[Case Gallery] Starting a Mod
1,372 (0.21/day)
Chicago, IL
System Name Stealth 2 Duo Turbine
Processor Intel e6850 @ 3.8ghz
Motherboard Asus Striker Extreme
Cooling CoolerMaster V8 Modded With 2 white LED's & 100CFM fan
Memory OCZ DDR2 1066_ SLI Black-4GB
Video Card(s) 2xMSI 8800GT"s SLI
Storage <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB
Display(s) ACER B273HU 27" LCD 2048x1152
Case Apex SuperCase_Custom 7 month Build
Audio Device(s) Striker Extreme Add-In Card HD-Audio
Power Supply EnerMax INFINITI 720watt
Software SE7VEN ULTIMATE 64bit
Benchmark Scores 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C
Specs:
Foxconn SLI board, Intel E6850, MSI 8600GTS, 2GB of g-skill DDR2 800 or 1066 whatever score's and overclock's higher.
Mods:
Cut two 120mm holes in front of case and fiberglass two fan ducts for Turbine fans. cut mobo tray for wire management, cut 120mm in bottom of case for second SLI card to breath, Cut 140mm hole above power supply for a custom hard drive cage, Cut 120mm hole in top of case for hard drive cage, Cut 92mm fan hole in back under power supply , moved and changed power and reset switches. Still have some more mods left to do and will update as I go.
I've had this case for about 8 years and alway wanted to mod it this way, so instead of buying a new case I will go crazy on this one and see how it turns out.
MrPr3f3ct
145 (0.02/day)
Processor AMD FX-60 2.61GHz Dual Core OC'd to 2.94 GHz
Motherboard ASUS A8N32-SLI Deluxe
Cooling CPU - Zalman 7000B Cu LED
Memory 2.5 GB PC3200
Video Card(s) BFG 8800 GT OC 512MB
Storage Yeah I got one or two... Nothin' special
Display(s) MAG 22" Widescreen LCD
Case CM Stacker 830
Audio Device(s) Creative X-Fi Xtreme Gamer
Power Supply Antec Tru-Power Quattro 850
Software Win XP Pro
Hey Steelkane, nice looking mod you've got going there. I'm wondering why you didn't post this in the Project Log section of the forums? I, myself, am currently working on a case mod for my daughter. I am posting my progress in the project log. I only say this because I think it's kiind of difficult to rate the mod as it is currently incomplete. Just a suggestion....
1,372 (0.21/day)
Chicago, IL
Point taken, and I will do just that, I wasn't looking for a score just yet but just showing what I have done so far. Thanks
234 (0.04/day)
Brasil - São Paulo - São Caetano do Sul
System Name NOS
Processor Core Extreme QX6850
Motherboard Maximus Formula
Cooling VANTEC STING RAY CPU Block, 3x120mm fan's with Radiator, Seltz 1200lt/h
Memory 4GB Crucial Ballistix 1066MHz 5-5-5-15
Video Card(s) PCI-express ATI Radeon HD2900XT 1GB DDR4 512bits
Storage 5 HD's 160GB SATAII Seagate ST3860815AS 7200.10
Display(s) LG 22'' model 22LS4R
Case 3Rsystem's R810 with mod's for watercooler system
Audio Device(s) Supreme FX II
Power Supply ULTRA X3 1000W modular PSU
Software WINXP PRO SP3 x86
