[SOLVED] Thermal Grizzly Kryonaut PSA (nasty scratching)
Status
Not open for further replies.
387 (0.07/day)
Processor i7 8700K
Motherboard MSI Z370 Gaming Plus
Cooling Noctua NH-D15S + NF-A12x25 PWM + 4xNF-A14 PWM
Memory 16 GB Adata XPG Dazzle DDR4 3000 MHz CL16
Video Card(s) Gigabyte GTX 1070 Ti Gaming 8G
Storage Samsung 970 EVO Plus, Samsung 850 Evo
Display(s) Samsung C24FG73 144Hz 1080p
Case Fractal Design Meshify C
Audio Device(s) Steelseries Arctis 3
Power Supply Superflower Leadex II Gold 650W
Mouse Steelseries Rival 600
Keyboard Steelseries Apex 7
EDIT: matter is fully settled amicably, with the help of the very good @Thermal-Grizzly support.
What can I say. Pay premium price, get premium scratching on both IHS and coldplate. Delidded my 8700K, only to find out what just 3 days of Kryonaut did to my D15S and the top of the IHS. Good thing I didn't put it on the die itself. The IHS was in pristine condition for almost 2 years of heavy use, mostly with Arctic MX3 and later Noctua NTH1. Kryonaut fixed the good looks.
You can see the clean IHS before the Kryonaut. I wish people would stop advertising this so hard. replaced it with NTH1 and temps are same, and it's far cheaper and not scratching anything. Quite sad.
Solaris17
Super Dainty Moderator
26,176 (3.80/day)
Alabama
System Name Rocinante
Processor I9 14900KS
Motherboard MSI MPG Z790I Edge WiFi Gaming
Cooling be quiet! Pure Loop 240mm
Memory 64GB Gskill Trident Z5 DDR5 6000 @6400
Storage 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400
Display(s) Odyssey OLED G9 (G95SC)
Case LANCOOL 205M MESH Snow
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Power Supply ASUS ROG Loki SFX-L 1000W
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
Software openSUSE Tumbleweed
Odd, iv never had that.
387 (0.07/day)
Processor i7 8700K
40,435 (6.52/day)
387 (0.07/day)
Processor i7 8700K
Atleast its not conductonaut which corrodes
I used that on the die itself. It already started to interact with the back of the IHS, but that was expected. It's one thing to know that what you will do has specific adverse reactions, and another to expect a normal TIM application and to get scratching.
Oh and neither acetone or isopropylic alcohol can clean that. Luckily, temps seem fully normal, but I have to say, it looks like crap, both the IHS and the coldplate.
4,213 (0.74/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
Urgh . . . I have some on my 1080Ti, but I've been meaning to replace it with MX-4 anyway.
It is by far the worst thermal compound I've ever worked with. Out of a 1g tube, I got 1 GPU application, with enough left over for another 1/2 an application. Most of what you put on top a surface gets wasted by it being impossible to spread evenly and thinly.
I really hope my GPU die is not scratched up.
387 (0.07/day)
Processor i7 8700K
Only one way to find out. Tear it down and post some pics maybe?
In my case, noctua nth1 seems to both spread better and give a bit better temps.
20,949 (3.40/day)
System Name Pioneer
Processor Ryzen R9 7950X
Case Thermaltake Core X31
Me neither, and I've put that stuff nearly literally everywhere.
Still I'm using MX-4 as of late for paste applications. Cost reasons.
Mussels
Freshwater Moderator
58,413 (8.11/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Oof, hadn't heard of this happening with kryonaut either
I use conductonaut for the high heat stuff and MX4 for everything else
799 (0.45/day)
Processor Intel i9 13900KS 6.2GHz/Allcore5.9
Motherboard z790 Apex
Cooling LT720 360mm + Phanteks T30
Memory 32GB @8000MT/s CL36
Video Card(s) RTX 4090
Storage 990 PRO 2TB / Firecuda 530 2TB
Display(s) Neo G8 / C1 65"
Case Antec Performance 1
Power Supply Prime Ultra Titanium 1000w
Mouse Scimitar Pro
Keyboard K95 Platinum
I ended up applying kryonaut 5-6 times on a 3900x (motherboard issues, trying to figure things out before RMAing the board) and not a single scratch. Could be some defective batch(es) out there.
87 (0.04/day)
System Name Shiny Beast 2.0
Processor AMD Ryzen 9 5950x
Cooling Corsair H150i Elite Capillex
Memory 32GB G.Skill Trident Z RGB 3600Mhz CL17
Video Card(s) Asus Strix RTX 3090 OC
Storage Samsung 980 Pro 1TB, Samsung 970 Evo 1TB, Samsung 860 Evo 1TB, Crucial MX500 2TB, WD Black 2TB
Display(s) Asus PG35VQ 3440x1440 200Hz GSync
Case Corsair 500D SE RGB
Audio Device(s) Logitech Z906
Power Supply Corsair HX1000 Platinum
Mouse SteelSeries Rival 600
Keyboard Logitech K750
Never seen anything like that on my 6700k that had it´s coolers swapped three times, each time with Kryonaut. Neither on the coolers base plates.
Same goes for my current 9900k and 3900x and both of their Corsair AiO´s.
Spreading it though is a pain
116 (0.03/day)
System Name Grand Aniki
Processor Ryzen 7 1700X
Motherboard AsRock B450m Pro4
Cooling Phanteks PH-TC14PE
Memory GSkill FlareX 16 GB 3200MHz
Video Card(s) Asus DUAL RX 480 8 GB
Storage Seagate Barracuda 1 TB, WD Blue 3 TB, Kingston HyperX Savage 240 GB
Display(s) Dell U2515H & Zowie XL2411P
Case Fractal Design Define R4
Audio Device(s) Asus Xonar DGX
Power Supply Cooler Master V750 SM
Keyboard Cooler master Masterkeys Pro M
Repasted my RX 480 2 times and my 1700x 3 times with some Kryonaut. Haven't gotten any scratching either.
18,239 (2.70/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
I also use Thermal Grizzly Kryonaut, never seen this before.
513 (0.18/day)
System Name Gaming PC / I7 XEON
Processor I7 4790K @stock / XEON W3680 @ stock
Motherboard Asus Z97 MAXIMUS VII FORMULA / GIGABYTE X58 UD7
Cooling X61 Kraken / X61 Kraken
Memory 32gb Vengeance 2133 Mhz / 24b Corsair XMS3 1600 Mhz
Video Card(s) Gainward GLH 1080 / MSI Gaming X Radeon RX480 8 GB
Storage Samsung EVO 850 500gb ,3 tb seagate, 2 samsung 1tb in raid 0 / Kingdian 240 gb, megaraid SAS 9341-8
Display(s) 2 BENQ 27" GL2706PQ / Dell UP2716D LCD Monitor 27 "
Case Corsair Graphite Series 780T / Corsair Obsidian 750 D
Audio Device(s) ON BOARD / ON BOARD
Power Supply Sapphire Pure 950w / Corsair RMI 750w
Mouse Steelseries Sesnsei / Steelseries Sensei raw
Keyboard Razer BlackWidow Chroma / Razer BlackWidow Chroma
Software Windows 1064bit PRO / Windows 1064bit PRO
i dont think a thermalpast can do that kind of damage
19,366 (3.66/day)
It can.. but typically it is the the ones with diamond in them where this happens
I've used this for years including multiple mounts on the same CPU and didn't have this issue.
Seems common. I wish I found that before buying it.
google for kryonaut scratching
You can google just about anything...
That said, how are there large (long) scratches when the thing stays in the same place the whole time? I'm wondering how you managed to get such large and LINEAR scratches across the IHS by simply mounting the thing. It doesn't really look like a paste and mounting thing to me...........typically that is pitting or much smaller length scratches. How you managed to make large scratches on the entire IHS/cold plate I have no idea. (looks like a cleaning thing to me).
EDIT: Worth reading - http://forum.notebookreview.com/thr...-properties-and-high-temp-degradation.829823/
Shows that they admitted to one bad batch back in the day... but this clearly isn't something that needs a PSA/sounding the alarm it seems.
EDIT2: support@thermal-grizzly.com
Email them.
1,908 (0.35/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
with what stuff do ya clean it?
freeagent
7,871 (3.73/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I agree with ED, those scratches are pretty long. For cleaning I use 99% isopropyl alcohol and a cloth. Everything comes off in a swipe. That's brutal.
5,801 (2.97/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Have you tried to contact them about it?
FreedomEclipse
~Technological Technocrat~
23,497 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
You obviously werent around during the IC Diamond fiasco on TPU so i'll leave these here for you
We even had the company CEO trying to bury the evidence. He had peoples damaged coolers sent to them for analysis then claimed they got lost in the mail or they never received them when their deliveries had been signed for by members of staff as proof of delivery.
2,649 (0.69/day)
Alabama
Processor Ryzen 2700X
Cooling Scythe Big Shuriken 3
Memory C.R.S.
Video Card(s) Radeon VII
Software Win 7
I can believe it, all that went down just before my time here.
The abrasive quality of diamond dust vs whatever is obvious, diamond is about the hardest substance on earth and even in dust form will scratch things up like a pasty form of sandpaper.
That's why I don't, won't or ever will use it in any form for anything.
19,366 (3.66/day)
Right...buuuut... this isn't a diamond based product AFAIK...
387 (0.07/day)
Processor i7 8700K
Sent them an email yesterday. Luckily I kept the bag in which the tube came, which has a serial number, so maybe they can take out of circulation further defective batches.
They include a plastic "spreader" with the tube, so I spread it with that. I assume that contributed. The spreader is really soft though, you can't scratch metal with it if you try as hard as possible, even with the edge (tried it now). So when the messed up paste is spread, I think it creates those traces, and because they're covered in paste, you don't see it until you clean it.
As for the cleaning, about which somebody asked for, I don't think it's possible without lapping. I tried 99% isopropylic alcohol and acetone solutions, and neither worked.
The PSA is necessary, as it's clear that TG still has bad batches in circulation. Mine is bought in Nov 2019. If you buy Kryonaut you gamble with the IHS and coldplate.
422 (0.10/day)
Hungary
System Name masina
Processor AMD Ryzen 5 3600
Motherboard ASUS TUF B550M
Cooling Scythe Kabuto 3 + Arctic BioniX P120 fan
Memory 16GB (2x8) DDR4-3200 CL16 Crucial Ballistix
Video Card(s) Radeon Pro WX 2100 2GB
Storage 500GB Crucial MX500, 640GB WD Black
Display(s) AOC C24G1
Case SilentiumPC AT6V
Power Supply Seasonic Focus GX 650W
Mouse Logitech G203
Keyboard Cooler Master MasterKeys L PBT
...one thing has not been mentioned yet. [putsontinfoilhat] Counterfeit product.
Couple of years back we had fake Arctic MX-4 circulating the dealers, it even penetrated some brick and mortar stores... :(
387 (0.07/day)
Processor i7 8700K
I have some doubts this was counterfeited, doesn't seem to be worth the effort to create this sort of packaging, with spreader and I think even a small leaflet guide inside. My purchase was from Aqua Computer, Germany, together with Conductonaut and a delid tool. The Conductonaut also came in properly packaged and sealed. All products have an invoice too.
19,366 (3.66/day)
How does spreading it (with presumably such little pressure) scratch a metal IHS? It takes some significant pressure to scuff an IHS up like that. Also, similar patterns on are on the IHS, did you (for some reason) apply the product to the base of the heatsink too???? Things aren't adding up. I believe you may have a bad sample, but typically you see pitting or much smaller length scuffing. On the HIS we see long arse scratches going in opposite directions even...
If this is gambling, I will take those odds any day...................thanks for the heads up and all, but I'll continue to take my chances (and win) :). Sorry this happened though. Keep us posted on how they respond. :)
Status
