System advice for new gamer
  • Thread starter Deleted member 74752
  • Start date
Seeking input on a new build for gaming. Items in cart...
Ryzen 7 3700X
Asrock B550 Phantom Gaming mb
Noctua NH-D15 cooler
EVGA SuperNova 850w Gold psu
Powercolor Red Devil Radeon Rx 5700 XT
No plans for any serious overclocking. Will a 850w psu take care of these parts easily? Thanks!
1,335 (0.36/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | Koss KSC75
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Tiny11 Windows 11 Education 24H2 x64
Even 650W would be enough imo
  • Like
Reactions: Rei
941 (0.45/day)
The New England region of the United States
System Name Gaming Rig
Processor Ryzen 7 3800X
Motherboard Gigabyte X570 Aurus Pro Wifi
Cooling Noctua NH-D15 chromax.black
Memory 32GB(2x16GB) Patriot Viper DDR4-3200C16
Storage Samsung 970 EVO Plus 1TB (Boot/OS)|Hynix Platinum P41 2TB (Games)
Display(s) Gigabyte G27F
Case Corsair Graphite 600T w/mesh side
Audio Device(s) Logitech Z625 2.1 | cheapo gaming headset when mic is needed
Power Supply Corsair HX850i
Mouse Redragon M808-KS Storm Pro (Great Value)
Keyboard Redragon K512 Shiva replaced a Corsair K70 Lux - Blue on Black
VR HMD Nope
Software Windows 11 Pro x64
Benchmark Scores Nope
Way overkill actually, you'll need 500Watts max. It doesn't hurt to go a little overboard but around 75% to 80% of peak gets you optimal power efficiency depending on the power supply. Unless you are planning on a major hardware upgrade to a big fat video card and a 5950x, I wouldn't go with more than 600-650Watts. The manufacturer is the most important factor in power supplies. EVGA tends to do a nice job. Spend the money saved on a better motherboard, more RAM or a faster SSD.
Thanks folks - It appears that particular mb is just average for sure...thinking it will suffice for gaming duties only. Don't imagine ever upgrading the cpu unless it dies. It's impossible to find a decent video card right now...hoping the 5700 XT will hold up for awhile. SSD and 32gb of memory already in the works. This will likely be my last build, at least as far as gaming goes.
Perhaps a better mb for a modest increase in price? https://www.newegg.com/msi-mpg-b550-gaming-carbon-wifi/p/N82E16813144322?Item=N82E16813144322
5,560 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
2,250 (1.15/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
you dont need a 850w for that system, could also opt for a 5600xt if its for gaming.
i'd opt for a nice 650w for that system.
what resolution are you playing at?
how much money are you going to spend?
2,716 (0.54/day)
Greece
Motherboard MSI B550 Tomahawk
Cooling ZALMAN CNPS9X OPTIMA
Case SHARKOON M25-W 7.1 BLACK
Keyboard Trust GXT280
PSU with 600W of silver or above quality is more than enough even if you upgrade later the CPU to R9 5950X. 5700XT is good enough for 1440P gaming also. As for the motherboard there are better choices for the same money. Check a video about that:
Toothless
Tech, Games, and TPU!
9,653 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
1,192 (0.28/day)
Processor 11700
Motherboard TUF z590
Memory G.Skill 32gb 3600mhz
Video Card(s) ROG Vega 56
Case Deepcool
Power Supply RM 850
That EVGA is a very good psu it will take care of your system easily and it will leave room for future upgrades.
I've seen three builds with that board and it's the only ASUS product I recommend. Solid board.
Seeing as how nearly all of these parts are already dated I can't justify spending much more than this on a motherboard. I'll go with the Asus mb and leave everything else as planned. Hopefully all these pieces will last a good long time. :toast:
6,966 (3.03/day)
California
System Name His & Hers
Storage lots of SSD.
What resolution do you game at? The 5700XT is the part that will struggle the soonest depending on what you game at if 1080p you'll be golden for a while.
Toothless
9,653 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
It's one of the best x570 boards for the price. The option to bump to a 5800x or higher down the line makes it more worth it.
I have a similar setup as what you picked out and it runs oh so good. I hope you didn't forget ram.
Yes, 1080p. The 5700XT will show it's age before anything else, but I don't game online often enough anymore for it to be a real struggle. It will have a WD 1T NVMe along with a WD 1T HDD and 32GB of 3200 memory. Thanks to all for the input.
6,966 (3.03/day)
California
It'll be very good at 1080p for a while and other than RT you aren't missing much from newer generations. While a 3060 ti would be much better they seem pretty impossible to get right now so you definitely could do worse than a 5700XT.
9,373 (3.39/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
At 1080P you will be getting up to 200 FPS in almost every game in high settings
6,966 (3.03/day)
California
So you are saying he's gonna gain nearly 70% more performance just slightly lowering settings........ I want some of them drugs you on bruh.
5,560 (1.02/day)
Gougeland (NZ)
Maybe playing Skyrim SE vanilla or older games but that's about it
