stream KODI library to OUTSIDE my home network?
341 (0.12/day)
System Name Core p90
Processor I7 9700k
Motherboard ASRock Z390 Phantom Gaming 4
Cooling Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo.
Memory Trident gskill 16gb 3000mhz
Video Card(s) Nvidia Founders edition rtx 3080 10gb
Storage M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd
Display(s) Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor
Case Thermaltake Core P90 tempered glass edition
Audio Device(s) On board
Power Supply Thermaltake smart m1200w
Mouse Logitech G600
Keyboard Logitech G910
Software Windows 10 64bit
I'd like to know HOW to stream my Kodi library to OUTSIDE my home network.
I've managed UPNP inside my home network where I can get access to my library on my cell phone or tablet only if I'm on the same home network.
How do I do the same but outside my home network? I've heard of things like plex SERVER and Air video HD... But I much prefer Kodi's interface. Is there any options inside of Kodi to do this?
I found the "web access thingy" but it only seems to work inside my home network and when I start playing a file, it plays on my htpc downstairs but nothing plays on the tablet or smartphone
555 (0.17/day)
In the middle of nowhere
System Name Scrapped Parts, Unite !
Processor Ryzen 5 3600 @4.0 Ghz
Motherboard MSI B450-A Pro MAX
Cooling Stock
Memory Team Group Elite 16 GB 3133Mhz
Video Card(s) Colorful iGame GeForce GTX1060 Vulcan U 6G
Storage Hitachi 500 GB, Sony 1TB, KINGSTON 400A 120GB // Samsung 160 GB
Display(s) HP 2009f
Case Xigmatek Asgard Pro // Cooler Master Centurion 5
Power Supply OCZ ModXStream Pro 500 W
Mouse Logitech G102
Benchmark Scores Minesweeper 30fps, Tetris 40 fps, with overheated CPU and GPU
I dont know how you setup your Kodi on, but if you have your Kodi in VM hosted in PC/server, I think you can setup NAT, with private address for inner network and public address facing outside, which then you can setup PPTP VPN to connect into your server.
2,373 (0.58/day)
Audio Device(s) A LOT
Honestly I’d discourage you from doing this if you’re asking how to on TPU. On completion you’ll have opened up access to your internal network, exposing your network and connected computers to external users, who may be malicious.
That said you simply have to forward the appropriate ports in your router and you’re all set and done. I would recommend running Kodi through docker and then using a reverse proxy (nginx) to allow for SSL/encrypted connections.
You could setup a VPN as suggested above, but your streaming quality will be limited due to the overhead of the VPN.
This is one real advantage of plex/Jellyfin/emby — their services set up all of this stuff for you, including user authentication, so that all you need to do is setup an account. I’d recommend deploying jellyfin or plex and then just using kodi for the interface if you’re married to it).
