TEAMGROUP Releases 3600 MHz DDR4 SO-DIMM for Gaming Laptops
W1zzard
Administrator
28,020 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
With the rapid growth of the global eSports economy, the gaming laptop market is getting hotter and hotter. TEAMGROUP's gaming brand, T-FORCE releases VULCAN DDR4 3600 MHz memory module exclusively for gaming laptop. The clock frequency is as high as the maximum performance of DDR4 3600 MHz. The capacity of the memory module is up to 32 GB (16 GBx2), which allows gamers to possess high speed performance and master the key to winning every gaming battle.
The T-FORCE series has swept the gaming world ever since its release. To meet the different demands for high end gaming equipment, the T-FORCE series today releases the exclusive memory module T-FORCE VULCAN for gaming laptop. It not only supports the 8th generation Intel Core processor, but it is also suitable for INTEL NUC platform. After many times of experiments, and testing combinations of different proportions of graphene and copper foil, the lightweight and thin graphene copper foil heat spreader design is tailor created by the R&D team. Long and rigorous internal laboratory test and burn-in test offer an outstanding 6% of cooling effect. In a closed space, VULCAN can maintain stability in low temperature and still offer high performance at the same time. The heat is transferred out efficiently to ensure the computer can still offer high performance with speed and stability under high speed operation. It is definitely the best choice for gaming laptop and mini PC.
T-FORCE VULCAN's ultra-low working voltage not only reduces electricity consumption and extends gaming laptop's battery life, but it can also reduce the heat generated by the operation of the system, so the system will not be unstable because of the high temperature. It also supports auto overclocking function. To immediately enjoy T-FORCE VULCAN's high performance experience, all it needs is to install on a DDR4 SO-DIMM system that supports overclocking. From now on, say goodbye to the complicated BIOS overclocking settings, and overclock in an easy and smart way.
17,503 (4.67/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
Does anyone know if the XMP profile on this ram would read correctly on my Clevo P670HS-G i7-7820hk gtx 1070 laptop?
I have 2133 and high timings on top of that... would love to upgrade to some nice ram. Probably would help this system a lot.
656 (0.15/day)
Good to see, many of the top end gaming laptops still come saddled with slow 2400Mhz DDR4, and whilst RAM speed won't transform your frame rates, it certainly helps in some titles, Witcher 3 for example sees gains of upto 10fps when running 3200Mhz Ram compared to 2400Mhz.
Every little bit helps.
6,829 (1.40/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
G-Skill are still the champions. Just look at the same timings for 50% Freq increase.
14,196 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
Do they have the low voltage (1.2v) So-Dimms at those timings?
6,829 (1.40/day)
