[Case Gallery] STILL IN PROGRES (UPDATED AGAIN)
zvonjola
89 (0.01/day)
Kutina,Croatia
Processor Intel Core i7 920@3.2
Motherboard Gigabyte ex58-ud3r
Cooling Prolimatech megahalems
Memory 6 gb ddr3 @1600
Video Card(s) Msi gtx 460 Hawk
Storage Intel 330 60 gb,Wd 640 gb
Display(s) Samsung 2232bw
Case Antec 300
Power Supply Corsair TX 650 V2
Software Win 7 ultimate 64
Specs:
INTEL C2D E6600 @ 3.2 GHZ,GIGABYTE P965 DQ6,MUSHKIN 2X1 GB 890 MHZ,GAINWARD 8800 GTS 512 (700/2000/1700),MAXTOR 320 gb,MAXTOR 250 gb,SEAGATE 120 gb(external backup),CHIEFTEC 650W MODULAR PSU,LOGITEC G5,SAMSUNG 22"LCD,CM 590 CASE
Mods:
cut fan mash on the back side,black paint inside,added original side panel with window
HERE R THE RESULTS:
3d mark 01 - 48119,
3d mark 03 - 38919,
3d mark 05 - 17072,
3d mark 06 - 12700,
3d mark vantage - 7100,
1,070 (0.16/day)
System Name My Current Desktop
Processor i9 12900KF
Motherboard Asus ROG STRIX Z690-E GAMING WIFI
Cooling ARCTIC Liquid Freezer II 360
Memory G.Skill Trident Z5 RGB Series 32GB (2 x 16GB) DDR5 6400 F5-6400J3239G16GA2-TZ5RS
Video Card(s) RTX 3090 FE
Storage SAMSUNG 980 PRO SSD 1TB
Display(s) Samsung G80SD
Case Fractal Design Torrent White
Audio Device(s) Schiit Bifrost2
Power Supply Corsair HX850
Mouse Razer Basilisk v3 pro
Keyboard Keychron Q6 Max (brown)
Software Win 11 Pro
very neat work. you'll get some good airflow in there :)
234 (0.04/day)
Brasil - São Paulo - São Caetano do Sul
System Name NOS
Processor Core Extreme QX6850
Motherboard Maximus Formula
Cooling VANTEC STING RAY CPU Block, 3x120mm fan's with Radiator, Seltz 1200lt/h
Memory 4GB Crucial Ballistix 1066MHz 5-5-5-15
Video Card(s) PCI-express ATI Radeon HD2900XT 1GB DDR4 512bits
Storage 5 HD's 160GB SATAII Seagate ST3860815AS 7200.10
Display(s) LG 22'' model 22LS4R
Case 3Rsystem's R810 with mod's for watercooler system
Audio Device(s) Supreme FX II
Power Supply ULTRA X3 1000W modular PSU
Software WINXP PRO SP3 x86
234 (0.04/day)
System Name NOS
kane77573
50 (0.01/day)
I gave you a 10,
Nice cable management, and ITS NOT A PC WITH JUST LIGHTS!!!!!!
Nice clean simple install
ccleorina
195 (0.03/day)
Overclocking Hell
Processor Intel Core i7 Extreme Edition 965 4.2GHz
Motherboard Gigabyte GA-EX58-EXTREME Intel X58
Cooling Noctua NH-U12P SE1366 120mm SSO CPU Cooler
Memory G.SKILL 6GB (3 x 2GB) DDR3 2000Mhz
Video Card(s) 2 XFX GeForce GTX 295 1792MB GDDR3 SLI
Storage 2 WD VelociRaptor 300GB RAID0 + WD GP 2TB Data
Display(s) 2 Samsung 30W" LCD 6ms
Case Thermaltake SwordM Black Liquid Cooling Case
Audio Device(s) Creative Falat1ty X-Fi
Power Supply Ultra X3 1600W Modular PSU
Software Microsoft Windows Vista Ultimate 64-Bit SP1 OEM
Nice rig.... like your cable management, clean simple install... 10/10 for me... How much u get for 3dMark06 for your 8800GTS 512? Just want to know?
2,228 (0.36/day)
Larisa, Greece
System Name StarCruiser Dark Knight v.2
Processor Intel® Core™ i5-3570K
Motherboard P8Z77-V LX
Cooling 1x custom W/C loop/ inflow:6x120 /outflow:4x120, 2x200
Memory Viper 3 Black Mamba (4x4GB)
Video Card(s) Powercolor LCS 5870
Storage 1X 128GB OCZ, 2 x 1.500 Gb Seagate
Display(s) Samsung 24" LC24F396
Case custom MDF case (I BUILT IT) check sig.....NOW
Power Supply Tagan 900 watt
Software Win 7 RC / Open office / Games
4,520 (0.71/day)
Perth AU
Processor Intel Core i9 10980XE @ 4.7Ghz 1.2v
Motherboard ASUS Rampage VI Extreme Omega
Cooling EK-Velocity D-RGB, EK-CoolStream PE 360, XSPC TX240 Ultrathin, EK X-RES 140 Revo D5 RGB PWM
Memory G.Skill Trident Z RGB F4-3000C14D 64GB
Video Card(s) Asus ROG Strix GeForce RTX 4090 OC WC
Storage M.2 990 Pro 1TB / 10TB WD RED Helium / 3x 860 2TB Evos
Display(s) Samsung Odyssey G7 28"
Case Corsair Obsidian 500D SE Modded
Power Supply Cooler Master V Series 1300W
it would get dam hot in there with that GTS
1,042 (0.16/day)
CT, USA
Processor q6700 @ 3.2ghz
Motherboard Asus p5w DH Deluxe
Cooling Scythe Andy Samurai, 4x80mm silenx, 2x120mm silenx fans
Memory 2x2gb G.Skill 4-4-4-12
Video Card(s) xfx black edition 6870
Storage 250gb seagate sata, 2x250gb seagate perp (raid0)
Display(s) dell 24"
Case Coolermaster atc s4000 sx-1
Audio Device(s) Creative Audigy2 Platinum
Power Supply Antec True Power Trio 650w
Software winXP pro x64
I have the same Blue Orb cpu cooler, and I find it pretty disappointing. Looks nice tho!
3,767 (0.61/day)
WI
System Name MUFFIN_MACHINE
Processor i7 920
Motherboard E760 Classified
Cooling cooler master gemini II
Memory 6gb ddr3 crucial ballistix
Video Card(s) TFIII 6950
Storage 500gb wd, samsung spinpoint t series 500gb, 2 tb samsung somthing or other
Display(s) syncmaster 940bw 19"
Case Corsair Carbide Series 500R
Audio Device(s) X-fi extrememusic
Power Supply Corsair HX 850W
Software windows 7 64bit
Benchmark Scores i can drink a pint in 5 seconds flat.
one of the cleanest cases ive seen good job
zvonjola
89 (0.01/day)
Kutina,Croatia
Case Antec 300
why disappointing?my cpu is oc 2 3.0 ghz and it is coold.36 degrees celsius idle on low fan speed(840 rpm),
1,042 (0.16/day)
CT, USA
Display(s) dell 24"
I'm just not getting good results in my case, but I could just have a hot chip too :p
It does really well now that it's cold out, but when the ambient temps are high (summer) the Orb just can't get the heat off it that well. Then again, you're got a pretty mild OC going there, mine is an e6400 @ 3.2g
What are your load temps?
zvonjola
89 (0.01/day)
Kutina,Croatia
Case Antec 300
around 47 degrees(low rpm),42 degrees at 1600 rpm
zvonjola
89 (0.01/day)
Kutina,Croatia
Case Antec 300
4,520 (0.71/day)
Perth AU
Every well done 8/10
zvonjola
89 (0.01/day)
Kutina,Croatia
Case Antec 300
E
evertigox
well organized
Nice setup man. It's nice and clean. good cable management. I have the same mouse...love it!
mdashoot
450 (0.07/day)
Las Vegas, NV
System Name 1st Build
Processor Intel Core 2 Duo E6850
Motherboard Asus P5K-E/WiFi-AP
Cooling Zalman 9700 NT
Memory G. Skill 2X1gb DDR2 800 PC2 6400
Video Card(s) XFX GeForce 8800GT 512mb 256bit Alpha Dog W/Accelero S1
Storage Samsung Spinpoint S-ATA 500gb
Display(s) LG L206W 20.1" Widescreen
Case Antec P182
Audio Device(s) HT Omega Claro Plus+ 7.1/Logitech Z-5500 5.1 speakers
Power Supply Corsair HX520w
Software WindowsXP Pro
9/10 from me, nice specs
I
interceptor_dj
pozdrav Kutini! evo baš gledam tvoju pilu-vidim da si pazio na urednost. Drago mi je jer moddingom bave i domači ljudi.
miloshs
362 (0.06/day)
Serbia
System Name Begginer's E
Processor Intel E8500
Motherboard DFI LT X48-T2R
Cooling Thermalright HR-01 Plus & Silverstone FM-121B (800-2400rpm)
Memory 2x2gb GEIL Ultra Plus PC8500 CL5
Video Card(s) Sapphire HD5850 1gb
Storage WD 1tb Black Series
Display(s) ASUS VW242HS 24"
Case CoolerMaster 690
Audio Device(s) ICH8 integrated crappie
Power Supply OCZ 700W xStream SLI PSU
Software Windows 7 x64
Svaka cast... nemam reci, vidi se da je ulozeno dosta truda i novca...
nego reci mi jel ova piramidalna foam stvarchica stvarno radi posao sto se tice izolacije zvuka iz kucista i da li ti mozda povecava temperaturu unutar kucista?!
Jedno od lepsih, cistih modova koje sam video.... svidza mi se :)... a pravo da ti kazem i ja sam hteo da odradim crni mat paintjob unutar kucista
Za sve ostale pogledajte moj mod na http://www.techpowerup.com/gallery/1723.html -imajte na umu da su poslovi jos u toku :D
And now for the english speaking people :D:
Very good job... i am speachless, u can see there's a lot of work and money put into this mod..
But tell me this pyramidal foam u have padded your case with, does it really works regarding the sound isolation from within the case and does it raise your in case temperatures?
This is one of the cleaner, purer mods i've seen... i like it... to tell you the truth, i myself am planning to do a black mate paintjob on the inside of the case...
For anyone else check out my mod http://www.techpowerup.com/gallery/1723.html -bear in mind that it's a work in the progress :D
zvonjola
89 (0.01/day)
Kutina,Croatia
Case Antec 300
ma jok!nije niš pomoglo,ali lijepše izgleda!temperature su iste!prije farbanja kučište dobro očisti(kompresor,vata i alkohol)i to radi u zatvorenom,ali opet dobro provjetrenom prostoru.iako se boje brzo suši, mogu ostat zrnca prašine.
HyD3
44 (0.01/day)
San Diego
Processor Intel Core i7 860 @ 4Ghz
Motherboard Asus Maximus III Formula
Cooling Coolermaster Hyper 212 plus
Memory 4GB OCZ DDR3
Video Card(s) Saphire 5850 @ 900MHz core, 1200MHz Memory
Storage Western Digital Black 500GB
Display(s) Asus 23.6 Widescreen
Case Coolermaster CM690
Audio Device(s) Creative X-Fi Extreme Music
Power Supply Coolermaster 750 watt
Software Windows 7 Home Premium
love the mod on the memory cooler!!!!!!! how did you do that????
miloshs
362 (0.06/day)
Serbia
Stvarno shto kaze ovaj chova, slikni ga sa strane onih fanova na RAM-u bas me zanima kako si to izveo... jel to bese 60mm FANovi?
