Strix 3090 safe temperatures
172 (0.08/day)
Processor 5900x
Motherboard Asus CrossHair Dark Hero
Cooling EK AIO 360
Memory G Skills Trident Neo -32G - 3600
Video Card(s) Asus trix RTX 3089 OC
Display(s) LG38GN950
Case Phanteks P6900S
Power Supply Seasonic Prime Ultra 850W titanium
I have a strix 3090 since last year, running great but i was concerned about the temperatures
I have a 5900x, PSU is Seasonic Prime ultra 1000w, Rog Dark Hero VIII, EK Aio 360 push pull on the front of the case.
I've put some heatsinks on the gpu and a 80mm fan on the top of the backplate of my 3090
I've undervolted as well : 1920 @ 0.875
but it some games the memory temperature junction is still going up to 85 to 88c with fan at 100%, is that completely safe?
In most games temps are around 60c on core and 75/78 on MTJ
thanks
1,081 (0.35/day)
System Name Main System
Processor i9-10940x
Motherboard MSI X299 Xpower Gaming AC
Cooling Noctua NH-D15S + Second Fan
Memory G.Skill 64GB @3200MHz XMP
Video Card(s) ASUS Strix RTX 3090 24GB
Storage 2TB Samsung 970 EVO Plus; 2TB Corsair Force MP600; 2TB Samsung PM981a
Display(s) Dell U4320Q; LG 43MU79-B
Case Corsair A540
Audio Device(s) Creative Lab SoundBlaster ZX-R
Power Supply EVGA G2 1300
Mouse Logitech MK550
Keyboard Corsair K95 Platinum XT Brown Switches
Benchmark Scores Cinebench R20 - 6910; FireStrike Ultra - 13241; TimeSpy Extreme - 10067; Port Royal - 13855
I think you should be okay, because your temp is lower than mine (same card). I have a lot of drives crammed in a Corsair 540
1830MHz @0.850mV, Memory Clock 1220 MHz, Temp: GPU 75C, Hot Spot 85C, Memory 92, Fan Speed 75%. I think the memory TJ Max is 110C?
Mussels
Freshwater Moderator
58,413 (7.90/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
110C is the limit for the VRAM, your GPU fan will ramp to 100% if that happens
under 100C is fine, 3090s just suck. Active watercooling on mine keeps it at 80C.
172 (0.08/day)
Processor 5900x
Cooling EK AIO 360
Hi
i've undervolted my Strix 3090 to 0.850 @ 1905 but i find my temps quite hot even with it
while playing some games like days gone, i have around 70c on core and 86c on memory
I game at 3840x1600, i've also put some heatsink and a fan on the backplate to cool vrm but not sure if it does something to be honest
I don't want to go on water for now or change thermal pads for warranty issues
Are those ok temps for this gpu even with an undervolt? I'm quite concerned by temps
If i go lower like 1850 for 0.8 will I lose a lot of performances?
1,081 (0.35/day)
Processor i9-10940x
Case Corsair A540
Your temp is fine. Make sure you get plenty of air flow into your case.
172 (0.08/day)
Processor 5900x
Cooling EK AIO 360
I do :) i have my EK aio on the front, push pull,
lian li fans 120 on top, rear and intake
But i was worried about the temps since i've undervolted and having fans blasting actually
1,081 (0.35/day)
Processor i9-10940x
Case Corsair A540
Your GPU fan speed is at 100%? Mine gets up to 64% to get to my temp.
172 (0.08/day)
Processor 5900x
Cooling EK AIO 360
i have this curve so yes around 85 % to 100 kinda, that's why i'm worried
1,081 (0.35/day)
Processor i9-10940x
Case Corsair A540
I think your fan curve is a bit aggressive. You can tame it down a bit. This is mine -
172 (0.08/day)
Processor 5900x
Cooling EK AIO 360
but my temps will be worse no?
1,081 (0.35/day)
Processor i9-10940x
Case Corsair A540
Try it, I don’t think it will be much worse
Mussels
58,413 (7.90/day)
Oystralia
Hi
0.85 is still fairly high, i'm at 0.740
you might find a huge drop in needed voltage and temps dropping even 50MHz
I've run as low as 1500Mhz and still been smashing 1440p 165Hz
43,613 (6.47/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Gelid Ultimate thermal pads on my 3070ti dropped memory temps 10c. They do help.
Mussels
58,413 (7.90/day)
Oystralia
i got the wrong sizes with my stock cooler but also backing them up, the gelids seem to be the best out there
i got more here i plan to put on my EK block and make the active VRAM cooling even shmexier
43,613 (6.47/day)
I'd like to do my VRM too but they need the odd 2.5 mm spacing, which doesn't exist. I figure I'll buy some 1.0 and 1.5 pads and mush them together. They remind me of slightly hardened and formed thermal paste, should work.. I think.. hopefully.
172 (0.08/day)
Processor 5900x
Cooling EK AIO 360
I've asked Asus and changing thermal pads at least in France will void my warranty.
I'm considering going full WC. but I lack skills and patience so i need some pro to do it for me and it's expensive
Well going to 1500 with a 3090 is a waste no?
i wanna stay at least at 1860mhz, seems 0.825 is stable but i haven't foud a big difference in temps, at least on memory but seems the UV affects more the core than memory non?
Mussels
58,413 (7.90/day)
Oystralia
a "waste"?
If i'm getting full speed outta my games, it's not a waste
172 (0.08/day)
Processor 5900x
Cooling EK AIO 360
a "waste"?
How is it possible since stock is around 1900? I don't understand How you won't lose any performance
Mussels
58,413 (7.90/day)
Oystralia
because its already fast enough... oh no 200FPS down to 180, the shame
you gotta realise stock bounces around a LOT, and unless you're on custom water like me, will thermal throttle down low
I was seeing as low as 1400 under heavy loads when i tried air cooled vertical mount and it was choking for air
1,763 (1.01/day)
In my opinion, the temps look fine. While the custom fan curve looks aggressive, but at the end of the day, when the GPU heats up, and heat up it will, you will ultimately end up at 80 or 100% fan speed under load. The RTX 3090 is the top of the range GPU, so expected to run hot. Couple with the fact that this is a Strix that draws north of 350W under load with its 3x PCI-E 8 pin power connector, only means that it may run potentially hotter, but with a higher core clock. If you are concern due to the heat, you should consider capping framerates in game so that it will run smoothly, and the GPU don't have to work that hard. After all, you've tried undervolting and increasing fan speed, with some success.
Krazeykami
1 (0.00/day)
Asus ROG Strix 3090 (non-oc variant) + AlphaCool Eiswolf 2 (modified backplate with my own active cooling, see https://forum.alphacool.com/threads/alphacool-eiswolf-2-for-3090-strix-wrong-size-of-padding.2809/ for details on my mod).
GPU is overclocked: +175 Mhz GPU / +250 Mhz Memory / 137% TDP
Idle temperatures:
CPU Tdie: 44.5c
CPU Die avg: 35.7c
Asus Chipset: 58.5c
GPU: 25c
Hot Spot: 32c
Memory Junction (VRAM): 32c
VRM: 29c
Stresstest: 30 minutes Unigine SuperPosition @ High Textures / 3840x1600
Stress / Load (Non-OC) Peak Temperatures:
CPU Tdie: <not measured>
CPU Die avg: <not measured>
Asus Chipset: <not measured>
GPU: 56.1c
Hot Spot: 66.2c
Memory Junction (VRAM): 66c
VRM: 48c
Stress / Load (OC) Peak Temperatures:
CPU Tdie: 74.5c
CPU Die avg: 75c
Asus Chipset: 66.3c
GPU: 66.2c
Hot Spot: 76.3c
Memory Junction (VRAM): 72c
VRM: 57c
3DMark scores (OC):
TimeSpy: Overall: 19538 GFX: 21431 CPU: 13023 - https://www.3dmark.com/spy/26080542
TimeSpy Extreme: Overall: 10647 GFX: 11060 CPU: 8789 - https://www.3dmark.com/spy/26078840
Port Royal: GFX: 14949 - https://www.3dmark.com/pr/1430299
Mussels
58,413 (7.90/day)
Oystralia
Wow that alphacool link explained why EK sent a bunch of spare thermal pads with my 3090 blocks - in case the damn thing was warped out of shape!
I can't believe they say the VRM doesnt need thermal pads however, that seems really off
Deleted member 24505
Even with your loop it's still at 80c load, i don't think i would bother with a 3090 even if i had the dosh. I wonder if the top drawer 4xxx will run cooler?
Mussels
58,413 (7.90/day)
Oystralia
It's only mining they hit that high, regular use is a lot lower
The 90's just got that design flaw of passively cooling potential heat monsters, i want my hardware to handle whatever load can be thrown at it... you never know what the future may bring
What if DIrectstorage ramps up the VRAM usage and 3090's become toasters on the topside?
Kanan
Tech Enthusiast & Gamer
3,517 (1.03/day)
Europe
System Name eazen corp | Xentronon 7.2
Processor AMD Ryzen 7 3700X // PBO max.
Cooling Noctua NH-D14 SE2011 w/ AM4 kit // 3x Corsair AF140L case fans (2 in, 1 out)
Memory G.Skill Trident Z RGB 2x16 GB DDR4 3600 @ 3800, CL16-19-19-39-58-1T, 1.4 V
Video Card(s) Asus ROG Strix GeForce RTX 2080 Ti modded to MATRIX // 2000-2100 MHz Core / 1938 MHz G6
Storage Silicon Power P34A80 1TB NVME/Samsung SSD 830 128GB&850 Evo 500GB&F3 1TB 7200RPM/Seagate 2TB 5900RPM
Display(s) Samsung 27" Curved FS2 HDR QLED 1440p/144Hz&27" iiyama TN LED 1080p/120Hz / Samsung 40" IPS 1080p TV
Case Corsair Carbide 600C
Audio Device(s) HyperX Cloud Orbit S / Creative SB X AE-5 @ Logitech Z906 / Sony HD AVR @PC & TV @ Teufel Theater 80
Power Supply EVGA 650 GQ
Mouse Logitech G700 @ Steelseries DeX // Xbox 360 Wireless Controller
Keyboard Corsair K70 LUX RGB /w Cherry MX Brown switches
VR HMD Still nope
Benchmark Scores 15 095 Time Spy | P29 079 Firestrike | P35 628 3DM11 | X67 508 3DM Vantage Extreme
Same, since 3080 Ti there's no reason to mess with a card that wasn't really designed well or not for high usage / gaming. 3090 Ti will allegedly fix that with no backsided vram anymore (doubled capacity in front side), if I had a 3090 vanilla, would've probably sold it a while ago and got a 3080 Ti instead. I mean this all, unless I'm a watercooler type of person which I'm not at the moment. It's a effective solution to the problem.
