Sparkle Calibre P960 - GeForce 9600GT 512MB with Dual Fly Cooling
malware
5,422 (0.74/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
Sparkle Computer has introduced a non-reference GeForce 9600GT using a new Dual Fly cooling. The card comes factory overclocked with a core running at 700MHz, 1850MHz shader clock and 512MB GDDR3 memory at 2.0GHz using 256-bit memory interface. The most interesting part is the cooler though. According to the company's PR "This high-efficient Cooling System developed by SPARKLE itself consists of aluminum die-casting thermal base with copper core inside, three high-efficient heat pipes and dual cooling fans with 0.2 mm thin cooling fins. When the GPU starts working, the copper core inside the aluminum die-casting thermal base will quickly take the working heat from the GPU to the heat-pipe horizontally put inside the thermal base, and the heat will be equably and rapidly spread to the left part and right part of the aluminum die-casting thermal base, at same time, the two circular heat pipes also quickly bring the heat from GPU to the 0.2 mm thin cooling fins, now the strong wind pressure and airflow made by two cooling fans take all the heat out of the cooling module." The actual gain from Dual Fly is up to 10°C cooler GPU, 5°C cooler case temperature and less noise (around 29dB). The Calibre P960 is expected to be available soon.
Cold Storm
Battosai
15,010 (2.40/day)
In a library somewhere on this earth
System Name Haro
Processor AMD 1700x
Motherboard AsRork x370 Taichi
Cooling EK Custom Loop - CPU only
Memory 32gb G-Skill Trident Z
Video Card(s) EVGA 1080 Superclock 2
Storage Too Many
Display(s) Viewsonic VX2450WM-LED 24" & LG 32 IPS
Case Cooler Master Cosmos II
Mouse SteelSeries Rival 500
Software Win10 Pro
Benchmark Scores i5 750 4.62ghz pi runs // Evga FTW p55
that cooler is sick! I can't wait for one of us to get it and take some pictures! The gain on temps is even something to brag about
alexp999
Staff
8,012 (1.27/day)
Dorset, UK
System Name Gaming Rig | Uni Laptop
Processor Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz
Motherboard ASUS P5Q Deluxe (Intel P45) | HP 6715b
Cooling Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans
Memory 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz
Video Card(s) XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250
Storage 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5"
Display(s) Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution)
Case Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000
Audio Device(s) Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio
Power Supply Corsair TX650W | HP 90W
Software Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64
Benchmark Scores 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0
That is one nice looking Graphics card. Only thing I cant get over with these though is where they are sending all the heat?? They will perform amazing on a workbench, but once inside the PC... it could be a royal PAI. "coolers" arent actually cooling the graphics card, they are moving the heat off the graphics card, but that heat has gotta go somewhere!
310 (0.05/day)
Processor AMD Ryzen R7 3900X
Motherboard Gigabyte X570 Asrock X570 Taichi
Cooling 2x LL140, 4x LL120 / bequiet! Dark Rock 4
Memory 32GB Corsair Vengence RGB DDR4 (3600 Mhz)
Video Card(s) Red Devil 5700XT
Storage x1 Inland 1TB Nvme, 1x Samsung 860 EVO 1TB, 1x WD 1TB, 1x Crucial MX500 500GB, 1x Sandisk X400 256GB
Display(s) Samsung C32H711
Case Fractal Design Meshify C
Keyboard Logitech G910
That is one wicked design. Kudos to Sparkle for the form/function balance.
FreedomEclipse
~Technological Technocrat~
24,006 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
1 word....
SLICK!
If you had proper ventillation inside your case you wouldnt have to worry. if your still worried & have a few power tools handy then you can mod yourself a little 80/92/120mm hole in the side of your case near the graphics card & attach a fan there to directly blow 'fresh' air on the card.
is this card still a G92 or G94??? (I think its G94)
if its a G94 it should run much cooler then G92 & the previous series - so stop panicing, you'l scare the other tpu members
jocksteeluk
1,455 (0.21/day)
The 13th room on the 13th floor of the 13th buildi
Processor custom dupont risk chip cpu prototype
Motherboard custom ibm x5 solid state carbon mainboard
Cooling industrial technologies prototype dupont custom heat transfer unit
Memory 6x 2gig prototype ecc hnc ddr4
Video Card(s) prototype low energy version nvidia 9 series unnumberd card
Storage 1tb solid state hdd
Display(s) 44 inch samsung plasma screen tv/monitor
Case custom ibm mobile home server case
Audio Device(s) custom Yamaha sound processing processor in spm format
Power Supply 1200watt deli cord custom made dupont type psu
Software sun unix/windows type v
That card will look fantastic mounted sidewards inside a windowless case, but seriously that is a nice cooling device.
1,172 (0.19/day)
UK
Processor Intel Core 2 Duo E7200 3.40GHz (400x8.5)
Motherboard Gigabyte GA-EP45-UD3P Rev 1.1
Cooling Xigmatek HDT-S1283
Memory 2x Crucial Ballistix DDR2 2GB 4:5 @ 500MHz 5-5-5-15
Video Card(s) Asus GTX 560Ti 1GB TOP Edition
Storage Crucial M4 128GB SSD + WD Black 500GB WD5001AALS
Display(s) Samsung P2370HD @ 1920x1080 60Hz
Case Antec 300
Audio Device(s) Soundblaster Live! 24-bit w/ Creative Inspire T6060 5.1 200W
Power Supply CoolerMaster Silent Pro Gold 600w
Software Windows 7 Professional Edition SP1 64-bit
that is fcccunn mint!
WarEagleAU
Bird of Prey
10,812 (1.61/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Sparkle has been coming up with some sick cooling designs. Their TEC cooler for their GPUs is awesome!
641 (0.10/day)
Processor Intel i5 3550
Motherboard ASRock Z77 Pro4-M
Cooling Thermaltake Performer 2.0 AIO Liquid Cooler
Memory 32GB Corsair Vengeance DDR3 1600mhz
Video Card(s) EVGA GTX 960
Storage Corsair Neutron 256gb Boot drive, ~7tb storage combined on other drives
Display(s) AOC 27" 1920x1080 IPS and Wacom Cintiq 13" HD
Case Fractal Design Node 804
Audio Device(s) Realtek HD audio, Pyle Pro PTA2 Amp, Sony SS-B3000 Speakers, Sennheiser HD595 headphones
Power Supply Antec 750W "High Current Gamer"
Mouse SteelSeries Diablo 3
Keyboard Rosewill Mechanical with cherry black keys
Software Windows 7 Ultimate 64
3 words.... i want that! lol.
Mussels
Freshwater Moderator
58,413 (7.96/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
for a stock card, its quite good.
factory OC, quiet fan(s), decent temps.
Oh as for alexp999: where else will the heat go? into your case. there hasnt been an effective exhaust cooler for nvidia in a long time, even the stock coolers leave a lot of heat in the case.
11,119 (1.65/day)
System Name Apple Bite
Processor Intel I5
Motherboard Apple
Memory 40gb of DDR 4 2700
Video Card(s) ATI Radeon 500
Storage Fusion Drive 1 TB
Display(s) 27 Inch IMac late 2017
here is mine on a 8800gs
Thermaltake is gonna be pissed that looks alot like a black dual orb cooler can you say lawsuit.
Mussels
58,413 (7.96/day)
Oystralia
for all we know it is that cooler and they have permission.
If they dont, well... unless TT has a patent on it its going to be hard to protect (they arent selling it as a 3rd party cooler, only bundled with a card - that may be a good defining point)
11,119 (1.65/day)
Processor Intel I5
Motherboard Apple
its not the same but very very similar
10,693 (1.72/day)
Austin Texas
System Name Planet Espresso
Processor 13700KF @ 5.5GHZ 1.285v - 235W cap
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard 65% HE Keyboard
ok... so i posted something totally stupid, saying its the same cooler... then i sobered up a bit, and remembered 'about the lack of personal property rights in the far east'...
aaah... wow.
but this TEC cooler you speak of... is niiiise...?
DarkMatter
1,714 (0.27/day)
Processor Intel C2Q Q6600 @ Stock (for now)
Motherboard Asus P5Q-E
Cooling Proc: Scythe Mine, Graphics: Zalman VF900 Cu
Memory 4 GB (2x2GB) DDR2 Corsair Dominator 1066Mhz 5-5-5-15
Video Card(s) GigaByte 8800GT Stock Clocks: 700Mhz Core, 1700 Shader, 1940 Memory
Storage 74 GB WD Raptor 10000rpm, 2x250 GB Seagate Raid 0
Display(s) HP p1130, 21" Trinitron
Case Antec p180
Audio Device(s) Creative X-Fi PLatinum
Power Supply 700W FSP Group 85% Efficiency
Software Windows XP
Naaah... Dual fan with heatpipes. End of similarities. If we follow your logic, any brand could think of a lawsuit against others, since many CPU and GPU coolers are similar. There isn't many designs you can choose from you know...
As if Ford settled a lawsuit against Toyota because they make cars with 4 tyres and a wheel...
OnBoard
3,033 (0.46/day)
Finland
Processor Core i5-750 @ 3.6GHz 1.136V 24/7
Motherboard Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby!
Cooling Alpenföhn Brocken HeatpipeDirectTouch
Memory Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24
Video Card(s) Gigabyte GTX 460 1GB OC (mostly stock speeds)
Storage OS: Samsung F3 500GB Games: Samsung F1 640GB
Display(s) new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD
Case new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans
Audio Device(s) new! ASUS Xonar DG & JVC HA-RX700 headphones
Power Supply Cougar CM 700W Modular
Benchmark Scores Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging
Sexy and seems it has an integrated memory"sink" underneath it. Stock coolers that you don't have to upgrade are sweet, like my Zalman PWM one :)
746 (0.12/day)
This graphics card is AWESOME! :rockout:
FreedomEclipse: it's a G94 indeed. ;)
47,189 (7.56/day)
Funny how board-vendors are churning out so much innovation into making a mid-range card look elite and sell well. But yes, it's a rat race and the reference cooler from NVidia, to me looks not very sufficient for people who would be buying these cards and OC'ing the hell out of them. eVGA and BFG Tech still sell high-clocked 9600 GT cards with reference PCB/cooler.
This card looks pretty, I like the black PCB and that they chose the chrome coloured cooler which would give this card an industrial look. It's time that more board vendors take to 1 GB memory as a USP instead of OC+better cooler. With the prices of memory on the fall, it would make a sweet (and relatively inexpensive) option of 1 GB memory.
3,278 (0.49/day)
UK-small Village in a Valley Near Newcastle
Processor I9 9900KS @ 5.3Ghz
Motherboard Gagabyte z390 Aorus Ultra
Cooling Nexxxos Nova 1080 + 360 rad
Memory 32Gb Crucial Balliastix RGB 4.4GHz
Video Card(s) MSI Gaming X Trio RTX 3090 (Bios and Shunt Modded) 2.17GHz @ 38C
Storage NVME / SSD RAID arrays
Display(s) 38" LG 38GN950-B, 27" BENQ XL2730Z 144hz 1440p, Samsung 27" 3D 1440p
Case Thermaltake Core series
Power Supply 1.6Kw Silverstone
Mouse Roccat Kone EMP
Keyboard Corsair Viper Mechanical
that is one decent looking cooler ;)
1,172 (0.19/day)
UK
Case Antec 300
