SYSTEM_SERVICE_EXCEPTION 0x0000003b
1,707 (0.54/day)
System Name The Blind Grim Reaper
Processor Xeon X5675 Westmere-EP B1 SLBYL 4.20ghz @ 1.256v
Motherboard Asus P6X58D-E
Cooling Noctua CP12 SE14, Redux Noctua 1500rpm fan Arctic F14 x3 for intake and exhaust
Memory Corsair XMS3 CMX4GX3M2A1600C9 x6
Video Card(s) EVGA GTX 1060 6GB SC Single Fan Model
Storage Crucial mx300 750gb main system + 1TB mx500 for games and music
Display(s) 22 inch samsung curved
Case NZXT Phantom 530 black
Audio Device(s) Nvidia HDMI through HDMI adaptor for output sound for turtlebeach x12 headset
Power Supply Antec HCG 850 watt
Mouse no brand
Keyboard normal usb keyboard
Software Windows 10 22H2 v1 (main is) and Windows 11 22H2 v2 on WD 250gb 7200rpm (testing purposes os)
Benchmark Scores Cinebench R20 = 2046cb
Hey everyone i have an issue that causes the 0x0000003b SYSTEM_SERVICE_EXCEPTION as im overclocking Xeon e5450 @ 3.71ghz, ram freq is 991.5‬mhz fsb:dram ratio 5:6 on asus p5q pro it only happens during gaming. As i have the vcore 1.304v, pll 1.60v, vtt 1.42v ram 2.20v, northbridge 1.62v, southbridge 1.30vThere's little information about the bsod codes for the 775 motherboard. The dimms are fully populated 4x 2gb Gskill F2-8500cl5-2gbpk. Do let me know if i need to increase or decrease each voltage as it would be helpful
622 (0.09/day)
Oak Ridge, TN
System Name BorgX79
Processor i7-3930k 6/12cores@4.4GHz
Motherboard Sabertoothx79
Cooling Capitan 360
Memory Muhskin DDR3-1866
Video Card(s) Sapphire R480 8GB
Storage Chronos SSD
Display(s) 3x VW266H
Case Ching Mien 600
Audio Device(s) Realtek
Power Supply Cooler Master 1000W Silent Pro
Mouse Logitech G900
Keyboard Rosewill RK-1000
Software Win7x64
Generally, that's a driver problem where the driver released some memory, and then reallocated and tried to use it.
If the reallocate thread runs faster than the release process thread, Boom, it crashes.
I usually only see this with driver code I write; see if you can narrow it down to which driver.
If it's the game itself, crank the memory down, and see if it goes away.
I have that processor running in XP32 at 4.6GHz, so I doubt it's the processor OC.
I'm using a P6TD Deluxe. (x58 chipset)
2,100 (0.48/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Bad driver. ;)
1,707 (0.54/day)
Mouse no brand
060519-8250-01.dmp
05/06/2019 00:16:24
0x0000003b
fffff807`3bcb90d0
ntoskrnl.exe
NT Kernel & System
Microsoft® Windows® Operating System
17763 05/06/2019 00:18:15
this is what i got through blue screen view as it on windows 10 1803 all drivers and bios are updated to the latest. I disabled the onboard audio on the motherboard as i know realtek sometimes cause problems before as i run the sound through asus gtx 1050 ti oc expedition through the hdmi cable into a hdmi passthrough box that have 3.5mm headphone jack. Everything is clean and has fresh mx-4 thermal paste so cooling isnt a problem. There was the same error as above with this win32kbase.sys, and mmcss.sys as it just popped up last night about an hour and thirty mins in resident evil 2 remake.
As for drivers nvidia is on the latest 430.86 and for the asus p5q pro isnt the greatest for the drivers as i had to use windows 7 64bits drivers to work in windows 10 in order to get things working as im not sure how good or bad for generic drivers from microsoft drivers for an older motherboard as some features will be missing or defunct like example ahci sata drivers i dont know which is better intel or microsoft as i dont see any info if theres any improvement between the two...
If there's anything else i need to do to fix this problem im having do please let me know as i be happy to tinker anything to fix this as i be up for the night
2,100 (0.48/day)
Spencerport NY
System Name Master
Best guess is W10 doesn't like your W7 drivers.
1,707 (0.54/day)
Mouse no brand
As theres no conflict in the drivers so windows 10 isnt having an issue with windows 7 drivers so it must be something in the bios causing this
It must be nvidia driver as the second last driver was flawless was able to play for 4 hours straight without crashing might try that later tonight see if that works
1,707 (0.54/day)
Mouse no brand
Yea latest nvidia driver causing the 0x3b error so i rolled back the 430.64 driver no crashing since
