I have this UGREEN enclosure and I'm looking for the best NVMe drive for my use-case. The drive will be used for transferring large files (both directions) and for long durations. It won't be used for long-term storage.
Unfortunately, most drive reviews focus on top DRAM speeds for gaming or ordinary computer use. Sustained speed and reliability are my main concerns. I guess heat would be another factor. It will be used primarily with USB 3.0 and 3.1. Mechanical external drives just aren't fast enough. For example, I performed a 2TB file backup/restore and it took nearly 6 hours with a mechanical drive running at 80-110 MB/s.
Which drive is the best value for my use-case and are prices going to continue trending upwards? Should I buy now or wait a few months.
Thanks!
J
Thanks!
J
