Small NZXT Gamma Mod/Addition Fan Question
TheBloodEagle
1 (0.00/day)
Hey guys, my first post. I've done a simple modification (had to bend some metal & put THIS in) to my Gamma case top bays in order to put a 120mm fan in there. I have a Asetek 550L Liquid cooler, so I did that modification in order to have more streamlined airflow onto the radiator. It's working pretty well. But I'm obsessed at the moment with adding one more fan. I've read a few reports about stacked fans but I haven't found exactly much on if a gap will be alright.
Here's my Case (sorry, I love orange, I know it clashes..ignore the dust):
[IMG]http://i.imgur.com/bjocRt3.jpg[/IMG]
Idea:
[IMG]http://i.imgur.com/J2kc7fr.png[/IMG]
Aside from ambient air in the room, I'm assuming that faster air is cooler air, so I want to add a fan in that orange highlight so it really force/accelerate the air through, like some pseudo-turbine. Stacked fans interfere which each other to the point you're actually having a negative effect (from what most people say) but do you think the spacing is enough to actually benefit the airflow? Should they be the exact same model fans? or should I use a different one for the 2nd fan? I'm currently using Cougar CF-V12HP's for both red labeled fans.
COUGAR CF-V12HP Vortex Hydro-Dynamic-Bearing (Flui...
The reason I ask about having 2 different fans is because of this Cougar illustration that shows their fan vs a normal fan. I'm thinking the "normal" fan would bring in air from the outside and just send it to the second fan where it would be more focused & accelerated thus even cooler. I don't think it would work right with a focused airflow coming from the first fan (red), seems like it would just hit the middle of the second fan (orange), so this might work since there's pretty much a tunnel going on? What do you think?
12,062 (2.58/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Get a fan shroud, they have been known to improve temps slightly. A shroud between fan(red) and fan(orange) will improve airflow direction.
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
I done similar to my zalman, but had 2 fans in the top bay.
it worked great on such a small case, you can even get mounts that are 5.25 size for 120mm fans
freaksavior
To infinity ... and beyond!
8,095 (1.22/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
3,842 (0.87/day)
System Name Zotan
Processor i9-10850K
Cooling H100
Case Airflow 275R
Power Supply RMX850
Can you post a better photo that doesn't have a weird angle to it please. :)
LOL that's the angle showing the fan in the bay.
I don't have that build anymore
