SSD overheating and underperforming
9,488 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Just bough a 480GB ADATA SU650 and something doesn't seem alright with it. I wasn't expecting it to be as fast or faster than my other 850 EVO but the speeds I am getting are even below what my HDD does. Then I noticed that the temperature of the drive is really high , around 60-64c. It just gradually gets to that temperature whether or not I even use the drive and I suspect the low performance I am getting is because the drive is throttling. The SSD is right in front of a case fan and there is absolutely no reason for it to get that hot.
So , my question is , is there something that can be done or should I just return it ?
7,412 (2.76/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
Return it IMO. Can you post a HDtune screen? Wanna see if the performance is bad from the beginning or does it slowly degrade overtime. I was actually interested in picking up one of those but I found some reviews and it looks like the drive has performance issues when copying large amounts of data, can be related to your issue.
7,412 (2.76/day)
Poland
Cooling Noctua D15S
My 850 pro's sit at 30 degrees. +60 is way too hot for a sata ssd.
I'd just get a refund to be frank,it seems like this drive is very limited. Look for WDS500G2B0A, that's an excellent price/performance drive.
Deleted member 178884
+1 to that but most sata ssds will handle 60c anything above that is a cause for concern though.
9,488 (3.27/day)
Case Phanteks NV7
60c may not be much for a drive under load but this stays at 60c all the time , even after a cold boot. Last CrystalMark test showed 170mb/s for sequential read and I didn't even bothered to let it finish , I just tried a large file transfer across the two drives and I get some abysmal speed in the order of a few mb/s , it's not that the drive has poor performance it seems outright broken, temp sensor is probably bust and makes the drive throttle. Looks like I have to return it , a rather unpleasant experience with ADATA SSDs.
671 (0.23/day)
System Name Unimatrix
Processor Intel i9-9900K @ 5.0GHz
Motherboard ASRock x390 Taichi Ultimate
Cooling Custom Loop
Memory 32GB GSkill TridentZ RGB DDR4 @ 3400MHz 14-14-14-32
Video Card(s) EVGA 2080 with Heatkiller Water Block
Storage 2x Samsung 960 Pro 512GB M.2 SSD in RAID 0, 1x WD Blue 1TB M.2 SSD
Display(s) Alienware 34" Ultrawide 3440x1440
Case CoolerMaster P500M Mesh
Keyboard Corsair K75
Benchmark Scores Really Really High
60-64C is not hot at all. Drives don't throttle till 90C+. You didn't actually post the performance you're getting but those ADATA drives are slow anyway.
7,412 (2.76/day)
Poland
Cooling Noctua D15S
It is for a sata drive,especially if he's getting such crap performance. 60 is inexcusable for such low numbers, look at mine, sits at 29 degrees under stress, just 2 degrees abovr the other 256 pro I have that is sitting at 27 in idle.
qubit
Overclocked quantum bit
17,865 (2.87/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Faulty. Return it for refund and get a better brand such as Samsung.
9,488 (3.27/day)
Case Phanteks NV7
Another odd thing is that the drive didn't show up first time I formatted it , it only showed up after a second time I did that. Thought nothing about it but I guess it was a sign something's wrong with it.
7,412 (2.76/day)
Poland
Cooling Noctua D15S
I'd replace it with a 860 evo,mx 500 or wd blue 3d.
rtwjunkie
PC Gaming Enthusiast
14,001 (2.34/day)
Louisiana
Processor Core i9-9900k
Or Crucial, or SanDisk, or Western Digital...
9,488 (3.27/day)
Case Phanteks NV7
Every review I saw for this drive shows at least 500 mb/s read speed and I am getting a third of that , as slow as these drives may be that's abnormally slow.
qubit
17,865 (2.87/day)
Quantum Well UK
Keyboard Yes
42,496 (6.66/day)
Mod it with a fansink or return it, bet anything it really doesn't use the outer case as a heatsink...
9,488 (3.27/day)
Case Phanteks NV7
Like I said the thing is right in front of a case fan running at max RPM , and it gets to 64c doing nothing. The drive is definitely throttling as I noticed that the speeds get gradually worse as temperature goes up. Going to buy a WD maybe I'll have better luck with it , thanks everyone for the help.
7,412 (2.76/day)
Poland
Cooling Noctua D15S
You can still try your luck with a replacement for the su650, but I'd just leave it and get a wd blue 3d. make sure your get the 2017 version cause it's confusing. Check the number, it's supposed to have WDS500G2B0A not WDS500G1B0A, same goes for different size (WDS250G2B0A vs WDS250G1B0A). The new one has 64-layer bics TLC, it's just as good as what they put on 860/970 evo but a bit less pricey.
https://www.wdc.com/en-ie/products/internal-ssd/wd-blue-3d-nand-sata-ssd.html#WDS250G2B0A
https://www.beslist.nl/products/r/WDS500G2B0A/
6,270 (0.91/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Yeah RMA that ADATA it is a notoriously horrible drive! Runs HOT and performance issues in way too many configs. I think eidairaman1 is correct in that the drive is faulty and not making the correct contacts under its hood. Also mentioned is the WD blue 5002B0A is a very solid dependable SSD as is the 5002B0B which is the very same drive in the M.2 platform both are an additional $30 more than the Scorching ADATA..... But i would advise an RMA for the crapola drive ADATA. RMA it for refund or store credit to be used for a real replacement. Good luck!
7,412 (2.76/day)
Poland
Cooling Noctua D15S
Or sandisk 3D, they're identical to WD blue.
2,336 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
phill
16,981 (3.44/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
Daft question at this point, but do you have a fan or anything in front of any of your SSDs or SATA drives? :)
7,412 (2.76/day)
Poland
Cooling Noctua D15S
9,488 (3.27/day)
Case Phanteks NV7
Said it twice , did you read my first post ?
@Vya Domus : If your in US see Newegg: https://www.newegg.com/Product/Product.aspx?Item=9SIA6ZP4RF0948
MX300 is a good drive, I have several.
Not in the US, thing is the drive wasn't even that cheap from where I bought it compared to others and there I was thinking It can't be crap.
Fortunately I can just return and not bother with RMA.
42,496 (6.66/day)
Yeah send it back, get a crucial mx300.
6,270 (0.91/day)
New York
Nice that a return is an option! Well i thought a little along the same lines....ADATA a company that that gained fame and popularity when it managed to make cheap ram that was overclocking like MAD, shit was the best for a minute...now i can't even remember what that ram was lol...but i was starting to think too that they were in a new form of REALLY good things but like the rest of the manufactures that have done this same call to fame it is never the case.....except for DFI who then managed to just disappear from the enthusiast market all together to fade back into OEM production....glad it's sorted tho.
