- Mar 5, 2007
- 1,372 (0.21/day)
- Chicago, IL
System Name | Stealth 2 Duo Turbine |
Processor | Intel e6850 @ 3.8ghz |
Motherboard | Asus Striker Extreme |
Cooling | CoolerMaster V8 Modded With 2 white LED's & 100CFM fan |
Memory | OCZ DDR2 1066_ SLI Black-4GB |
Video Card(s) | 2xMSI 8800GT"s SLI |
Storage | <<HDD For OS>> 2x150GB_Western Digital Raptor_Raid 0. <<HDD For Storage>> 3 x 1TB |
Display(s) | ACER B273HU 27" LCD 2048x1152 |
Case | Apex SuperCase_Custom 7 month Build |
Audio Device(s) | Striker Extreme Add-In Card HD-Audio |
Power Supply | EnerMax INFINITI 720watt |
Software | SE7VEN ULTIMATE 64bit |
Benchmark Scores | 3DMark01=NTTA, 3Dmark06=NTTA 3Dmark_Vantage=NTTA, Core Temp v0.99.5=28C |
Specs:
* Asus A8N-SLi Deluxe nForce4 SLi AMD64 939 DualDDR400/Dual PCI Express/SATA150Raid/GigaLan MB
* AMD Athlon64 FX55 939 64bit 1MB Cache/ Core: SledgeHammer
Operating Frequency: 2.6GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/1MB
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 939
Multimedia Instruction: MMX, SSE, SSE2, 3DNow!, 3DNow!+
* Thermalright XP-120 with ThermalTake 120mm Smart fan
w/ Blue LED 38.6 - 93.7 CFM
* Zalman ZMNB47J Northbridge/Chipset Cooler w/40mm Fan
* G-Skill 2GB F1-3200DSU2-1GBLA (Dual channel)Memory
* 2 x BFG GeForce 6800 Ultra OC 512MB Video Card
* 2 x Western Digital 74GB 10,000rpm Serial ATA150 Raid 0
* 1 x Seagate Barracuda 7200.8 ST3400832AS 400GB
7200 RPM 8MB Cache Serial ATA150 Storage Drive
* 2 x Lite-on 16x Dual-Layer Black True 16x16 DVD+/-RW
* ENERMAX UC-9FATR2B 5.25" BLACK MULTIFUNCTIONAL
PANEL
* CoolerMaster LLC-U03 Black Musketeer 2
* Black Sony Floppy w/10"inch UV Blue round cable
* Sound Blaster Audigy 4 Pro w/External I/O Hub with infrared receiver
* Thermaltake Tsunami VA3000BWA Case
* PC Power & Cooling’s Turbo-Cool 850 SSI PowerSupply
* Three 10"inch UV Blue SATA cables Two 10"inch UV blue Round IDE cables
* Two Evercool 120mm 4 LED Aluminum Fan - BLUE 79.14 CFM/36 dBA
# CRYSTAL QUAD 92X25MM BLUE 4 LED FAN 48.1CFM 34.5DBA Installed
on side window Enermax security screw set for The PC case, Power supply, motherboard, and PCI Slots
# One THERMALTAKE CL-C0001 TRUELIGHT MEMORY HEAT SPREADER
KIT Up to 8 Different lighting modes # Three high performance DDR heat
spreader from 3M is made from T6061 aluminum for excellent heat dissipation
# ARCTIC SILVER 5 THERMAL COMPOUND was used to Install CPU HeatSink
& ChipSet HeatSink
# 3.5" Drive Bay Controller for the lights on the CoolerMaster Black Musketeer 2 & THERMALTAKE heat spreader Show
Mods:
The cost of parts for this system was $6,500 about a year ago. The best hardware went into it.I was going to upgrade to 8800GTX card but this system plays everything I through at it great.Not bad for a year old build.
Specs:
Voltage: 1.5V
Process: 0.13Micron
Socket: Socket 939
PANEL
& ChipSet HeatSink
Mods:
