[SOLVED] Help needed - PC turns ON and then OFF in a matter of seconds
23 (0.01/day)
Processor Intel Core i7 4770 @ 3.40GHz
Motherboard MSI H87-G43 GAMING (MS-7816)
Memory 16 GB DDR3
Video Card(s) MSI GTX 1060 GAMING X
Storage Samsung SSD 850 EVO 250GB, Samsung SSD 850 EVO 250GB, Samsung SSD 850 EVO 500GB, 2794GB TOSHIBA HDD
Display(s) PHILIPS 27" 144hz G-SYNC
Case MS-TECH HORNET
Audio Device(s) ASUS Xonar DGX Audio Device
Power Supply thermaltake hamburg 530w 80 plus
Mouse CORSAIR M65pro
Keyboard CORSAIR Vengeance K60
Software W10
Hello guys, i need help with a PC.
As soon as i turn it on (power button) it stays on for seconds and suddenly turns off again.
[EDIT]
the problem seems to be getting worse:
1st time it happened during windows boot
recently it was doing it during bios post messages
now it stays on for a fraction of a second and than turns off
[EDIT2]
when it truns off, it turns on again after 1 second, and than off in a fraction of a sec... let's hope it' just a mobo death loop:banghead:
Tests i already made trying to turn it on:
x) heatsink is clean from dust
a) another PSU (info below)
b) single ram stick (both, single, inverted...), another slot (dual channel 1 and 3, 2 and 4)
c) check each and every cables, unplug replug all PSU connectors
d) unplug hard drive...
e) cmos reset (jumper), + no cmos battery for minutes
f) new cmos battery
g) tested with and without GPU.
HW specifications:
CPU i7
MB Asus Z97-Pro
RAM 16 Gb Corsair (2x8GB)
Cooler Corsair Hydro Series H80i GT Liquid CPU Cooler
GPU EVGA GT 740sc
SSD Samsung 850 Evo
PSU Corsair CX750M >> alternative for test Corsair VS 650
thank you for your time, for any othe rinfo feel free to ask. i hope we can solve this together ;)
8,511 (3.22/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Have you tried using a different GPU?
23 (0.01/day)
Memory 16 GB DDR3
Case MS-TECH HORNET
Software W10
ops i miss to report the test... i tried with and without current GPU. Unplugged gpu video cable on motherboard.
2,004 (0.36/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
so then there is only the cpu + mainboard left?
23 (0.01/day)
Memory 16 GB DDR3
Case MS-TECH HORNET
Software W10
yeah....i was hoping for something i was ignoring.
i can add that this problem seems to be getting worse:
now it stays on for a fraction of a second and than turns off (before bios post beep)
1,949 (1.06/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
could it be the cpu ?
1. dried thermal compound?
2. the heatsink not sitting properly causing it to overheat and shutoff
need additional info as well, e.g how old is it? when did it start happening?
im suspecting the motherboard be the culprit if the motherboard is old, maybe a circuitry malfuction somewhere
2,004 (0.36/day)
Heart of Eutopia!
Processor 5960x
Memory 32 Viper
Storage raptors+ssd
Case open bench
Audio Device(s) onb
Mouse mx 518
if you have a friend with changeable parts yes do it-but ya already did all the steps necessary for which i salute you!
hope y can solve it quick. i had a z87 msi g43 and i hated it-my guess goes to the mb-in all my 30 years of computer i had one cpu die on me and that was my fault
23 (0.01/day)
Memory 16 GB DDR3
Case MS-TECH HORNET
Software W10
I can doublecheck it but it does the problem after a fraction of a second now...overheating requires some time i think.
So you suggest to try another MOBO and if the problem is still there...CPU. K i will set my mind on it. Let's see if anyone has other suggestions. TY both
2,004 (0.36/day)
Heart of Eutopia!
Processor 5960x
Memory 32 Viper
Storage raptors+ssd
Case open bench
Audio Device(s) onb
Mouse mx 518
yeah you seem like ya know what ya do so not much to do there except mobo or cpu.
i salute you for doing all this stuff before asking bravo bravo.
last question: is it in a case?-if yes then make the simple out of case test with just the parts ya need for boot
sorry i thought its the mobo ya got in your sig-but its a Asus Z97-Pro which should be better then the msi low end stuff i had
23 (0.01/day)
Memory 16 GB DDR3
Case MS-TECH HORNET
Software W10
i think it's 5+ years old so mobo circuitry going banana is surely a possibility...some times i hope to be Louis Rossmann 's son...and than i wake up still older and far less competent than him ;)
+ i can add that when it truns off, it turns on again after 1 second, and than off in a fraction of a sec... let's hope it' just a mobo death loop:banghead:
41,130 (6.57/day)
Clean your heatsink
8,511 (3.22/day)
Cooling In Win SR36
41,130 (6.57/day)
Heat or power
23 (0.01/day)
Memory 16 GB DDR3
Case MS-TECH HORNET
Software W10
Clean your heatsink
I did, i just forgot to write it on my trial/error list..updating
Heat or power
Power > you mean PSU ? I tested with a brand new one
Heat > mmm... is possible to generate the amount of heat you suppose in a very very short time ? the problem kicks in after pressing power button in 0,3 seconds. The machine is of with no powercable since yesterday and it still turns off after 0,3...before bios post
Deleted member 67555
If you don't see any bloated caps on the Mobo look at the flat black caps.. They have 2 solders on the bottom and 1 on the top.. Right about the middle look for brownish spots...
41,130 (6.57/day)
Pull the motherboard out, run on a non conductive surface with minimum parts, psu, motherboard, ram, keyboard, mouse, gpu/igp, monitor.
No drives
8,165 (2.21/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
No drives
Can the OP not get into the BIOS?
couple things to add while you have the system out of the case, disconnect the case front panel buttons and lights from motherboard, ensure the motherboard push buttons are not stuck "in". hold the bios button while you power on to clear CMOS.
41,130 (6.57/day)
23 (0.01/day)
Memory 16 GB DDR3
Case MS-TECH HORNET
Software W10
UPDATE:
So i decided as a last call to replace thermalpaste. Off coure is was not fresh bacuse the PC has more than 4 years of hard work behind...but the problem was another:
There are 2 cables that you must plug to the Liquid CPU cooler: A and B (you can see those in attached pictures).
A goes from Cooler to motherboard USB3 header
B goes from cooler to FANS
Anyway one or both of them was not plugged correctly. So I assume that the motherboard was turning off the moment it realized that CPU cooler was not working properly. After carefully replugging those the problem is now gone for good.
thank you guys for all your suggestions. WE did it!
PS: is there a way to update my thread with [SOLVED] on title?..i cannot edit it anymore
41,130 (6.57/day)
Motherboard manuals should specify that
181 (0.03/day)
Dyer, TN
Very first thing I do when working on a pc, laptop, or video card is redo the thermal paste, and 90% of the time was the cause of the weird stuffs a going on. I change my paste every year, and thermal conductive pads every 2 years or so for you can buy new ones of them, if you didnt know. In doing this as a rule of thumb, my pc's will chug along year after year, and even more years after that when my son inherits my old hardware as I upgrade to newer stuff running my old stuff for another 4-5 years with not a single problem. And knocking on wood, doing it this way, I have yet to have to replace ANY hardware because of a failure in ANY of the systems I have built in the 20+ years I been working and building computers, for I have people bring me their stuff back every year to do a fresh reinstall of windows, and upkeep of their stuff for them.
Ayhamhamadeh
1 (0.00/day)
Hey, I had same problem and wanted to mention that I also fixed it by changing the CPU-Cooler. I didn't know that without cooler the CPU will get too hot in 1 sec....
Anyway thank you for your updates.
Vikum112233
1 (1.00/day)
[EDIT]
[EDIT2]
f) new cmos battery
HW specifications:
CPU i7
MB Asus Z97-Pro
GPU EVGA GT 740sc
SSD Samsung 850 Evo
hellow i had the same issue after so many decades i have found the error. the mother board has dual bios once you remove the cmos battery it only clear one path. you need to manually trigger the jumper near front buttons port. after clearing both paths my PC have come back to normal. hope this will help somebody. Thanks
