- Oct 9, 2007
- 46,892 (7.62/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Introducing the RGB AURA FAN 3.0. X2-gaming AURA 3.0 come in fans of 3 of each 12cm RGB fans of high quality, multi-LED and multi-colored DC cooling fans for the PC gamer and enthusiast. The fan contains a speed of 1000 RPM and an appropriate 23 dB silent sound level because of installed anti-vibration pads that is wonderful when focusing on gaming without distractions. Also comes with a Big 4pin connector. This all new fan design will make a great addition to any gamer PC. By X2-Gaming - All geared up.
![](https://www.techpowerup.com/img/Ao3A1rq2tYYxmnOT_thm.jpg)
![](https://www.techpowerup.com/img/9B5rOOKF61faHQo5_thm.jpg)
![](https://www.techpowerup.com/img/K7v3hPNbuYNhHU0y_thm.jpg)
![](https://www.techpowerup.com/img/lp2lZ6cyVs05yBFf_thm.jpg)
- Product size: 120 x 120 x 25mm
- Rated Power: FAN 1.2W, LED LAMP 1.5W
- Rated Current: FAN 0.10 A, LED LAMP 0.30 A
- Fan Speed: 1000(+/-10%) RPM
- Sound level: 23 dB
- Connector: Big 4pin
- Bearing Type: Hydraulic Bearing
- 2pcs RGB ring with hand switch, single Fan in one box
