR H100
Display(s) 1 Dell 30U11 30"
Case BIT FENIX Prodigy
Audio Device(s) none
I looks well featured and is priced very well, but the front of that case is pretty ugly, that's 2 new cases from Silverstone, that have all the nice high quality Silverstone touches, and then front is so horrible looking it's like they were designed by someone that hates the company.
9,901 (1.85/day)
Jakarta, Indonesia
Case Icute Super 18
yeaH from front usb to down still looks nice but the upper front is bad
47,180 (7.56/day)
yep but with that space the cables would bend much :shadedshu
I see more than an inch of clearance. Enough room to bend even the toughest cables.
Plug in the cables, then insert the graphics card, bend the cables as you're inserting; and not install the card and then attempt to plug in the cables. Not rocket science, really.
k0rbein
8 (0.00/day)
Innaarsuit, Greenland
System Name Ol' Reliable
Processor AMD Phenom II X6 1090t @ 4.3ghz
Motherboard JW A880-GMT Extreme
Cooling XSPC Cooling Kit
Memory Gskill Sniper 8gb 1600mhz
Video Card(s) Asus GTX 580 Matrix Platinum
Storage Samsung 840 Pro raid 0, Toshiba 2x4tb
Display(s) Dell U2913WM
Case Fractal Arc Mini
Power Supply Amacrox Freestyle 750W
M-Atx with 1,2k psu.. :banghead:
41,888 (6.61/day)
MATX wasnt meant for that, more like HTPC. MATX is crippled as of expansion primarily, so they dont require massive PSUs to function, which is good to a point.
4,267 (0.68/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
+1 to cramped. However, I'm saying that in a positive tone, so more like "cozy" - at least with a high-end mATX setup. For mITX, it's quite roomy.
Unfortunately the outside just isn't doing it for me so I'd use it for neither purpose.
696 (0.11/day)
Portugal
System Name Quiet Gaming PC v5
Processor AMD Ryzen 5 5600
Motherboard Gigabyte B550 Aorus Elite V2 (rev. 1.2)
Cooling Thermalright TRUE Rev. C
Memory 2x16GB TeamGroup Vulcan Z Red DDR4-3600 CL18
Video Card(s) XFX Speedster SWFT 309 RX 6700 XT
Storage WD Blue SN550 1TB NVMe // TeamGroup MP34 4TB NVMe // Crucial MX100 512GB
Display(s) MSI G27CQ4 E2
Case Fractal Design Define R4
Audio Device(s) Realtek ALC1200
Keyboard MKPlus Slayer M3 RGB Mechanical Keyboard
Why are all new Silverstone cases so ugly? Are people attracted to this now?
NHKS
596 (0.12/day)
i am not happy with the looks (front panel aesthetically).. quirky parts of design are front & rear panels .. at front, intake mesh is not 'flush' with ODD covers.. while at the rear, the MB I/O panel & expansion slot openings are flush with the rest of the panel(which makes the add-on card screws to jut outside!)..
packaging seems tight but doable, cooling might be adequate as long as the HDD cage is not full.. i prefer the PS07 thanks..
4,113 (0.68/day)
Iowa, USA
System Name THE CUBE 2.0
Processor Intel i5 13600k
Motherboard MSI MPG Z690 EDGE DDR4
Cooling Phanteks PH-TC14PE BK 2x T30-120 Fan mod mount
Memory G.Skill TridentZ 3200 MT/s C15 32GB 2x16GB
Video Card(s) Gigabyte Aorus 1080 Ti 11GB OC: Core 2GHz, Mem 5.7GHz
Storage WD SN770 250GB / 3x WD SN850X 2TB / Toshiba X300 4TB / 2x RAID1 Toshiba P300 3TB
Display(s) Samsung 49" Odyssey OLED G95SC 240Hz 5120 x 1440
Audio Device(s) Beyerdynamic DT 880
Power Supply Corsair RM1000X
Mouse Logitech G700
Keyboard Logitech G910
...The front sucks, the layout sucks, this whole case sucks. The only way to save these poor cards is either WaterCool (No room for that) or just go with one card...
365 (0.07/day)
I said it about the SG09 and now I'm even more convinced...Silverstone lost some designers somewhere along the way. They are spawning some ugly, ugly children these days.
979 (0.20/day)
Processor 12100
Video Card(s) 1650 Super
Case Coolermaster Ammo 533
Mouse G403
Keyboard Sidewinder x4
This is disappointing. Antec 300 with less fan slots and uglier front.
Zefferelli
1 (0.00/day)
Contrary to the opinions of the others here, I quite like the front fascia. Reminds me, somewhat, of the HP Z-series workstation towers.
mediasorcerer
978 (0.20/day)
coast ,melbourne
System Name THE MEDIAMACHINE
Processor i5-3570k
Motherboard Asus gene v z-77 matx.
Cooling Antec h20 620
Memory 2x4gb g.skill ripjaws z 2400
Video Card(s) h.i.s radeon 7950 reference 3 gb- hooray!!!
Storage samsung 128gb~830 ssd. samsung 500gb hdrive.
Display(s) 22 inch tele.
Case circa 1996 grey rat box with no sides front.until my own is finished
Audio Device(s) inbuilt creative.supreme effects 3
Power Supply thermaltake tt-500w
Software win 7 x64-
Benchmark Scores Coming soon
Yes i think the fronts quite ugly too[not in the realm of hideous though], the tjo8e had a nice front for a matx, and not bad room/cooling too, they should have stayed with that theme but extrapolated on it, was a nice looking case.
1,964 (0.42/day)
Sydney NSW, Australia
System Name Shoebox Sandwich | Razer Blade 14 | Synology DS423+ w/ 4X8TB WD Red | ROG Ally | Mac mini
Processor AMD Ryzen 7 7800X3D | AMD Ryzen 9 5900HX
Motherboard ASRock B650E PG-ITX WiFi | Razer thing
Cooling NZXT Kraken 240 RGB w/ Lian Li P28 + Corsair AF120 Slim | Double fan vapour chamber
Memory G.Skill Flare X5 2x16GB 6000MHz CL32 DDR5 | 16GB 3200MHz DDR4
Video Card(s) Sapphire Radeon RX 7900 XTX | NVIDIA GeForce RTX 3070 8GB
Storage Seagate FireCuda 520 2TB + Lexar NM790 4TB | 1TB NVMe SSD + 2TB NVMe external SSD
Display(s) Alienware AW3423DW & Sony A90K 42" | 14" QHD IPS 165Hz & Sony BRAVIA 9 75" TV
Case FormD T1 - v2.1 - Titanium colourway w Aluminium mesh | Razer Blade 14
Audio Device(s) Schiit Hel 2E (Focal Clear & HiFiMAN HE-4XX & DROP PC38X) | Samsung Q950A
Power Supply Corsair SF750 Platinum | Razer 230W brick
Mouse Razer Viper Ultimate Mercury | Roccat Kain 202
Keyboard Womier SK75 (Green) | Corsair K63
VR HMD Oculus Quest
Software Windows 11 Home | Windows 11 Home
Benchmark Scores 2022 MINI Countryman SE PHEV Hybrid ALL4 | British Racing Green| Malt Brown Interior| YOURS Trim
not to mention-no cpu, no cpu heatsink/cooler, no ram.
I think Silverstone has become a bit like honda recently. Still remain very practical and a quality product (in the most part) with some pretty cool features, but are butt ugly or just plain boring. Silverstone really must have lost some designers in the recent months.
716 (0.13/day)
Finland
System Name RGB-PC v2.0
Processor AMD Ryzen 7950X
Motherboard Asus Crosshair X670E Extreme
Cooling Corsair iCUE H150i RGB PRO XT
Memory 4x16GB DDR5-5200 CL36 G.SKILL Trident Z5 NEO RGB
Video Card(s) Asus Strix RTX 2080 Ti
Storage 2x2TB Samsung 980 PRO
Display(s) Acer Nitro XV273K 27" 4K 120Hz (G-SYNC compatible)
Case Lian Li O11 Dynamic EVO
Audio Device(s) Audioquest Dragon Red + Sennheiser HD 650
Power Supply Asus Thor II 1000W + Cablemod ModMesh Pro sleeved cables
Mouse Logitech G500s
Keyboard Corsair K70 RGB with low profile red cherrys
Good luck installing the cables there. Yet alone running a decent demanding game like BF3 without throttling like never before.
PR fail right there, not really product fault. Showed setup isn't what this case is designed for.
What is product fault is the ugly exterior looks. I would take TJ08-E over that thing any day.
Fourstaff
10,074 (1.85/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
