Spire Announces the Versis PC Chassis
4,784 (1.01/day)
Still on the East Side
Introducing the Spire Versis PC chassis series. The Spire Versis is an completely inverted chassis design, meaning that the mainboard is mounted on the left side of the case. For those who are looking for something different from the standard PC case, the Versis series are a great choice! Featuring a fresh and unique, all meshed front panel design, completely tool free drive bays, Top I/O panel with 1 * USB3.0, 1 * USB2.0 and HD/AC97 audio connectors.
The Versis is supplied with 3 pre-installed fans: 2 x 12 cm Blue LED fans installed on the front and 1 x 9 cm silent fan on the rear. Three additional 12 cm intake fans can be mounted, two on the side panel and one on the top panel. Built from strong 0.6 mm SECC steel this chassis is very robust and durable. The Versis structure design is the new standard with left side mainboard mounting for best space and air-flow / cooling optimalization. There is plenty of room for larger heavy duty (gaming) components such as large CPU cooler and 340 mm long graphic-card, offered to you by Spire - Powered by Innovation.
Main Features:
● Inverted structure for better thermal solution & easy system assembly
● Strong 0.6 mm SECC Steel structure
● Front pre-installed two 120 mm Blue LED fans
● Tool-less drive-bays and expansion slots
● Stylish and unique design for real enthusiasts
● Cool aluminum and all meshed front panel
● Water-cooling holes are pre-drilled to support water-cooling systems
● Standard ATX power supply located on the bottom of the chassis
● Supports up to 340 mm long graphic cards
● Front-Top USB2.0+USB3.0 and HD/AC'97 Audio connections
● Cable management, back panel cable routing
● Quality backed by 2 year manufacturer warranty
Compatibility:
The Spire Versis chassis series are compatible with the ATX and MICRO-ATX standard platforms.
MSRP:
USD 56.95 / EURO 44.95
Availability:
The first model of the Versis chassis series, is part # SP6015B-CE/R and is now available from our factory in Shenzhen China and will be available from our Branches starting 2nd week of September.
3,535 (0.68/day)
Netherlands
System Name ap201 | Odroid N2+ | NUC
Processor AMD Ryzen 5 3600 | Amlogic S922X | Intel Core i5-7260
Motherboard Gigabyte B550M DS3H |Odroid N2+ | NUC Board 7
Cooling Inter-Tech Argus SU-200, 3x Arctic P12 case fans | stock heatsink + fan | stock HSF
Memory Gskill Aegis DDR4 32GB | 4 GB DDR4 | 16 GB DDR4
Video Card(s) Sapphire Pulse RX 6600 (8GB) | Arm Mali G52 | Iris Plus 640
Storage SK Hynix 240GB, Sam. 840 + 850 EVO (2x (250 GB)| Samsung 850 Evo 500GB | WD Green 240 GB
Display(s) AOC G2260VWQ6 | LG 24MT57D |
Case Asus Prime 201 | Stock case (black version) | Stock case
Audio Device(s) integrated
Power Supply BeQuiet! Pure Power 11 400W | 12v barrel jack | 19V laptop brick (Asus)
Mouse Logitech G500 |Steelseries Rival 300 | no-name ergo mouse
Keyboard Qpad MK-50 (Cherry MX brown)| Blaze Keyboard
Software Windows 10, EndeavourOS | Gentoo Linux | EndeavourOS
So the PCI-e slots will end up at the top, right? Does that make any serious difference, cooling wise?
4,510 (0.90/day)
yes, take a look at review of Silverstone Tenjim TJ08-E. Also their upcoming Raven Rv-04 also has similar structure.
9,900 (1.85/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
sorry Spire, your front panel is pretty bad
3,941 (0.61/day)
Maryland
System Name HAL
Processor Core i9 14900ks @5.9-6.3
Motherboard Z790 Dark Hero
Cooling Bitspower Summit SE & (2) 360 Corsair XR7 Rads push/pull
Memory 2x 32GB (64GB) Gskill trident 6000 CL30
Video Card(s) RTX 4090 Gigagbyte gaming OC @ +200/1300
Storage (M2's) 2x Samsung 980 pro 2TB, 1xWD Black 2TB, 1x SK Hynix Platinum P41 2TB
Display(s) 65" LG OLED 120HZ
Case Lian Li dyanmic Evo11 with distro plate
Audio Device(s) Klipsh 7.1 through Sony DH790 EARC.
Power Supply Thermaltake 1350
Software Microsoft Windows 11 x64
Why have a psu at the bottom?
Heat rises last time I checked. Even just the ambient heat of the PSU casing, would cause the components above it to become hotter, I'd think.. Also, with the fan on the psu pushing air out of the sytem, it would be sucking cold air from the bottom out of the pc.. I'd rather have a top located one, sucking the hot air that rises, out of the pc.. Unless I'm missing something..
D3luSi0n4L
2 (0.00/day)
The move to bottom mounted power supplies I believe came with the addition of the PSU fan hole in the case. So you could bottom mount your power supply, have it intake from a fan hole below the powersupply and have it spit it right back out the back. This also opens up the top area for fans, radiators, etc.
3,941 (0.61/day)
Maryland
System Name HAL
Ahh so for things like water loops it should be good I guess.
Virtually all psu's "intake then spit right back out the back".. I don't see any difference there..
But as far as venting an air system, I think I'd rather have the psu mounted up top. Good to know though. Maybe I'll do a water loop someday. :)
887 (0.15/day)
Processor Intel Core i3-8100
Motherboard ASRock H370 Pro4
Cooling Cryorig M9i
Memory 16GB G.Skill Aegis DDR4-2400
Video Card(s) Gigabyte GeForce GTX 1060 WindForce OC 3GB
Storage Crucial MX500 512GB SSD
Display(s) Dell S2316M LCD
Case Fractal Design Define R4 Black Pearl
Power Supply Corsair CX600M
Mouse Logitech M500
Keyboard Lenovo KB1021 USB
This case has a top mount for a 120mm "blowhole" fan (see manufacturer's specs here). You can install a fan there for active cooling or leave it empty for passive cooling.
A power supply cranks out a fair amount of heat on its own. By moving it to the bottom, the power supply doesn't end up sucking in warm air from the case (in other words, it only has to worry about cooling itself).
5,061 (0.88/day)
Processor AMD Ryzen 5 7600
Memory Kingston Fury Beast DDR5-5600 16GBx2
Video Card(s) Gigabyte Gaming OC AMD Radeon RX 7800 XT 16GB
Storage TEAMGROUP T-Force Z440 2TB, SPower A60 2TB, SPower A55 2TB, Seagate 4TBx2
Display(s) AOC 24G2 + Xitrix WFP-2415
Case Montech Air X
Audio Device(s) Realtek onboard
Power Supply Be Quiet! Pure Power 11 FM 750W 80+ Gold
Mouse Logitech G Pro X Superlight Wireless
Keyboard Royal Kludge RK-S98 Tri-Mode RGB Mechanical Keyboard
This. With a bottom mounted PSU and its fan pointed towards the bottom of the case, it is instead getting air from outside the case, which would pass through its components and out towards the rear. No interaction whatsoever with the air inside the case except if there are some small holes in the other sides of the PSU.
In this specific case, the rear fan would handle the CPU socket area, as well as the side panel (if a fan is installed there). The top fan slot will then take care of the PCIe slots, and if you install another side panel fan, there would then be two fans in total handling the PCIe slots.
Disregarding the optional fan slots for a moment, 2 intake fans at the front and one in the rear is still good enough as a default anyway, especially in this configuration since the heat in the PCIe slots can go up through the unoccupied top fan slot.
Frick
Fishfaced Nincompoop
19,439 (2.85/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Audio Device(s) Line6 UX1 + Sony MDR-10RC, Nektar SE61 keyboard
They do, but if mounted on top they get the hot air from the CPU, mounted on the bottom they get air from outside the case, and it goes out the back. Most PSU's generally don't get that hot externally (afaik) so it's not a problem. It wouldn't be anyway, a few degrees here and there doesn't matter really (imo, I stopped caring about that years ago :p). Besides, most cases have fans at the back that blows out the air, and lots of cases have intakes on the side so I dunno what I think. It often feels like cabling is easier when they're bottom mounted. This depends on how the case is of course but still.
Anyway, drop the holes in the side and it'd be good. I kinda like that front panel, angles and stuff but no bling. If they'd lost those .. buttons or whatever it is on the 5.25 covers and made everythin black it'd almost be Batmany.
43,601 (6.52/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
No, not really. I've had a Lian Li V1000 for years that is "reverse ATX" and there is no difference in terms of cooling. The only positive.. or negative I can get out of it is it may be easier on the GPU fan... Or, it may be more stress on the fan if GPU fans are designed to run upside down.
Jacez44
35 (0.01/day)
Givatayim
System Name White Phoenix
Processor Intel i7-2600k @ 5.1Ghz (1.525v)
Motherboard Gigabyte P67A-UD7
Cooling Thermalright TRUE
Memory G.SKill 16GB DDR3-2000 CL9
Video Card(s) eVGA GTX 680 2GB
Storage Crucial M4 256GB w/12TB NAS
Display(s) 2007FP / 3007WFP / 2007FP
Case White Antec p190
Audio Device(s) X-Fi XtremeGamer
Power Supply Silverstone 1000w [Single Rail]
Software Windows 7 64-bit SP1
0.6mm steel? I have 0.5mm Aluminum that I can easily bend with my heads.
hat
Enthusiast
21,745 (3.31/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Well, steel is a good bit stronger than aluminum...
