SW Power Cap GTX1080
227 (0.07/day)
Manchester, UK
System Name Full LC'd Node 202 || Asus X202e
Processor i7-7700K || i3-2365M
Motherboard Asus Z270I || HM76 int.
Cooling Full Custom Loop|| Stock
Memory Hyper Fury DDR4 32GB || 4GB 1333
Video Card(s) GTX 1080 FE || HD3000
Storage 950 Pro M.2 +WD 2TB M.2 SSD || Sandisk 256 SSD
Display(s) Asus MG278Q
Case Fractal Node 202
Audio Device(s) OnBoard
Power Supply Corsair SF600
Mouse Logitech G502 ||Asus WT710
Keyboard Logitech G410 || Logitech K830
How do I remove this cap that gets flagged when I load GPU?
I've done a fresh Win10 install, flashed GPU BIOS using nvflash64 in the OS. Changed PCIe cable.
What else is there to try? My card wont boost past 800Mhz with 3dmark loaded or any games I play.
23,179 (6.10/day)
I believe you need a so called shunt mod for this. If you are ready to throw the card away, by all means google it :)
There are no software hacks as far as I know. These GPUs are indeed power locked and limited. For good reasons mostly.
227 (0.07/day)
Manchester, UK
My card won't boost past 800mhz...OP updated
23,179 (6.10/day)
Nice so you already bricked it! This is not how the card is delivered and bios flashing is generally counter productive.
Flash it back to a working bios and stop screwing around...
1,963 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
You can't BIOS flash Pascal cards with modified BIOS, ONLY official releases will work, and those in 99% of the cases won't solve this problem (which is hardware based).
I guess it may be the result of shunt resistor damage (do you get "Pwr" in GPU-z as perf limit reason, when you try doing something ?).
If so, disassemble the card and check resistance on all shunts.
227 (0.07/day)
Manchester, UK
Thanks, I'll try that. It does show pwr on GPU-z too.
9,663 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
It's a hardware problem, can't be fixed as far as I know.
newtekie1
Semi-Retired Folder
28,473 (4.06/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Install MSI Afterburner and try turning up the Power Limit. It probably won't fully fix the problem, but it should at least make it better.
193 (0.08/day)
System Name Zen4
Processor Ryzen 9 7950x
Motherboard Asus Strix B650E-E Gaming WiFi
Cooling Some oem 240 AIO
Memory 2xKingston DDR5 2x16GB (Hynix M die)@6000 CL26-35-35-27
Video Card(s) Gainward Phantom 4090 (@2.82GHz .95V UV, 350W PL)
Storage WD Black SN850X
Display(s) LG OLED C1 48"
Case Phanteks P600S
Power Supply Corsair RM1000i
Mouse Logitech G Pro X Superlight
Keyboard Corsair K70
VR HMD HP Reverb G2
Software Win11
You should not try this on your card (!), at least not before you have fixed the issue(s) triggering your power limit, as this will remove the protection saving your card from potentially burning up. And if it's air cooled, you should not try it at all, as the card will not throttle and protect itself as normal. I also believe this has pretty much made the shunt mod obsolete.
But I just wanted to mention that there are XOC bioses for some of the Pascal cards (Asus Strix models, but works on some other cards too) that removes the power limit entirely, and also unlocks Vgpu all the way up to 1.200V. These BIOS'es are leaked versions meant for extreme overclocking (LN2). I use a XOC bios on my water cooled Palit 1080ti, and at 1.200V and 2150MHz, it can easily pull up to 450Watts, too much for air cooling, and probably also getting up there considering the power delivery to the card itself. Just wanted to mention it as an alternative to the shunt mod, which is also dangerous. But I mean, if you have a fire extinguisher besides you, and are prepared to lose all your gear...:fear:
43,492 (6.76/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
Get the original bios back on the card and get the bios link from the vga bios collection by attempting to upload your bios through gpu-z and white sticker pictures from your card. I will help you try and find a bios with a higher power limit.
227 (0.07/day)
Manchester, UK
View attachment 148892View attachment 148894
Lool @extinguisher. My card is on a waterblock. If I can't get it fixed, I do some experiments with the XOC BIOS.
I don't understand "white sticker pictures". My card uses a waterblock and backplate now and I'm not sure I remember seeing some white stickers 4 years ago. Should I still attempt uploading BIOS using GPU-z?
Tried, no luck
43,492 (6.76/day)
Tried, no luck
The card has stickers on back of card take pics of those, otherwise get the link to your original bios
227 (0.07/day)
Manchester, UK
43,492 (6.76/day)
My original BIOS validation
Ok so you have a FE board.
I would try these bios for now see how the card handles the performance (make sure it boosts up to those speeds continuously)
If you want to push further look at this info in each file and make sure it is there
Connectors
1x DVI-D
1x HDMI
3x DisplayPort
Board power limit (make sure it isn't too high, we are starting you off with 230W and 250W, some go as high as 350W but they were built to handle that load, FE is reference) if you want to experiment-test them and if no good put a lower power bios back on.
Look at the Clock speeds too.
These are verified files that match your cards dev ID and SSID.
Unverified list
193 (0.08/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
Was the card ever shunt modded? I know some of those modded cards failed due to the use of liquid metal to alter the resistance of the current sense resistors, which led to the liquid metal softening the solder points of the resistors. If you got it second hand, I would inspect those, as it could easily mess up the power draw readings for your card.
43,492 (6.76/day)
Was the card ever shunt modded? I know some of those modded cards failed due to the use of liquid metal to alter the resistance of the shunt resistors, which led to the liquid metal softening the solder points on the shunt resistors. If you got it second hand, I would inspect those, as it could easily mess up the power draw readings for your card.
I doubt it has.
Shunt means parallel btw.
193 (0.08/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
I remember watching this video a while back regarding the shunt mod, and it was kinda funny as he initially thought it was nvidias fault for using bad solder :)
43,492 (6.76/day)
Anyways this guy hasn't been back on recently so carry on lol
227 (0.07/day)
Manchester, UK
Connectors
1x DVI-D
1x HDMI
3x DisplayPort
Unverified list
I'll give this a try. Thanks
I got it used in 2017. I've had a look online re: shunt mod, checked shunt resistor, no signs.
227 (0.07/day)
Manchester, UK
Soooooo. I poked my shunt resistor and it fell off
You seem to have replaced your shunt completely or have zero ohms across it. Your power draw is soo low for that clockspeed.
193 (0.08/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
So it was likely shunt modded with liquid metal at some point? As in the video I linked a few posts up?
What power draw reading are you referring to? My card is stock, only water block and XOC bios added. MSI Kombustor is fairly light load wise, here's a quick run and it's at 360Watts plus according to HWiNFO64:
227 (0.07/day)
Manchester, UK
The number in the cmd window but I guess thats wrong
193 (0.08/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
I often lock my clocks at max in Afterburner, so they don't clock down when idle, so that nvidia-smi report reading was at idle and max clocks, sorry for the confusion :)
227 (0.07/day)
Manchester, UK
Ah I see where the confusion was, thanks for clarifying.
Interesting v/f curve. Did you adjust that or did that come with the xoc BIOS? Nice result you've got there. Do you run this OC 24/7?
I've resulted in using a piece of thick solder to bridge the contacts of the shunt resistor. the resistor fell off when I poked it.
So, for now, it boosts up to 1936mhz but only downclocks to 1151mhz.
193 (0.08/day)
System Name Zen4
Case Phanteks P600S
VR HMD HP Reverb G2
Software Win11
Thanks :) It's very stable at 2150, but I usually run it at 2100 because I prefer stability over performance. The curve is manually edited, it only takes a few minutes to make one. You probably know this but shift and arrow keys are your friends, L to lock card to a selected node, remember to apply afterwards. The XOC bios have some lower nodes on the curve that I suspect aren't stable on my card, I had a couple of glitches playing youtube videos (card clocks to 1500MHz range) and such, so I dropped the entire curve 50MHz for those lower speeds just to be sure. A bit like that super stable CPU overclock that passes anything you throw at it, only to fail miserably and freezing while opening chrome :wtf:
Crazy clocks for 0.875V? Is it stable at 1936MHz? And that downclock seems strange? What does the curve look like? The card is now shunt modded and on XOC bios? Is it only partially shunt modded? as I believe there are 3 current sense resistors (one for each PCI-E power plug and one for the PCIe slot). Personally I would solder the resistor back on if possible, but I guess the amount of current going through it requires a good solder, so it might be hard to do...
