Take Your Define R6 to Another Level with the Connect D1 and Flex VRC-25 Add-ons
889 (0.34/day)
To complement the release of the highly anticipated new Define R6, Fractal Design announces two accompanying accessories to even further expand the capabilities of the new case, both visually and technologically. The Connect D1 upgrade kit enhances speed and convenience with full USB 3.1 Gen 2 support and the latest Type-C connector. The Connect D1, available for purchase in early 2018, enables fast charging and blazing 10Gbps transfer speeds on compatible motherboards and devices with hassle-free bidirectional Type-C connections.
The Flex VRC-25 offers a unique step-up in style as a vertical PCI-E riser card and extender, making your graphics card the outward facing centerpiece of your build. Coming late January, R6 owners can free their GPU from the bounds of traditional mounting with confidence knowing the Flex VCR-25 is stress-tested for guaranteed stable, uncompromised performance. The Flex VCR-25's patented shielded overlap cable and riser card solution is specially fitted with custom standoffs for the Define R6, ensuring every installation is as clean-looking, reliable and rock-solid as the case itself.
Flex VRC-25 Key Features
  • Full PCI Express 3.0 support offering uncompromised performance for high-powered GPUs
  • Patented shielded overlap cable structure guarantees maximum transmission speed and stability
  • Extra-long 210mm heavy gauge ribbon cable is both durable and flexible
  • Right angle adapter with rigid PCB and standoffs enable a secure vertical mounting solution
  • Stylized black cabling with color-matched premium black PCB substrate
  • Flexible and extended PCI Express slot with 16x/8x/4x/1x compatibility
  • Heavy-duty double-sided wiring delivers up to 3x the power of traditional riser cables (auxiliary power connections are recommended for devices over 40W TDP)
  • Designed for use with all Define R6 Series cases
Connect D1 Key Features
  • Full USB 3.1 Gen 2 support with up to 10Gbps transfer speeds
  • USB Fast charging support with compatible motherboards and devices
  • Reversible USB Type-C port, allowing fast and easy connection every time
  • Replacement I/O shells for Black, Blackout, White, and Gunmetal included
Availability
  • Flex VRC - Late January 2018
  • Connect D1 - Q1 2018
MSRP
  • Flex VRC-25 USD39.99
  • Connect D1 USD29.99
5,717 (0.93/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Display(s) 32'' 4K Dell
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 P
I wonder whether the USB panel would be backwards compatible with Define R5
16 (0.00/day)
Norwalk, CA, USA
System Name Pending (Still thinking)
Processor AMD Ryzen 7 1700x
Motherboard Asrock Taichi X370 Bios P4.70
Cooling Cryorig H7
Memory 2 x 16GB G.Skill DDR4 @ 2400
Video Card(s) Asus DirectCUII R9 290x
Storage Crucial MX300 1.05TB M.Sata and 3 x 2TB Seagate HDD
Display(s) BenQ GW2765HT
Case Fractal Define R5 Blackout
Audio Device(s) Realtek ALC 1220
Power Supply Evga Supernova G2 850w
Mouse Logitech G203
Keyboard IBM Model M
Benchmark Scores Pending (Waiting for more mature bios updates)
Looking at my own R5, the power button/usb panel is fused to the front panel. So, nope not compatible.
Mentando
2 (0.00/day)
Looking at my Define S, it looks like it could fit, if you are willing to drill the screw holes yourself. Maybe you would also have to dremel some of the front panel, since it seems to be a little wider than the normal assembly.
184 (0.06/day)
7,762 (2.78/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
I won't be greeting an R6 (I already think my R4 is far too big), but if I ever make the scratch built SFF case I'm sketching out, that front panel piece would be a shoo-in. Would make front IO and everything else oh so simple.
472 (0.10/day)
Processor i5-13500
Motherboard MSI MAG B760 Tomahawk WiFi DDR4
Cooling Thermalright Peerless Assassin 120 White
Memory Corsair Vengeance LPX 4x8GB 3200
Video Card(s) EVGA RTX3060 12GB
Storage 250GB NVME (main) 1TB SSD (Game) 1TB HDD (Storage) 2TB HDD (ext Backup)
Display(s) Benq 27" GW2765 + Asus 27" VE278 + 55" Hisense
Case Cougar MX600 White
Audio Device(s) Audiotrack Prodigy Cube DAC + Edifer S330D + Plantronics RIG 400
Power Supply Corsair AX760
Mouse Logitech G403 Hero
Keyboard EVGA Z15 Brown Tactile (Blue Oring, Lube, Silence Pad)
One of the good thing about those panels is that you can buy it if you build a custom case.
6,263 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
$30 friggin bucks for something that should have been installed on the case by default, wow what a prize Fractal, thanks but no thanks. And all you get is ONE (1) USB-C port, ouch......
1,162 (0.21/day)
Chicago, Illinois
Well not everyone wants it and it would have added to the price. This makes sense to me.
6,263 (1.53/day)
Motherboard AZW SEI
Well, if they are selling it for $30 as an add on, then they are obviously mass producing them, which means their actual cost is around $10 at most, so for people who are gonna buy the case anyways, I seriously doubt another $10-15 would matter much....
And why would anyone considering buying a new case NOT want it to contain current-generation I/O capabilities ????
And Fyi, I just bought a 2x USB-C + 2x 3.0 bay device for my son's computer for $20......
1,162 (0.21/day)
Chicago, Illinois
Well then this is a better deal. This has seven ports total for $30, you paid $20 for a total of four ports. Anyhow, not too many cases have USB C ports . Sure it would be nice to have but it's definitely not a deal breaker for me or most people I would imagine. Fractal has always been a great bang for your buck brand. $10-$20 or even $30 on top does affect sales considering the price point they're in.
