Sound Blaster AE-5 vs onboard audio
3,256 (0.58/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Cooling Noctua NH-U14S
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) AMD Radeon RX 6600
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) HP Z Display Z24i G2
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
I've had Sound Blaster AE-5 card for several years now. I have been using various Creative cards for decades, always simply buying a newer model every few years when I got an upgrade itch.
I have recently been questioning whether I need the card at all with onboard sound probably improving since 20 years ago or so.
My setup is BIG stereo speakers and an integrated amp on the desk, and I run the Sound Blaster in direct mode. I just like my music to sound good. I'm a boomer and listen to FLACs stored on the PC :D
The onboard sound chip on my Asus B550 motherboard is something from Realtek the Asus website describes as "Realtek ALC S1200A". I have no idea what exactly that is, and there are hardly any results about it on Google (that specific model).
Can anyone who knows something about audio tell me whether the Sound Blaster card is supposed to sound noticeably better considering my setup or whether there should be hardly any difference? I wouldn't mind ditching a card from the PC, leaving room for more airflow or whatever. I just like minimalism, heh.
27 (0.01/day)
System Name HP Z6 G4
Processor 2X Xeon Gold 6268CL
Motherboard HP 81C6
Memory 2048GB Optane DCPMM + 512GB ECC DDR4 2666
Video Card(s) NVIDIA RTX A5000 + AMD W6600
Storage 2X Optane 905P 960GB + 2X Seagate MACH.2 2X18 18TB
Display(s) Dell G3223Q
Audio Device(s) M-Audio Profire 610
Power Supply 1000W
Mouse Razer Naga
Keyboard Keychron Q4
Software Debian 12
In my experience, motherboard integrated audio tends to have a very bad signal to noise ratio.
What this means is you’re more prone to hearing undesirable electronic chirps and hums or white noise, especially through amplified speakers. This can be very distracting. Discrete sound cards and external DACs usually advertise a signal to noise ratio >120db (bigger number means more “signal” relative to “noise”).
If you want to ditch the card, an external/USB DAC like a MOTU M2 (or M4, depending on how many channels you want) would give you a similar or better signal to noise ratio. There are numerous options from Focusrite, Universal Audio, Presonus, etc.
Part of the SoundBlaster value add is their software suite of equalizer tools, bass boost, crystalizer, etc. although all these effects can be duplicated with other software like FXSound.
A friend of mine who used a B550 board said the onboard audio was “flat” and “lacked stereo separation.” I never listened to the system, so I can’t quantify it more than that.
As always the best test is to listen with your own ears!
43,061 (6.72/day)
Onboard audio is a value added function, keep the sound card you have.
Back when people used teamspeak, i used my sound card for game audio with speakers and the onboard for voice comm on a headset wrapped around my neck.
3,855 (1.33/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
When audio output is analog then obviously DAC matters a lot.
What about digital output? Is there a benefit from discrete audio card when sound output is something like optical or HDMI? Or would that depend on the DAC in whatever receives the signal - how do these fare against ones in discrete audio cards?
103 (0.25/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative P580 speakers, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
I tried my setup on both onboard and SB because of you. My Sennheiser screamed for help and my 5.1 demanded a raise in salary.
Jokes aside, stay with the AE-5.
My 2c.
3,256 (0.58/day)
Czech republic
It sounds the same. Or so it seems to my ears. I removed the card from the PC and will sell it. The large beefy speakers are what makes the sound quality anyway, not some theoretical small differences in numbers in specs.
I used the SB in direct mode anyway, so any hypothetical extra value from software was useless anyway.
I've been using Sound Blaster cards for probably 25 years and never used any onboard sound in all the time, but if the claims about horrible sound quality you keep finding on the internet are true, something good must have happened in the recent years, because aside from slightly lower volume, music sounds exactly the same between the two sources.
I might eventually buy a standalone DAC, the Schiit Bifrost 2, but only because of the claimed noise cancellation circuitry or whatever it is - basically the damn noise you can hear when you pump volume up significantly. I could never make it disappear with any components, and few years ago I tried changing just about everything, and nothing helped.
103 (0.25/day)
VR HMD none
Software W11 pro
Whatever suits your ears.
