TechPowerUp NVCleanstall v1.15.0 Released
47,300 (7.53/day)
TechPowerUp today released the latest version of TechPowerUp NVCleanstall, a handy utility that lets you take greater control over your NVIDIA GeForce software installation. NVCleanstall lets you disable stuff you probably don't need, such as Telemetry, or legacy components, giving your PC a leaner set of system software from NVIDIA. Version 1.15.0 introduces several handy changes. To begin with, the title screen shows whether the currently installed driver is a Studio driver (optimized for creators). A crash during the background update check for new NVIDIA drivers has been fixed.
We've added two more installer tweaks with this release. The first one lets you disable Multiplane Overlay (MPO)—doing so is known to fix certain rare system stuttering issues. Another tweak lets you disable the NVENC concurrent session encoding limits, so you can encode more than two streams in parallel. This tweak uses keylase's patch scripts from GitHub. The "build package" option has been improved to ensure it runs well on systems with more than 20 CPU cores, and better error reporting has been added. Grab TechPowerUp NVCleanstall v1.15.0 from the link below.
DOWNLOAD: TechPowerUp NVCleanstall 1.15.0
  • Title screen now shows whether the installed driver is a Studio Driver
  • Fixed crash during background driver update check
  • Added tweaks option to disable Multiplane Overlay (MPO)
  • Added tweaks option to remove NVENC concurrent session encoding limit (github.com/keylase/nvidia-patch)
  • Improved error reporting for "Build Package" option
  • Build Package compression is now limited to 20 threads, to avoid out of memory errors
  • Build Package now displays its output while running
Update 23:29 UTC: Updated the download to 1.15.1, to fix an issue with MPO and NVENC patch
68 (0.02/day)
Is this different than the widely know method of deleting all unnecessary stuff from extracted driver package (and removing EULA lines in inf file) then installing?
6,881 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
Great handy tool.
1,936 (0.47/day)
Yes. This has options that deleting and modifying existing installer files wont offer.
Tremolo4
8 (0.01/day)
I got an error message box after the installation finished. Something like "Failed to set Multipane status". I forgot to take a screenshot. Laptop with GTX 1060 and Optimus. I have not enabled any of the tweaks IIRC. Just installing the "Recommended" variant.
3,330 (1.08/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Same. It's for MPO. I get this message even when I don't touch the advanced disable MPO setting.
36 (0.05/day)
System Name Speed Demon 2.0
Processor i7 13700k
Motherboard ASUS ROG Strix Z690-E Gaming WiFi 6E
Cooling EK Supremacy Nickle, 2 x Magicool Elegant 360mm Copper Radiators
Memory Team T-Force Delta RGB 32GB DDR5 7200 (PC5 57600)
Video Card(s) MSI 3080-TI Air Cooled
Storage Corsair Gen4 MP600 + Multiple Samsung Gen 3
Display(s) Dell 32 Inch - S3222DGM & Dell G2422HS 23.8" Portrait
Case CaseLabs Mercury S8
Audio Device(s) SONOS
Power Supply Seasonic Focus PX-850 850W 80+ Platinum
Mouse MADCATZ R.A.T. 8+
Keyboard Logitech ‑ MX Mechanical
I never saw an option to lets you disable Multiplane Overlay (MPO)?
3,330 (1.08/day)
Storage Too much
Mouse G305
VR HMD Valve Index
Software Win 10
W1zzard
Administrator
27,964 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Solaris17
Super Dainty Moderator
27,083 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
So it checks in the background using the nvidia servers? or it can only check in the background and NOT contact nvidia?
W1zzard
Administrator
27,964 (3.71/day)
Memory 48 GB
Thanks! Did this bug leave any leftovers on my system that I should undo?
No
How is "without contacting NVIDIA servers" ambiguous ? It contacts our servers only. Suggestions how to reword? "does not contact NVIDIA servers" ?
Solaris17
27,083 (3.83/day)
Alabama
VR HMD Quest 3
I think it was just context. When I checked the box for installation it did not auto check the box shown. I may have simply confused myself under the assumption that if it was installed it would update without the need for me to interface in that manner.
That drove me to then question the function. I wasn’t understanding why you would install without the ability to pull updates to begin with which confused my understanding of the option.
W1zzard
Administrator
27,964 (3.71/day)
Memory 48 GB
If you get confused, others get confused, too. How would you reword it? I guess I could add a sentence or two if that helps
nRag3
8 (0.01/day)
I use this tool religiously and just wanted to thank the developer(s). :)
9,340 (5.28/day)
Louisiana
Keyboard G710+x3
Yeah I thought the driver update function was pretty clear :eek:
Solaris17
27,083 (3.83/day)
Alabama
VR HMD Quest 3
Changing it to "Will not contact" from "without contacting" in my case would remove my illusion of two different scenarios.
The "without" is probably what confused me, as I would read that as "If I dont check this box it will check for updates anyway, it will just contact nvidia. This box only toggles the upstream provider."
Changing it to "Will not contact" to me then reads "This box enables updates but it wont check nvidia servers."
Thats how I would automatically interpret the context. In my mind its clear only if you already know how it works, if you dont then the current working to me leaves an interpretation of two possibilities.
In my case I have never used nvcleaninstall so I am not aware of when or was part of the thread in which this option was implemented. So I had no idea what I was looking at.
If any of that makes sense.
79 (0.05/day)
Processor Ryzen 5 3600
Motherboard ASRock X470 Taichi
Memory G.SKILL 32GB DDR4 3200 CL16
Video Card(s) EVGA GeForce RTX 3070 FTW3 Ultra (1980 MHz / 0.968 V)
Display(s) Dell P2715Q; BenQ EX3501R; Panasonic TC-P55S60
Case Fractal Design Define R5
Audio Device(s) Sennheiser HD580; 64 Audio 1964-Q
Power Supply Seasonic SSR-650TR
Mouse Logitech G700s; Logitech G903
Keyboard Cooler Master QuickFire TK; Kinesis Advantage
VR HMD Quest 2
The wording gave me pause as well. I suggest changing it to "Periodically check TPU servers for driver updates" with no parenthetical.
1,520 (2.19/day)
France
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
Software EMDB
Benchmark Scores 0>1000
Is this a typo ? :
Metanoi4
1 (0.00/day)
Hi guys. After debloating nvidia driver I lost dynamic boost 2.0 support. Is there any option to select in the app to enable it again? RTX 3070 Mobile
