speaker unplugged ...???
24 (0.01/day)
reunion island
System Name windows 8.1 pro 64 bit
Processor amd fx 9590 black edition ( 5.0 ghz)
Motherboard crosshair V fomrula z
Cooling corasir h 100i
Memory 4*4 go g skills 1333mhz
Video Card(s) SLI zotac 660 ti amp extrem
Storage 1 ssd 250 go + 2* 2to hdd
Display(s) philips FLT 107 CM (hdmi) + AOC 22 pouce (dvi)
Case helios prophecy
Audio Device(s) asus xonar phoebus
Power Supply thermaltake 1200 w
hello. after a reboot of the Computer, I no longer had sound coming out of my speaker, I unplugged and reconnected, I test on the front out, I reinstalled the audio driver to date, then (can be a cause of despair) I reinstall windows 8.1, I do all the updating I reconfiguer the driver as he was when my speaker worked and always shows me unplugged while my speaker are connected . I also test my speaker on my phone and it works. the sound card is it burning? thank you in advance
Kursah
Super Moderator
14,733 (2.21/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
Sounds like you may have an output issue. When you go into control panel > audio What is the default device selected? Are you using onboard audio or a dedicated sound card? You have sweex in your system specs and I don't know what that is...
You tested the front out...and? Did it work? Did it not? Try listing what you've tried and success/fail, work/don't work, etc. It will be more helpful for you and everyone that assists you.
You re-installed the OS and it still doesn't work? Was it a format and install?
Have you checked to see if there was a BIOS glitch that reset a specific setting pertaining to the audio device?
24 (0.01/day)
reunion island
hello . audio in the peripheral default is " philips flt " I previously used a sound card sweex but I gave a friend then I connected to the internal sound card , then after a few months , sound came more of my speaker , I test the front output , its not working , I reinstall the audio driver, it did not work, I look at the bios, nothing has been updated so I have done a reset bios, Still its not working. then I reinstall my win 8.1 does all the update and install all the motherboard cd , its not working . installation for win 8.1 I did with the cd from the bios . jai format and re- partition. therefore I require to connect my speaker output on my tv for his work. in the control panel there s no obselete driver and I also try to research the problem on device audio and he told me " connect the speaker ." thank you for help
1,618 (0.28/day)
windows says nothing is connected when you plug in the cable or it looks fine in software but no sound comes out hardware?
maybe try changing the different default outputs as default, then disable the ones you dont use on that left window in your pic
12,333 (2.25/day)
Oregon
Keyboard EVGA / Logitech K400
Well if your speakers are plugged into your motherboard then the Realtek should be your primary sound. Somewhere in your sound properties you have selected 'Digital output" which should not be selected. Unless your using a Toshlink. But you don't give us this information
24 (0.01/day)
reunion island
windows tell me that nothing is connected while the speaker is connected, so impossible to even out the sound and turning off unnecessary device its not working. Because windows tell me that my speaker is not connected I can not set device by default
nothing plugged in the optical port I just connect the speaker on the green port on the mobo. I also disabled all the digital audio output. even when I plug in my headphones to the front output, it does not recognize
12,333 (2.25/day)
Oregon
Unplug your front header
Go to the device manager and right click on the realtek driver (Under sound) and uninstall. Then reboot
24 (0.01/day)
reunion island
I unplugged my headphones and when I want to uninstall it a window that opens and ask me if I also want to delete the device. should I do? I uninstalled without deleted, I rebooted but its still not working. it just happened that the optical audio devices that I have reactivated disabled
12,333 (2.25/day)
Oregon
Okay so first this statement made no sense.
Its about trouble shooting the problem. So follow instructions
Disconnect the front audio plug from the header on the motherboard. (It could be a short) you can put it back later
Uninstall the driver. Yes "delete the device" reboot
When you reboot windows will install the driver again in the default settings.
You should not have digital audio checked at all. Your using analog
24 (0.01/day)
reunion island
yes I know it does not make sense after reading but I do not speak English very well ... what I mean is that, after the uninstall and reboot the optical devices that I had disabled, ARE Reactivated, here is what I meant. I proceed as you said but the problem is still presentCapture016.jpg
12,333 (2.25/day)
Oregon
24 (0.01/day)
reunion island
