Simple question about AMDVBFLASH
Kisaki
1 (0.01/day)
When opening the AMDVBFLASH program with the drivers installed, it opens a window with ":", apparently waiting for commands, but when trying to execute any command, it simply does not work. Without the drivers installed, the program only opens and closes automatically. What would be the function of the terminal created when manually opening AMDVBFLASH with the drivers installed?
43,079 (6.72/day)
Are you using version 3.15, 3.31 or 5.***?
If you are using those versions the driver is a necessary component and only used temporarily to allow the command prompt to induce the bios flash via commands, fyi atiflash/amdvbflash graphical user interface have been discontinued, use the command prompt to flash, you must be in an administrator privileged command prompt to flash. I believe there is a readme file that states to install the driver within the amdvbflash folder, once done flashing you uninstall that driver.
Ok pretty much confirmed in description here
