SoundBlaster AE-5 pure edition + LogitechZ906 + Cable SPDIF
Methodman777
4 (0.00/day)
Good Morning ,
I need help for to resolve my problem : you are the experts
I have :
-- > Mothercard : MSI Z390 gaming Pro
--> Soundcard : Soundblaster AE-5 Pure Edition
--> Speakers : Kit Logitech Z906 ( DTS , dolby , 5.1 )
Software : SoundBlaster command
So , i have connected Soundcard and Kit logitech with cable SPDIF
My problem is : when i configure in soundbalster command for SPDIF , the software need to active my Microhpone for use SPDIF , ok i active this and when i make a test : i listen all the speakers separatly , it is good BUT when i would listen a simple mp3 , only speakers right and left FRONT works !!!
and if i try to change a configuration with speaker ( default ) : i have all speaker works but it is not 5.1 ( dts )
I don't no why ?
if you have a solution , or tell me how i must to configure for to have DTS 5.1 works
Thank you so much for your help
Regeneration
NGOHQ.COM
3,090 (0.45/day)
Music comes in stereo (2 channels), to expand it to 5 speakers, you need to increase the surround spectrum in SoundBlaster Command or in the media player.
Methodman777
4 (0.00/day)
Thank you for your help but how ? to increase ? sorru but i don't really undestand how
Regeneration
NGOHQ.COM
3,090 (0.45/day)
If it doesn't work, try doing it on the media player. Fo example, foobar2000 has convert stereo to surround DSP.
Methodman777
4 (0.00/day)
Thank you so much , i will try to this and i will told you , if it is good or not
I have try with foobar2000 , yes it is works with all speakers but it is not a DTS ( this just upmix 5.1 ) , i can't use dts neo:pc mode ( movie or music )
may be , have you a another solution ? thank you so much
Regeneration
NGOHQ.COM
3,090 (0.45/day)
The source isn't DTS and therefore the output isn't neither.
Try VLC with HDMI/SPDIF audio passthrough on. But take in mind that encoding MP3s to DTS will not improve the quality.
