FordGT90Concept
"I go fast!1!11!1!"
- Oct 13, 2008
- 26,263 (4.30/day)
- IA, USA
System Name | BY-2021 |
Processor | AMD Ryzen 7 5800X (65w eco profile) |
Motherboard | MSI B550 Gaming Plus |
Cooling | Scythe Mugen (rev 5) |
Memory | 2 x Kingston HyperX DDR4-3200 32 GiB |
Video Card(s) | AMD Radeon RX 7900 XT |
Storage | Samsung 980 Pro, Seagate Exos X20 TB 7200 RPM |
Display(s) | Nixeus NX-EDG274K (3840x2160@144 DP) + Samsung SyncMaster 906BW (1440x900@60 HDMI-DVI) |
Case | Coolermaster HAF 932 w/ USB 3.0 5.25" bay + USB 3.2 (A+C) 3.5" bay |
Audio Device(s) | Realtek ALC1150, Micca OriGen+ |
Power Supply | Enermax Platimax 850w |
Mouse | Nixeus REVEL-X |
Keyboard | Tesoro Excalibur |
Software | Windows 10 Home 64-bit |
Benchmark Scores | Faster than the tortoise; slower than the hare. |
I can't believe something that does this isn't readily available on the internet so, I wrote it and here you go:
To use it, just call new A2S_INFO(IPEndPoint) and, if it doesn't throw an exception, it should have all the data in the class instance. If it throws an exception, you're either querying the wrong port number (usually not the game port number) or the server is unavailable.
Code:
using System;
using System.Net;
using System.Net.Sockets;
using System.IO;
using System.Text;
namespace ServerQuery
/// <summary>Adopted from Valve description: https://developer.valvesoftware.com/wiki/Server_queries#A2S_INFO </summary>
public class A2S_INFO
// \xFF\xFF\xFF\xFFTSource Engine Query\x00 because UTF-8 doesn't like to encode 0xFF
public static readonly byte[] REQUEST = new byte[] { 0xFF, 0xFF, 0xFF, 0xFF, 0x54, 0x53, 0x6F, 0x75, 0x72, 0x63, 0x65, 0x20, 0x45, 0x6E, 0x67, 0x69, 0x6E, 0x65, 0x20, 0x51, 0x75, 0x65, 0x72, 0x79, 0x00 };
#region Strong Typing Enumerators
[Flags]
public enum ExtraDataFlags : byte
GameID = 0x01,
SteamID = 0x10,
Keywords = 0x20,
Spectator = 0x40,
Port = 0x80
public enum VACFlags : byte
Unsecured = 0,
Secured = 1
public enum VisibilityFlags : byte
Public = 0,
Private = 1
public enum EnvironmentFlags : byte
Linux = 0x6C, //l
Windows = 0x77, //w
Mac = 0x6D, //m
MacOsX = 0x6F //o
public enum ServerTypeFlags : byte
Dedicated = 0x64, //d
Nondedicated = 0x6C, //l
SourceTV = 0x70 //p
#endregion
public byte Header { get; set; } // I
public byte Protocol { get; set; }
public string Name { get; set; }
public string Map { get; set; }
public string Folder { get; set; }
public string Game { get; set; }
public short ID { get; set; }
public byte Players { get; set; }
public byte MaxPlayers { get; set; }
public byte Bots { get; set; }
public ServerTypeFlags ServerType { get; set; }
public EnvironmentFlags Environment { get; set; }
public VisibilityFlags Visibility { get; set; }
public VACFlags VAC { get; set; }
public string Version { get; set; }
public ExtraDataFlags ExtraDataFlag { get; set; }
#region Extra Data Flag Members
public ulong GameID { get; set; } //0x01
public ulong SteamID { get; set; } //0x10
public string Keywords { get; set; } //0x20
public string Spectator { get; set; } //0x40
public short SpectatorPort { get; set; } //0x40
public short Port { get; set; } //0x80
#endregion
public A2S_INFO(IPEndPoint ep)
UdpClient udp = new UdpClient();
udp.Send(REQUEST, REQUEST.Length, ep);
MemoryStream ms = new MemoryStream(udp.Receive(ref ep)); // Saves the received data in a memory buffer
BinaryReader br = new BinaryReader(ms, Encoding.UTF8); // A binary reader that treats charaters as Unicode 8-bit
ms.Seek(4, SeekOrigin.Begin); // skip the 4 0xFFs
Header = br.ReadByte();
Protocol = br.ReadByte();
Name = ReadNullTerminatedString(ref br);
Map = ReadNullTerminatedString(ref br);
Folder = ReadNullTerminatedString(ref br);
Game = ReadNullTerminatedString(ref br);
ID = br.ReadInt16();
Players = br.ReadByte();
MaxPlayers = br.ReadByte();
Bots = br.ReadByte();
ServerType = (ServerTypeFlags)br.ReadByte();
Environment = (EnvironmentFlags)br.ReadByte();
Visibility = (VisibilityFlags)br.ReadByte();
VAC = (VACFlags)br.ReadByte();
Version = ReadNullTerminatedString(ref br);
ExtraDataFlag = (ExtraDataFlags)br.ReadByte();
#region These EDF readers have to be in this order because that's the way they are reported
if (ExtraDataFlag.HasFlag(ExtraDataFlags.Port))
Port = br.ReadInt16();
if (ExtraDataFlag.HasFlag(ExtraDataFlags.SteamID))
SteamID = br.ReadUInt64();
if (ExtraDataFlag.HasFlag(ExtraDataFlags.Spectator))
SpectatorPort = br.ReadInt16();
Spectator = ReadNullTerminatedString(ref br);
if (ExtraDataFlag.HasFlag(ExtraDataFlags.Keywords))
Keywords = ReadNullTerminatedString(ref br);
if (ExtraDataFlag.HasFlag(ExtraDataFlags.GameID))
GameID = br.ReadUInt64();
#endregion
br.Close();
ms.Close();
udp.Close();
/// <summary>Reads a null-terminated string into a .NET Framework compatible string.</summary>
/// <param name="input">Binary reader to pull the null-terminated string from. Make sure it is correctly positioned in the stream before calling.</param>
/// <returns>String of the same encoding as the input BinaryReader.</returns>
public static string ReadNullTerminatedString(ref BinaryReader input)
StringBuilder sb = new StringBuilder();
char read = input.ReadChar();
while (read != '\x00')
sb.Append(read);
return sb.ToString();
