TechPowerUp GPU-Z 2.32.0 Releases: Cutting-Edge New Features
47,186 (7.56/day)
TechPowerUp today released the latest version of GPU-Z, the popular graphics subsystem information, diagnostic, and monitoring utility. Version 2.32.0 introduces a wealth of new cutting edge features. To begin with, we enabled a large selection of new per-rail power sensors for NVIDIA GPUs, including the ability to tell power draw per specific PCIe power connector, power draw at the PCIe slot, power draw from the USB-C port (VirtualLink port), and GPU ASIC-only power draw, among a wealth of other new sensors.
We also introduced the ability to tell the Q0 stepping of Intel "Comet Lake-S" Core desktop processors apart from the G1 stepping. This feature should be particularly useful when re-selling your 10th gen Core processors that have multiple steppings, as you can use the GPU-Z Database validation or screenshot as proof of stepping to a prospective buyer. Among the new GPUs and CPUs supported are Intel 10th gen Core, AMD Radeon Pro W5700X, WX 4170; NVIDIA GeForce GTX 1650 Ti (mobile), and Tesla V100S-PCIe 32 GB. Support is also added for Windows 10 May 2020 Update. We fixed the WDDM 2.7 hardware-accelerated GPU scheduling readout in the "Advanced" tab for AMD graphics cards. Grab TechPowerUp GPU-Z 2.32.0 from the link below.
DOWNLOAD: TechPowerUp GPU-Z 2.32.0
The change-log follows.
  • Added NVIDIA per-rail voltage and power monitoring
  • Fixed WDDM 2.7 Hardware Accelerated GPU Scheduling readout in Advanced Tab to report "Disabled, not supported" instead of "Unknown (8)" on Windows 10 2004 with AMD graphics card
  • Added support for Intel Comet Lake 10th Generation CPUs
  • Added support for AMD Radeon Pro W5700X, WX 4170
  • Added support for GTX 1650 Ti Mobile (TU116-A), NVIDIA Tesla V100S-PCIE-32 GB
540 (0.08/day)
System Name Ed-PC
Processor Intel i5-12600k
Motherboard Asus TUF Z690 PLUS Wifi D4
Cooling Noctua NH-14S
Memory Crucial Ballistix DDR4 C16@3600 16GB
Video Card(s) Nvidia MSI 970
Storage Samsung 980, 860evo
Case Lian Li Lancool II mesh Perf
Power Supply Corsair RM750x
Software Win10 Pro 64bit
Wow, nice work, slot wattage, voltage readings for PCI-E rails and slot would have been really helpful back when moding 970 power tables in the bios, still are very helpful with locked bios too.
95Viper
Super Moderator
12,944 (2.21/day)
Ditto... Thanks Wizzard!
Works great... no problems.
ARF
4,670 (2.68/day)
Ex-usa | slava the trolls
Unfortunately, it doesn't read the Pixel and Texture Fillrates and GPU Clock on Vega 8.
W1zzard
Administrator
27,719 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
26 (0.01/day)
"We also introduced the ability to tell the Q0 stepping of Intel "Comet Lake-S" Core desktop processors apart from the G1 stepping. This feature should be particularly useful when re-selling your 10th gen Core processors that have multiple steppings, as you can use the GPU-Z Database validation or screenshot as proof of stepping to a prospective buyer "
Where is that?
ARF
4,670 (2.68/day)
Can you get me the top part of the window too?
Yes, of course :)
There are several different readings there.
Is Vulkan not supported on this iGPU?
8,202 (3.93/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Same thing, old 2700U here. Screenshot if it helps!
Old driver, I'll update now and see if that does what ARFs does....
UPDATE:
Adrenaline 20.5.1 installed, no change.
W1zzard
Administrator
27,719 (3.70/day)
Memory 48 GB
Check if you can run some sort of Vulkan demo, GPU Caps Viewer should have some.
Cheeseball
Not a Potato
1,981 (0.34/day)
Pittsburgh, PA
System Name Titan
Video Card(s) ASRock Radeon RX 7900 XTX 24 GB GDDR6 (MBA) / NVIDIA RTX 4090 Founder's Edition
Storage Crucial T500 2TB x 3
Case HYTE Hakos Baelz Y60
Power Supply Corsair SF1000L
Keyboard Wooting 60HE+ / 8BitDo Retro Mechanical Keyboard (N Edition) / NuPhy Air75 v2
VR HMD Occulus Quest 2 128GB
Software Windows 11 Pro 64-bit 23H2 Build 22631.4317
What 2080 Super OEM is that in your first screenshot?
5,470 (1.05/day)
This update is kind of insane, especially for some of us who can easily use that power monitoring for other things.
Thank you, based W1zzard.
740 (0.22/day)
System Name Harm's Rig's
Processor 5950X /2700x / AMD 8370e 4500
Motherboard ASUS DARK HERO / ASRock B550 Phantom Gaming 4
Cooling Arctic Liquid Freezer III 420 Push/Pull -6 Noctua NF-A14 i and 6 Noctua NF-A14 i Meshify 2 XL
Memory Patriot Viper Steel DDR4 16GB (4x 8GB) 4000M TRIDENT Z F-43600V15D-16GTZ /G.SKILL DDR4
Video Card(s) ZOTAC AMP EXTREME AIRO 4090 / 1080 Ti /290X CFX
Storage SAMSUNG 980 PRO SSD 1TB/ WD DARK 770 2TB , Sabrent NVMe 512GB / 1 SSD 250GB / 1 HHD 3 TB
Display(s) Thermal Grizzly WireView / TCL 646 55 TV / 50 Xfinity Hisense A6 XUMO TV
Case Meshify 2 XL- TT 37 VIEW 200MM'S-ARTIC P14MAX
Audio Device(s) Sharp Aquos
Power Supply FSP Hydro PTM PRO 1200W ATX 3.0 PCI-E GEN-5 80 Plus Platinum - EVGA 1300G2/Corsair w750
Mouse G502
Keyboard G413
Cool!
jtalll
1 (0.00/day)
Win10 2004
NV 450.99
2080 ti
DX12 Mesh Shaders Supported NO??
712 (0.22/day)
Croatia
Processor Ryzen 5 3600 PRO
Motherboard AsRock B450 Pro4
Cooling Thermalright Peerless Assassin 120
Memory Silicon Power XPower Zenith 2x8GB @3200 MHz
Video Card(s) Gigabyte RTX 2070 Super Gaming OC 8GB
Storage Crucial P5 Plus 1TB / Crucial MX 500 1TB
Display(s) Dell P2419H
Case Fractal Design Pop Air /w 3x Thermalright TL-C12C
Audio Device(s) Creative Sound Blaster Z + Edifier R1000T4
Power Supply Super Flower Leadex III 650W
Mouse Microsoft Intelimouse Pro
Keyboard IBM KB-8926
Benchmark Scores Turns on on the first try! Usually.
Something looks off with power usage, this is on idle.
and this is on load (PCI-e render test).
Power draw and especially voltages seem off, this is on both latest driver and 445.87. The card performs as it should otherwise.
14,061 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Where is that?
Integrated GPU, look at the stepping code.
Shown in this pic as Revision Code.
W1zzard
Administrator
27,719 (3.70/day)
Memory 48 GB
It seems mesh shaders aren't supported yet by NVIDIA. Are you aware of any demo that can actually test this?
working as intended?
Power consumption % TDP seeems to be stuck at 0, too. Maybe that 1050 doesn't have board power measurement circuitry?
2,248 (1.03/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
thats grand work chaps, thank you very much, ill be playing with it today :)
30 (0.01/day)
System Name CyberDyne Systems
Processor AMD 7800X3D
Motherboard Asus ROG STRIX B650E-E Wifi
Cooling Alphacool Eisbaer Aurora HPE 360 mm
Memory 32 GB G Skill Flare X5 F5-6000J3038F16GX2-FX5
Video Card(s) Nvidia 4090FE
Storage WD Black SN850X 1 TB, WD Black SN850X HS 2 TB, WD Black SN770 2 TB
Display(s) Alienware AW3821DW 3840x1600 144 Hz
Case ThermalTake Core P3 TG Pro
Audio Device(s) Onboard Realtek ALC4080 Corsair SP2500
Power Supply Asus Thor 1000W
Mouse Razer Viper Ultimate CyberPunk 2077
Keyboard Corsair K65 LUX RGB
Software Win11 Pro
Hmm..
In your case it seems that the "Board power draw" is the sum of the power draw of the two 6/8 pin connectors plus the pci-e slot (174.5+75.6+47.8=297.9 W) and the GPU consumes a big fraction (210.4 W) of that. Like one would expect.
In my case it looks like the GPU consumes (16.2 W) more power than the complete board (13.6 W)?
This is on idle tough.
1,891 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
Shouldn't 12V voltages be the same across all 12V lines ?
3,808 (0.58/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Wow lots of drop down options under the advanced tab!!
Everything seems as it should for my RX 480
5,535 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
Ok so what is needed to support this WDDM 2.7 hardware-accelerated GPU scheduling other than Windows 10 pro x64 2004 and radeon 20.5.1 drivers
