Stripped GPU heatsink Screw
Murderator
7 (0.00/day)
Indonesia
So my notebook have one screw on GPU heatsink that just won't comes out. It's head is just won't grip to any screwdriver anymore. I've tried glue method, no luck.
Is it safe to make a new thread/grip for a minus screwdriver, with a metal cutting saw?
will it damage the chip?
Acer E5-573G
i5 5200u
Nvidia 940M
One heatpipe for both CPU and GPU
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.94/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Power Supply Corsair
Mouse cheap
Keyboard under going restoration
hiya
pic please
elastic band usually does the trick
sneekypeet
not-so supermod
29,703 (4.28/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
I would assume that trying to cut a slot inside of the laptop is a bad idea as there is no way to contain the metal shavings. It is highly likely that the shavings could short out many thinks inside of it.
CAPSLOCKSTUCK
8,578 (1.94/day)
llaregguB...WALES
Mouse cheap
vacuum or magnet would help with that
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Small vise grip if you have it partly out. Otherwise you can try cutting a slot in it very carefully and using a flat head screw driver. Mask all of the surrounding area with painters tape before cutting, after cutting blow it out with a duster afterwords to make sure any metal doesn't enter the board.
If it isn't tightly screwed in it might be possible to solder a small nut to it and turn the nut, I am not sure.
AsRock
TPU addict
19,226 (2.96/day)
UK\USA
Cooling D15
hiya
pic please
Yeah some times, or the good ol dremel if there is space, although the later you gotta cover any thing electronic.
Here's 5 more idea's if possible.
CAPSLOCKSTUCK
8,578 (1.94/day)
llaregguB...WALES
Mouse cheap
In this instance an impact driver probably isnt the right approach.......:)
9,781 (2.15/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
if you can carefully cut a slit in the head of the screw, maybe is the best anyone could answer. if i were you, id try using a pair of pliars, or something that can tightly grip & turn it. then theres the flathead screwdriver method.
12,340 (2.22/day)
Oregon
Keyboard EVGA / Logitech K400
take a pic. Does it turn at all ?
The trick is not to strip it. Your best bet now is if it works just put it back together
7,111 (1.00/day)
USA
Mouse Zowie EC3-C
Just don't use an impact screw driver LOL.
9,781 (2.15/day)
Massachusetts
Processor i7-11700K
Ive seen it done with a small Dremmel drill, and you drill right down in the center of the stripped screw-head( about a quarter inch) and then you set a smaller screw into that hole (preferably a reversed threaded screw) and use it to back it out that way.
I ran into an issue just like this on a Dell OptiPlex small form factor. It was such a pain in the ass because the screws were torX headed (which suck BALLS) I ended up having to use a massive flat head screw driver to get it out, but first I had to break the bond with a pair of very small pliers (needle nose is not suitable in most cases in my experience) you need flat bill
I just recalled one way I was able to do it with a wicked difficult stripped screw , was using a pair of tinsnips. because they have such sharp tips. I actually snip into the head of the screw, and use that to turn it loose. it works really well, you'd be surprised. but you have to point them straight down, that way it forms a notch on either side of the screw head for the snips to grab.
if there enough of the screw head to Grasp, this method works like a charm IME.
CAPSLOCKSTUCK
8,578 (1.94/day)
llaregguB...WALES
Mouse cheap
it often helps if you try tightening the screw then have another go at it.
AsRock
TPU addict
19,226 (2.96/day)
UK\USA
Cooling D15
Ahaha yes lol. there's me presuming common sense. Just thought it would give him the idea how it's done.
44,157 (6.81/day)
Use a left handed drill bit
Murderator
7 (0.00/day)
Indonesia
hiya
pic please
My camera is not good for taking close up. I tried rubber it don't work.
I don't have option bcause even laptop repair center in my city won't take the job. They afraid they'll broken the chip's glass, bend the board, or cutting the circuit like they did before.
How about covering with transparent plastic like for food?
and how strong soldering compare to superglue method?
I don't have the drills
sneekypeet
not-so supermod
29,703 (4.28/day)
System Name EVA-01
Murderator
7 (0.00/day)
Indonesia
I tried cutting plier, general pliers, and locking pliers, not turn at all. it's very slippery. And i almost bump into the component nearby
It doesn't turn at all, except the other direction. I put it back together, but my CPU according to Intel XTU is thermal throttling. Even it's stays below 76C both CPU GPU.
The screw is very thin shiny slippery. How is your screw type?
I did
That's what i'm afraid. That any impact will damage the chip
I don't have drills
Will it work without drills?
what do you think of using a saw to make a flathead screw, will the vibration damage anything? or maybe ESD?
sneekypeet
not-so supermod
29,703 (4.28/day)
System Name EVA-01
The screw removers could work with a hand driver that accepts bits.
My same advice as above applies. The bits of shavings could still be an issue.
Norton
Moderator - Returning from the Darkness
14,104 (2.91/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Is this what it looks like? If so, which screw is it?
EDIT- something like these should work on those screws:
44,157 (6.81/day)
Get a drill then, any 1 will do
9,781 (2.15/day)
Massachusetts
Processor i7-11700K
which screw is it?
it has to be one of the following. im fairly sure it is the 3 in the mid section of the heatpipe though....all of which are the "best case" scenario type of stripped screw (since some can be flush or worse, like the top right one) those are the ones that always seem to strip on me :banghead:
CAPSLOCKSTUCK
8,578 (1.94/day)
llaregguB...WALES
Mouse cheap
time for a ghetto solution then
look for a carbarundum cutting disc....you can get them at 1mm thickness. Using a back and fore motion by hand....NOT MACHINE cut a a groove in the screwhead.. Its well worth taking 10 or 15 mins to do it slowly and carefully. Every swipe you make will remove a tiny amount. Have a vacuum cleaner running the whole time.
you can do this if you take your time and use a back and fore rubbing motion......the discs cost pennies.
the discs are easy to break and you may find that using a broken piece will be easier to manage
Murderator
7 (0.00/day)
Indonesia
The screw are seems fragile to me. Maybe this will work with hands. But it have the same risk with saw method right? bits of shavings?
This one
I asked those pliers at local store, doesn't have one.
Aren't they expensive?
I've never had stripped screw before.So when it's bit stuck i didn't expect this, keep forcing it. If i knew such case, i'll glue them before they stripped competely, it'll help right?
12,062 (2.55/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
I have a set of these:
You put your drill in reverse, it bites into the screw. Specifically asked for them for christmas last year.
9,781 (2.15/day)
Massachusetts
Processor i7-11700K
Really ANY pliars with a flat tip can work, but if you dont think you can get it unscrewed, just take a second to decide whether NOT removing it is an option (what I mean by this ,is if you're just doing this to look at it ,or replace thermal paste for good measure.... don't ,put the other screws back in and leave it for the next owner).
Ive never known of a reliable adhesive method, so in my opinion, your better off pushing that out of your mind. I would say your best choices of the following
Do what @CAPSLOCKSTUCK said and cut a slot for removal.
Use pliars with a flat tip, or tinsnips with a sharp tip.
Or put the cover back on if its an option, & let the next owner deal with it.
You also could take it to a repair shop, but In my opinion, this is really the BEST case scenario you'll find with a stripped screw, atleast its not inset, or flush. Id go for the pliars method.
or these ,
