- Feb 22, 2021
- 58 (0.04/day)
Processor | Core 2 Quad Q9650 |
Motherboard | XFX nForce 780i SLI |
Cooling | Zalman |
Memory | 4x1GB Ballistix DDR2-1066 |
Video Card(s) | 2x Quadro FX 4800 |
Storage | 2x WD RE3 500GB RAID 0 |
Display(s) | Apple Cinema HD |
Case | Chieftec Dragon |
Audio Device(s) | Sound Blaster X-Fi |
Power Supply | Corsair 500W |
Software | Windows 7 Ultimate x64 |
Noticed fan was not spinning on my HD 5870 so I disassembled it and found this. It's an engineering sample (which is why I am so concerned about fixing) but I believe this area is identical to the reference model.
The issue is very obvious. capacitor... B200? Hard to see through the burn marks.
I believe this all started when I put a fishy PCI card in my PC, powered it up to test. Heard a pop, thought it was from the PCI card but now I know the source... I am experienced with soldering so I should be able to fix, I just need to know what this was. Is this capacitor something I'd be able to just remove entirely and bridge the pads with solder? Should I try to find what value it was?Maybe it's the same as C209, should I test that one and buy another of that? (or am I totally wrong and this is a resistor... but I think only a capacitor would explode this violently)
