[Case Gallery] Swiftech Power!
Z
zeuz1980
Specs:
Gigabyte 3D Aurora OCZ GameXStream 700W A8N32-SLI
AMD X2 3800@2.6mhz (FX-60 speed)OCZ EL DDR PC-4000 2x1024MB Dual Channel Platinum 1xRaptor 74GD Maxtor 250G 16Mb2x7900GT SLI Voltmod 1.5v (670Mhz//1650Mhz) Acer AL1916W NEC DVD 5.1 Lochitech Audigy SE Lochitech MX510 ZBOARD Merc
Mods:
Swiftech custom wc!
Swiftech Apogee
Swiftech MC60 2x
Aquatuning Extreme Rad 240
4x Yate loon
Laing D5 Vario
1/2 inch ClearFlex60 tubing!
UV Reactive TEC
The theme was blue. Because the power supply have a blue-led, the case fan is blue. So the UV-reactive is also blue. I like the blue and black. A8N32-SLI is a black mobo. I hope you like mine WC setup to. ;)
Next update will be a sidewindow
The ClearFlex tubing is super!
EviLZeD
815 (0.12/day)
System Name Ez - 1st custom
Processor AMD Phenom x3 8450
Motherboard Asus m3a78-em
Cooling thermaltake mini typhoon :D aerogate fan controller
Memory 6gb corsair xms 2 800mhz ddr2
Video Card(s) xpertvision HD 4850 1GB ddr3 sonic 685/1000
Storage Corsair 128gb SSD, 2x 250GB maxtor 16mb cache raid 0, 500gb 32mb cache storage
Display(s) AMD surround view 2x e172fp 17" 1x dell e248wfp 24"
Case coolermaster elite 330
Audio Device(s) creative audigy se
Power Supply hiper type r 580watt
Software Windows 7 x64
nice but why dont you take a picture in the dark with the cathodes on :D?
Z
zeuz1980
I will try! But a make photo's with a mobile phone :( so they wont will pretty.
cdawall
where the hell are my stars
27,680 (4.19/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
2.6ghz on water? that it?
Z
zeuz1980
Yes it's a shame..I hit a wall at 2.6mhz. It doesn't matter how much volt I use, it doesn't oc futher. The positive on this that i can run 1:1 with the memory.
cdawall
27,680 (4.19/day)
Houston
Processor 2990WX
Software W10P
could be worse at least you didnt hit a wall at 2.4ghz
EviLZeD
815 (0.12/day)
its a great build 8/10
FanATIc
132 (0.02/day)
Gothemburg, Sweden
Processor C2D E6700ES stepping 5 rev B1 @ 3.2GHz
Motherboard Abit AW9D-MAX (bios 12)
Cooling Thermalright XP120+Revoltec 120mm red UV fan
Memory Corsair DomminatorTWIN2X6400C4D DDR2,2x1GB DHX E.P.P CL4-4-4-12T
Video Card(s) Sapphire X1950PRO+ Artic Cooling Accelero X2 @ 670MHz GPU
Storage Seagate Barracuda 7200.10 NCQ 160GB 16MB cache Sata II
Display(s) iiyama ProLite E1900S TFT19' 2ms
Case Akasa Eclipse 62
Audio Device(s) Creative SB X-FI Xtrememusic
Power Supply Tagan Easycon 580W
Software Win XP MCE .:original:.
Great machine!!!!
Lovely WC kit!!!
8/10
993 (0.15/day)
Los Angeles...U.S.A
Processor i7 920
Motherboard EVGA X58
Cooling eight 120mm fans, Swiftech GTZ cpu block, 3 120mm radiator, MCP655 pump, primochill tubing
Memory 6 gig G-Skill DDR3 1600
Video Card(s) GTX 285's (SLI)
Storage 500GB Western Digital
Display(s) 3 Asus 23 in inchers
Case Lian Li A77B
Audio Device(s) on board 7.1
Power Supply Corsair 1000
Software win 7 64
Jesus Christ! Nice job on the watercooling!! Nice looking machine 9/10 from me
Z
zeuz1980
Tnx guy's for you're feedback!
I have made another update.
There are some score's no and I have turned the intake/outtake @ the apogee. Because the air bubbels.
RickDStik
102 (0.02/day)
Processor Core2Quad q6600 (389x9)
Motherboard Asus P5Q-EM
Cooling Zalman 8000
Memory 4GB DDR2-800
Video Card(s) GeForce 7900GS
Storage 4xWD250JS RAID0
Display(s) Dell 24"
Case Aspire Q-pack
Power Supply TT 650w
Software Vista Ultimate
Your 3dm05 score is weird ... with your 06 score being as good as it is, 05 should have been higher than that I would think.
Z
zeuz1980
I dont get it over the 14k, I use the 91.47 drivers.
This driver is the best for me system, other drivers set me back 1k!
