Technical Issues - TPU Main Site & Forum (2022)
Status
Not open for further replies.
979 (0.42/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
Is it just me or is the TPU logo on the homepage faded?
Forum
3,039 (0.53/day)
MN
System Name Personal / HTPC
Forum
I get the same thing while using Dark Reader extension in Chrome, but only when I have the dark theme active. When I turn off the Dark Reader extension the logo looks the normal red color.
I cleared out my cache and cookies, but the issue remains while using Dark Reader extension.
Dark Reader active:
Dark Reader inactive:
979 (0.42/day)
Yes it was Dark reader I should have posted an update. I discovered that shortly after @lexluthermiester posted he was not seeing the same thing.
3,039 (0.53/day)
MN
The odd thing is, the TPU logo looks correct when I'm on the Forums main page, but all the other main pages the logo is washed out.
Forums = looks correct
Home, Reviews, Downloads, Case Mod Gallery = logo looks washed out
29,358 (6.90/day)
Dark Reader active:
I'm also using Darkreader, as my screenshot show clearly. That's not the problem. Have you updated DarkReader recently? Also, I'm on FireFox.
979 (0.42/day)
Yes on FF it auto updated 3 days ago. Ver 4.9.58 If I turn Darkreader off then the logo is fine on the Main page. Not too much of a concern its fine if its pink not red. :laugh:
1,317 (1.48/day)
Weird. Regardless, this doesn't seem to be a problem with TPU directly. Seems like it's completely plugin related.
Agree. It appears to be Dark Reader's theme generation mode setting. Changing from Dynamic to Static restores the TPU logo SVG to it's normal solid red. DR has this to say about the default Dynamic mode:
Dynamic deeply analyzes website stylesheets, background images, and vector graphics. Requires some resources on initial page load, but produces the best visual results. The work on this mode is in progress, but it already works well for many modern websites.
For reference:
W1zzard
Administrator
28,292 (3.73/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Database failed while I was sleeping and the monitoring scripts didn't detect the error, so the instance didn't get restarted
Edit: Found a bug in code that I've written more than 10 years ago. It catches the error in the database but flags the resulting request as success (HTTP code 200) and not as failure (HTTP code 500), so our monitoring scripts couldn't catch it.
3,039 (0.53/day)
MN
Issues attaching pictures to posts using Insert Image (Ctrl+P). Getting a oops, ran into a problem pop-up.
Also, when I download the latest version of GPU-Z from TPU, Chrome tells me that the file "may be dangerous". (I wanted to post a picture of this, but that's when I found I kept getting the server error when I tried to attach an image).
3,127 (2.32/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
I downloaded the new GPU-Z a few minutes ago with no issues. I did this on a Windows 10 PC with a Chromium based browser.
However I tried to attach an image to this reply and I also got the server error.
W1zzard
Administrator
28,292 (3.73/day)
Memory 48 GB
may be dangerous
I think this happens when a file is brand-new, just released
Image upload should be fixed now, please confirm
Thanks for reporting this
3,127 (2.32/day)
Here's an upload test.
Looks like it's fixed.
Mussels
Freshwater Moderator
58,412 (7.84/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Sometimes when i copy paste or cut and paste with quotes, the quotes work and othertimes they do not
Any idea wth is going on there? I *could* use the in-forum quoting system but it's more clicks overall
3,023 (1.15/day)
System Name System V
Processor AMD Ryzen 7 9700X
Case NZXT Source 210
Not exactly an issue, but might be worth the observation anyway, a bit of slow speeds when downloading GPU-Z from TPU's US-5 server, even though its load was low.
trace in case it's of any use
EDIT: Nevermind, whatever it was seems to be fixed.
3,448 (1.69/day)
Power Supply Corsair RM750x
Mouse Logitech M575
3,023 (1.15/day)
243 (0.04/day)
Zagreb, Croatia
System Name My main PC - C2D
Processor Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan
Motherboard Gigabyte GA-P35-DS3R (Intel P35 + ICH9R chipset, socket 775)
Cooling Scythe Ninja rev.B + 120mm fan | 250mm case fan on side | 120mm PSU fan
Memory 4x 1GB Kingmax MARS DDR2 800 CL5
Video Card(s) Sapphire ATi Radeon HD4890
Storage Seagate Barracuda 7200.11 250GB SATAII, 16MB cache, 7200 rpm
Display(s) Samsung SyncMaster 757DFX, 17“ CRT, max: 1920x1440 @64Hz
Case Aplus CS-188AF case with 250mm side fan
Audio Device(s) Realtek ALC889A onboard 7.1, with Logitech X-540 5.1 speakers
Power Supply Chieftec 450W (GPS450AA-101A) /w 120mm fan
Software Windows XP Professional SP3 32bit / Windows 7 Beta1 64bit (dual boot)
Benchmark Scores none
Not tech issue but Oct 6th list of links on homepage wants to poke my eye out with:
"Processors
Intel Ryzen 5 7600X and Ryzen 9 7900X NikkTech"
... Pls fix tnx
Mussels
58,412 (7.84/day)
Oystralia
"Processors
... Pls fix tnx
Woops, must be a bug on our AMD pentium servers hosting the database
W1zzard
Administrator
28,292 (3.73/day)
Memory 48 GB
"Processors
... Pls fix tnx
Fixed, thanks!
18,584 (2.66/day)
System Name AlderLake
Just for about a minute or so:
stinger608
11,250 (1.89/day)
Wyoming
System Name 2023 Ryzenfall
Processor AMD Ryzen 5800X
Cooling SilverStone AH240 AIO
Case Corsair Air 540
Audio Device(s) On board
Hmm, haven't had that issue today @P4-630
Status
