strange asrock 970 extreme
1,118 (0.56/day)
System Name just ordinary potato system, but dont understimate potato..
Processor ryzen raven ridge 2200g, ryzen 2600 upgrade:)
Motherboard msi b350 pc mate, biostars a320, asrock ab350m micro
Cooling x2 cheap china handmade, i got plenty aigo/fantech rgb fans now heh
Memory klevv dual channel 8gb 3000mhz, trident 16gb 3600mhz, random ddr2 stick
Video Card(s) back to square, using vega 56 now:D
Storage wd green ssd 240gb, 3tb seagate expnasion, random laptop hdd x4, 1tb 3.5
Display(s) acer vgo 22inch fullhd 75hz
Case cheap segotep/dazumba mid atx, alcatroz mini atx
Audio Device(s) genius retro wood style, harman kardon stick iii
Power Supply be quite system power9, powerlogic standar, voltron 300fx, thermaltake smart 1200w
Mouse rexus, genius ps/2, powerlogic ps/2 ball tracking
Keyboard rexus, random china product x3
Software talking abt best software, autodesk/unity3d/notepad yes notepad!!
Benchmark Scores theres nothing to brag abt potato, but it can run decent 30fps fullhd with good setting:)
my friend just got used asrock mobo, this motherboard quite strange rly, he used vega 56 it can sometimes enter & even play game normally, sometime it crash on booting, so i bring few of my vga for a test, unexpected result, non of rx570/580 work, they all no display, funny thing gtx260+ working, i note the error code of led, it display 97 on number, whats this troubleshot cause? anyone have same problem as our? pls lemme know thx:)
model of motherboard
temporary asume thats something wrong with the pcie slot, maybe the motherboard cant or have priblem running new vgacard, i do quick check on asrock website, it suppose to be 2.0 express
43,492 (6.76/day)
What are the rest of his system specs and what specific brand of Vega 56 is this card?
1,118 (0.56/day)
What are the rest of us system specs and what specific brand of Vega 56 is this card
oh i forgot to note it, i believe he use 2 stick of single channel ddr3, and the model of 56 is red devil triple fan, psu use thermaltake lite 650 also used spare one corsair vs, will contact him to list whole specific pc info
okey cpu is fx6300
43,492 (6.76/day)
Those psus are not strong enough.
And what specific ram modules is he using?
1,118 (0.56/day)
corsair vegeance, with 8 8 timing i guess, wait i will ask again
43,492 (6.76/day)
Tbf id get rid of the corsair for gskill
347 (0.06/day)
Valencia, Venezuela
System Name Tropicaliente | Digger | A515-43-R19L
Processor FX-6300 | Q6600 | R3 3200U
Motherboard ASRock 970 Extreme 4 | Gigabyte X48T-DQ6 | Grumpy_PK
Cooling EVGA CLC120 | OCZ Vendetta | Stock
Memory 16GB DDR3-1600 | 8GB DDR3-1333 | 16GB DDR4-2666
Video Card(s) PowerColor RX-570 4GB Red Dragon | HIS HD5670 1GB IceQ | Vega 3
Storage 256GB SSD (OS) + 512GB SSD (Games) + 500GB + 2TB + 4TB | 80GB + 320GB | 128GB NVME + 512GB SSD
Display(s) Asus VN247H-P | KVM USB Switch | 15.6" FHD
Case Antec ONE | Generic Black
Audio Device(s) on board + Logitech Z623 | on board | on board
Power Supply Cooler Master GX-650 | Antec VP-450 | Powerbrick ac/dc
Mouse MS Wired Desktop 600
Keyboard MS Wired Desktop 600
Software Win 10 x64 Pro | XCP-ng 8.1: XOA, pfSense, RouterOS, FreeNAS, Zabbix | Win 10 x64 Home
... i note the error code of led, it display 97 on number, whats this troubleshot cause? anyone have same problem as our? pls lemme know thx:)
About the code number...
92 - 99​
Problem related to PCI-E devices. Please re-install PCI-E devices or try installing them in other slots. If the problem still exists, please remove all PCI-E devices or try using another VGA card.
I have that motherboard with a rx570 without problems.
Did you try Clear CMOS?
1,118 (0.56/day)
135344
92 - 99​
alr clear cmos yes, sadly no fix, it even worse using rx570/580 no display:D
43,492 (6.76/day)
Post dr debug 0x97
He needs to update bios to these if not done so slready, also a bios battery swap cant hurt.
My bro has that exact mobo.
Make sure to flash all beta bios to the system first. Do not flash 2.80 yet
After each flash do a clear cmos and a save defaults in bios.
1,118 (0.56/day)
oh okey will do, i think this is the fix, hope it done well thx, almost forget that i never do flashing mobo bios yet, will read the tutorial bit hehe
43,492 (6.76/day)
Start with oldest beta bios and update.
1,118 (0.56/day)
how do i check the correct version of m/b? theres 2 rom glbal and china, also is this okey L2 .21 beta?
L2 .21 it is okey starting with this one?
43,492 (6.76/day)
Go in the bios and see
Start with L1.46 if possible then move up.
1,118 (0.56/day)
Start with L.146 if possible then move up.
okey wait
135354
okey i found L146, only need to check which version of global or china
i will prepare downlpad all file needed, and let him know
43,492 (6.76/day)
19,375 (3.51/day)
1. That PSU is fine for that GPU and system (so long as the PSU is working properly).
2. The PSU likely has nothing to do with it because the issue is on boot, not while on load.
That aside, flash the BIOS to the latest and give it a whirl.... as it looks like you are doing already. Simply flash to the latest non beta version (unless beta says something about VGA compatibility). Global vs. China is a different language, not file/bios.
EDIT: You should be flashing to version 2.80 from 2015. All those beta BIOS' are two years older than the latest stable version.
EDIT2:
If there are specific instructions that say so, indeed, follow them potato, otherwise, you do not have to install those first.
EDIT3: I don't see where ASRock requests/requires that, so unless the exiled airman saw something I missed (certainly possible), just flash to the latest version.
43,492 (6.76/day)
EDIT2: If there are specific instructions that say so, indeed, follow them potato, otherwise, you do not have to install those first.
With all the stuff that asrock has had going on with their boards i would start with the beta bios then move to the final bios
19,375 (3.51/day)
All the stuff eh? Not sure what that was...anyway, it's only time...
Though thinking about it, what BIOS is the OP on (@potato580+ ?)? It could be newer than those beta BIOS' which would make flashing to the older beta a bad idea.
I guess my take is if going to a beta BIOS first was necessary, it would tell us. Personally, I'm not dumping a beta bios on that board when there is a 'stable' BIOS available (assuming it works of course).
1,118 (0.56/day)
ive download all beta from oldiest yes, and will flash after beta to 2.8 via window version, might visit again and flash it on next thursday, even its easy task to do so but my friend just wont do it himself, he afraid of brick the board hehe, thx for the tips guys, will update after it done:)
43,492 (6.76/day)
Find out what bios version is on there and then update. Also there is a bigger risk of bricking a gpu than a mobo
1,118 (0.56/day)
what do you mean by bricking gpu?
43,492 (6.76/day)
Ok an incorrect bios file installed on a gpu renders a card unuseable, no video output from the card, that is called bricking.
1,118 (0.56/day)
oh i never knew it, this is soemthing important to be aware, thx for the tips!
43,492 (6.76/day)
19,375 (3.51/day)
Again, BEFORE you start flashing, see what BIOS version is on there. You do not want to go backwards. If there is any question... just flash to the latest stable BIOS. They are beta BIOS' for a reason...
