[Solved]My 32Gb Transcend USB flash drive goes worrisome!
202 (0.04/day)
lol
System Name BrighTaloN
Processor 980X
Motherboard DX58SO2
Cooling Corsair H100 dual cougar 12cm pwm fans
Memory CMZ16GX3M4X1600C9G
Case Haf X
Power Supply Toughpower Grand 750
Software 7 Proff 64-bit
Benchmark Scores never did atm
The thumb drive used to work just fine for over three years of moderate use and now it has started to show these worrying symptoms as follows:
Following is the pic of the transcend flash drive I'm referring to in case anyone wonders which model, I hope it's not beyond recognition yet:
It takes forever for every system to detect the flash drive(H:) while slowing the system down at the same time :(
whenever it seems like it has settled down and stable, it would go back through the long detection process all over again when I try to open the flash drive (drive (H:)) to access the files stored in it.
Eventually it would just lead to some minor to major system lock-ups/freezes that could either require you to force-pull the flash drive off your system or press the physical reset button.
What concerns me most here is the fact that there are some very important family photos stored in it and I really can't afford to lose them just like that and since I've been out of stable work for to long already, paying for Data Recovery Services isn't really an option for me right now, yes it's that sad :(
I hope somebody would help me out with this, thank you so much in advance!
Jatheon
22 (0.01/day)
Did you try to go to Device Manager, right-click the USB drive in the Disk drives category, then select Properties, switch to Policies tab, and choose "Optimize for performance". Click OK to keep it.
silentbogo
5,534 (1.39/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
There could be few reasons why it freezes:
1) Flash memory failure
2) Controller failure
You can check the first one by running a complete test with something like a Flash Drive Tester
http://www.vconsole.com/client/?page=page&id=13
Just remember that it will destroy all data during the testing process
The second one is much harder to diagnose, but it is the main reason of flash drive premature deaths.
I have a couple of Kingston DataTraveler sticks that no longer work due to USB controller malfunction (don't even register with a PC anymore)
You can also try and boot under Linux, or find a tool to make a raw file system dump, then recover your data from the image.
P.S. Did you try to connect this flash drive to another PC/Laptop? Did it show the same symptoms?
SuperSoph_WD
WD Rep
128 (0.03/day)
Wherever help is needed!
Hey, @vziera!
@silentbogo mentioned some pretty awesome suggestions you can tackle to resolve the issue, or at least to recover your family photos.
You can try using some other third-party data recovery software as well, but that'd be at your own risk. Unfortunately, if the flash drive's storage chips are corrupted , you'd need to turn to a professional data recovery company for help whether you like it or not. :(
Either way, you shouldn't have saved any important files there. Flash drives are best regarded as a short-term storage solution, they are handy but it's never safe to store essential docs or any other files for that matter, without having a copy of them elsewhere.
Although, I guess you could also attempt retrieving the files using a Ubuntu CD, since the USB drive is recognized but not accessed through Windows.
Hope this helps. Best of luck!
SuperSoph_WD
202 (0.04/day)
lol
Processor 980X
Motherboard DX58SO2
Case Haf X
@Jatheon No luck bro, not responding here and there still :(
@silentbogo @SuperSoph_WD I've tried to connect this flash drive to several other healthy computers at home and at a neighbor's, they all showed the same exact symptoms :(
About the Ubuntu cd procedure, could you guys be more specific about how to do it? I mean could you please explain me in steps with which tools to use? Thank you so much again, your replies mean the world to me!
silentbogo
5,534 (1.39/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
Well, ubuntu would be your best bet at this point, because in Windows you'll need some trickery and additional software, while almost any Linux distro provides everything you need out of the box.
1) Create a bootable CD or USB stick with Ubuntu or any other distro of your choice
2) boot from your media and start a terminal session (start > applications > utils > terminal or simply hit CTRL+ALT+T)
3) insert your crippled USB stick and enter these commands in terminal:
Code:
sudo su
umount /dev/sdx
apt-get update
apt-get install gddrescue
ddrescue /dev/sdx ~/backup.img ~/backup.log
sync
/dev/sdx should be your USB drive device (e.g. /dev/sdb, /dev/sdc etc.)
~/ is your home directory short path (full path is usually /home/username/)
This sequence will elevate your privileges to superuser, unmount the flash drive(if it was previously mounted), install a gddrescue package and finally create an exact image of your flash drive and ignore all read errors.
as a result you'll have 2 files in your home directory: backup.img - the flash drive image, and backup.log - a log file, containing the info about backup process.
You can later mount the image just as any other storage device, or write it to another flash drive.
3,175 (0.53/day)
Brockport, NY
System Name Is rly gud
Processor Intel Core i5 11600kf
Motherboard Asus Prime Z590-V ATX
Memory (48GB total) 16GB (2x8GB) Crucial Ballistix Sport 3000MHZ and G. Skill Ripjaws 32GB 3200MHZ (2x16GB)
Video Card(s) GIGABYTE RTX 3060 12GB
Storage 1TB MSI Spatium M370 NVMe M.2 SSD
Display(s) 32" Viewsonic 4k, 34" Samsung 3440x1440, XP Pen Creative Pro 13.3
Power Supply EVGA 600 80+ Gold
VR HMD Meta Quest Pro, Tundra Trackers
Does this flash drive have a lock switch on it? I used to have a drive in high school that would act like this until I noticed there was I guess a write protect switch. It did this kind of stuff with the switch on. Might be a long shot.
911 (0.23/day)
System Name BlueKnight
Processor Intel Celeron G1610 @ 2.60GHz
Motherboard Gigabyte GA-H61M-S2PH (rev. 1.0)
Memory 1x 4GB DDR3 @ 1333MHz (Kingston KVR13N9S8/4)
Video Card(s) Onboard
Storage 1x 160GB (Western Digital WD1600AAJS-75M0A0)
Display(s) 1x 20" 1600x900 (PHILIPS 200VW9FBJ/78)
Case μATX Case (Generic)
Power Supply 300W (Generic)
Software Debian GNU/Linux 8.7 (jessie)
It is probably dying (or dead).
I know it is not the answer you would like to hear but you cannot simply trust flash drives so much. When they die they simply "puff".
If you think it is a problem caused by Windows... Try to plug it on a different operating system, or even a different computer. If the problem persists it is probably a problem with flash drive itself.
Backup. Sad you are learning it the hard way. :(
202 (0.04/day)
lol
Processor 980X
Motherboard DX58SO2
Case Haf X
@silentbogo The Ubuntu procedure unbelievably worked like a charm, I've got the photos back!!! Thank you ever so much, God bless you sir bro!!!
@zithe @Blue-Knight @SuperSoph_WD @Jatheon @silentbogo Thanks a lot for visiting this thread, God bless you all!!! Let me know if you guys have any problems and I'll do what I can to help! :'D
Take care and have a nice day!
silentbogo
5,534 (1.39/day)
Kyiv, Ukraine
System Name WS#1337
Mouse Logitech G603
You're welcome!
2,350 (0.51/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
Many usb thumb drives are unbelievably cheap, and ticking time bombs.
I've bought new thumb drives that when written with random data, return the same data with a few bits flipped. Brand new!
2,334 (0.45/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
202 (0.04/day)
lol
Processor 980X
Motherboard DX58SO2
Case Haf X
SuperSoph_WD
WD Rep
128 (0.03/day)
I'm glad to see you so happy with your family photos back!
Make sure you have such files backed up on at least two different locations in the future. This way you'd save yourself the devastating headaches of data loss!
Take care & best of luck, @vziera! :)
