Smaller than pixel?
3,352 (0.60/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
Hi all!
I was reading an article of how gpus work and came upon a stunning and strange sentence:
Pixels are not the smallest unit that can be addressed by the GPU :twitch:
After reading it all, it didn't explain this.
It would interest me a lot if it is not the smallest unit.
Is it true? And what it is?
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
It might refer to this - subpixel
A component of a pixel. Three subpixels make up one pixel, namely one red, one green and one blue subpixel
atb (all the best)
Law-II
4,012 (0.70/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
Yes, pixels are made up of 3 primary colored "subpixels" that are controlled individually. The combination of Red, Green and Blue subpixels with differing brightness of each creates the color of each pixel you see. When all 3 subpixels are of equal brightness, they form the color White.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.36/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
The smallest unit sent to a dispay is the pixel (with color information). Inside the GPU, it's all math. The GPU basically takes a snapshot of an area of the math, calls it a pixel, and sends it to output.
4,012 (0.70/day)
Yes. The display then takes the "pixel (with color information)" and processes it internally, then sends the appropriate electrical signals to each subpixel and makes each subpixel twist a certain amount (for LCD displays, basically the liquid crystals in the subpixels twist to "open and close" the subpixel, essentially blocking the backlight and the subpixel color filter from being visible on the viewing side) or manipulates the electron beam in a CRT to hit the right phosphor pads that make up the subpixels with the correct level of energy.
11,880 (2.16/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
pixels dont exist to the geometry engine in a gpu or most of its core at all ,and untill the rops get involved they dont even matter or get considered
3,352 (0.60/day)
Case Zalman S2
Ok now after the last comment i got confused!
4,966 (0.86/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
yeah that's both a bit more info than necessary, and worded a bit confusingly. no offense to the last 2, but the first 3 replies give you a good short explanation.
Kreij
Senior Monkey Moderator
13,817 (2.08/day)
Cheeseland (Wisconsin, USA)
Here's a bit easier way to visualize it.
Let's say you tell your geometry engine (game engine) to draw a cube.
At this point the engine has no concept of pixels as it only knows that there is a cube (of undetermined final size because it only has vector information) that uses a texture.
The engine then takes other information (like scaling, rotation, lighting, etc), and creates your "rendered" cube, removing non-viewable information (based on camara direction) if told to do so, and also performs AA, AF, etc.
It then looks at the viewport information to see where the cube is in relation to the camera (distance from you) and again sizes it accordingly using the screen capabilities (resoultion, etc.) in pixels.
The order may not be exact in my example, but you can see why pixels have no meaning until the final output is displayed.
Let's say you are playing Skyrim. If you're not you should be. :D
If you tell the game to make an NPC twice the size (2x scaling), the number of pixels it uses on the screen is completely dependant upon where you are in relation to the NPC. Closer? More pixels, farther less.
Here is info on subpixel rendering
Subpixel rendering is a technique to give the impression of higher resolution due to the way humans see color combinations and the like.
On LCDs (not CRTs) each pixel is made up of 3 color subpixels. There are still only X number of pixels on your screen.
95Viper
Super Moderator
13,272 (2.20/day)
Cleartype uses sub-pixel rendering.
How does ClearType display technology work?
To understand how ClearType works, one first has to understand what makes an LCD screen different from other types of displays. Most screens created images made up of pixels, which when magnified look like single squares. The equivalent of one pixel on an LCD screen is actually composed of three sub-pixels: one red, one green, and one blue (R-G-B). Seen together, these sub-pixel triplets combine to be seen by the human eye as a single pixel.
If we were to look at a single pixel, our eye would see it as in the illustration above. However, if we were to magnify the image, we would see that each pixel is actually made up of three separate subpixels. And so, if when we see white on an LCD screen, we are really looking at red, green and blue stripes.
ClearType
Some info at GRC.com that is interesting: Sub-Pixel Font Rendering Technology
Subpixel rendering From Wikipedia < Kreij beat me to the posting.
Sort of interesting the way the mind and eye work.:)
Kreij
13,817 (2.08/day)
Hmmm ... it appears that sub-pixel rendering does have some effect (although not as good) on CRTs (it creates a slight blur).
I assumed (apparently wrongly) that because the three color beams focus on a pixel and blend to create the pixel's final color, that the concept of sub-pixels didn't really apply.
Perhaps the GCs are capable of minute adjustment to beam location within a pixel?
I'm gonna look into this more. Quite interesting (to me at least :D ).
W1zzard
Administrator
28,501 (3.73/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
direct3d doesnt support cleartype subpixel rendering. i think the OP is talking about something else.
either everything before rasterization, which is just floating point math. or maybe some sort of antialiasing?
Kreij
13,817 (2.08/day)
This is from a MS blog on the WPF Direct2d API
One of the first things that needed to be done was to change over the rendering code to be based on D3D10.1 rather than D3D9. This decision was made since there were several other technologies being built around this version of the runtime as a basis (10level9, WARP, D3D primitive remoting), and because we see hardware built around this architecture as being the future. This allowed us to design D3D10.1 interoperability, and hence allow these other technologies to interoperate with Direct2D as well.
And later in the blog ...
In the end, what we have built is a hardware accelerated 2D rendering API (with software fallback) with a modern primitive rendering set that allows interoperability with previous APIs as well as the state of the art APIs. We feel that this will be a worthy replacement for GDI and GDI+ for most application development scenarios, and will also be able to complement D3D10.1 in some game development scenarios as well. The componentized fashion that was used to build the full set of technologies will also allow developers to mix and match pieces to build things that were hard to build before, such as being able to render subpixel positioned text directly into Direct3D textures with support for any font.
Looks like DX10.1 and up support subpixel rendering. Another MS page on rendering tiers says subpixel (cleartype) rendering has been around since DX9. (shrug)
W1zzard
Administrator
28,501 (3.73/day)
Memory 48 GB
yes but thats only for text. basically what you see on your aero desktop
i dont think any game uses it, also it breaks when the screen is rotated and cleartype doesnt know about that
Kreij
13,817 (2.08/day)
Yes. Since the subpixels are oriented in a horizonal only pattern, rotating the screen tosses it out the window. Kind of dampens the enthusuasm about SPR, expecially for things like eBook readers. :laugh:
Looks like SPR is done in the shaders (2.0 and up), so it should be feasable in 3D. I read something about MSAA using a combination of SPR and AA, but I don't remember where I saw that.
You're still writing GPU-Z in MFC (thus GDI/GDI+) aren't you? I think you can do it somehow using GDI+ but it doesn't sound easy, nor is it of any value for your utility. But if you ever get the urge to make GPU-Z a full 3D app .... lol
W1zzard
Administrator
28,501 (3.73/day)
Memory 48 GB
gpuz uses subpixel rendering, like almost every other windows application that has standard windows controls
afaik cleartype is not done in shaders. msaa is a completely different technology and does not look suitable to me for ultra high quality font rendering
directwrite AA modes: http://msdn.microsoft.com/en-us/library/dd368118(VS.85).aspx
Kreij
13,817 (2.08/day)
Windows controls only use it for the fonts, no?
More info ...
A rendering tier value of 2 means that most of the graphics features of WPF should use hardware acceleration provided the necessary system resources have not been exhausted. This corresponds to DirectX version that is greater than or equal to 9.0.
and ...
Text rendering :
Sub-pixel font rendering uses available pixel shaders on the graphics hardware.
Fun stuff.
Edit : I saw the rendering enumeration page, but have no idea what "bi-level text" means. :roll:
Edit 2 : My bad, I was going from memory (not a good thing when you get to my age. lol)
It's not MSAA, it's Nvidia's SRAA (which was their response to AMD's MLAA) that uses post-processing techniques for subpixel fiddling.
http://research.nvidia.com/publication/subpixel-reconstruction-antialiasing
95Viper
Super Moderator
13,272 (2.20/day)
