[Test Build] Fix for 576.02 Driver Install
W1zzard
Administrator
28,620 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Please test the attached build, it should be able to install the new 576.02 drivers normally, without any issues.
Also this builds adds a fallback to bypass our Cloudflare CDN in countries with censorship issues, like Russia and Spain
  • NVCleanstall_1.18.7.exe
Ahhzz
Super Moderator
9,193 (1.47/day)
System Name OrangeHaze / Silence
Processor i7-13700KF / i5-10400 /
Motherboard ROG STRIX Z690-E / MSI Z490 A-Pro Motherboard
Cooling Corsair H75 / TT ToughAir 510
Memory 64Gb GSkill Trident Z5 / 32GB Team Dark Za 3600
Video Card(s) Palit GeForce RTX 2070 / Sapphire R9 290 Vapor-X 4Gb
Storage Hynix Plat P41 2Tb\Samsung MZVL21 1Tb / Samsung 980 Pro 1Tb
Display(s) 22" Dell Wide/24" Asus
Case Lian Li PC-101 ATX custom mod / Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Mouse Logitech G502 Lightspeed Wireless / Logitech G502 Proteus Spectrum
Keyboard K68 RGB — CHERRY® MX Red
Software Win10 Pro \ RIP:Win 7 Ult 64 bit
Detected Trojan:Win32/Wacatac.C!ml
what security app flagged it?
pandaligx
12 (0.09/day)
May I ask if the NVIDIA Control Panel has been repaired, which appears when right-clicking on the desktop?:peace:
Ahhzz
Super Moderator
9,193 (1.47/day)
611 (2.21/day)
nvcp has been moved to system tray for quite some time, I think since nvapp release, you open both via system tray
Tasslehoff
3 (0.27/day)
Not according to VirusTotal...
I don't know about virustotal, maybe it has no records because the file is new and not yer recorded by their database, but I got this warning and the setup file quarantined.
Sorry for the OS language but I don't have time to change my OS locale to english right now, I think it's still quite understandable.
8 (0.00/day)
System Name Queen-18
Processor Ryzen 7 5800X
Motherboard MSI Tomahawk Max II
Cooling NH-U9S
Memory Crucial Ballistix DDR4 3600MHz PC4-28800 16GB 2x8GB CL16
Video Card(s) MSI 3070Ti VENTUS 3X 8G OC
Storage Emtec Power Pro X300 SSD 512GB // Seagate BarraCuda 3.5" 2TB SATA 3
Display(s) LG UltraGear 27GP850-B
Case Sharkoon Pure Steel Black
Audio Device(s) Philips Soundbar HTL2111A
Power Supply Corsair RM850 (2019)
Mouse Logitech M185
Software Windows 11 LTSC Iot
In my case it was not detected by Windows Defender.
With this build I was able to install the latest drivers [576.02] for my 3070 Ti.
Just notice that the name of the file is 1.18.1 and the window of the program shows 1.18.2 .
W1zzard
Administrator
28,620 (3.74/day)
Memory 48 GB
oops, that's a typo. let me reupload the file with teh correct name
SecureAge. An antivirus nobody has ever heard of
71 others are clean: https://www.virustotal.com/gui/file/bed59284e22fd62e3f99805e15852a144431e5d40e2669f1f1ceb28fff4bf66f
Check if the exe is digitally signed by TPU, which guarantees it hasn't been tampered with. Unless of course you don't trust me
Is this still happening? I can run it perfectly fine on my Windows 11 system with Defender enabled
2 (0.00/day)
Weird, for me (Win 10 with Defender), it flagged the 1.18.2 version too, but didn't flag the 1.18.1 version at first.
Also, it flagged the "setup.exe" in local appdata when I tried installing the driver. Virustotal also reports 13/72 detections (mostly AI based or "high confidence").
The behaviour analysis in their sandboxes does not look suspicious though...
Maybe the setup.exe inside NVCleanstall main program gets detected by MS Defender inspection if it is bundled?
W1zzard
Administrator
28,620 (3.74/day)
Memory 48 GB
Ah, that file didn't get signed without signature. The old one expired and I forgot to switch it to the new one. Build in first post updated with new build
meem55
9 (0.50/day)
Downloaded 1.18.2 to test.
My AV is Kaspersky Standard and it gives a Trusted notification when scanned.
With Kaspersky disabled and scanned with Defender, also no warning.
This on Windows 11 Pro 24H2 Dutch (26100.3775)
2 (0.00/day)
Very nice, 1.18.3 fixed MS Defender triggering.
When running it though, the first time it only uninstalled NVApp, but did not install anything (still old driver). I only ticked Display Driver, PhysX, and NVCP.
After running it again with the same setting, it installed the new driver successfully.
Chuggy
2 (0.20/day)
1.18.3 fixed the defender triggering :respect:. With the current settings I use, everything appears to work fine.
Windows 11 Pro 26100.3775.
2,167 (0.33/day)
Metro Manila, Philippines
System Name Zangief (Reborn) 2.0 AM4 not dead yet!
Processor AMD Ryzen R7 5700X3D (tweaked PBO)
Motherboard Gigabyte GA-AX370 Gaming K7 Rev 1.0 BIOS F53d
Cooling Noctua NH-D15 Push / Push Config | 2x ML120 | 2x Phanteks 120 mm
Memory 2x16GB G.Skill Trident Z Neo RGB @ 3600mhz CL 18 -> running 3800mhz @ 1.37v
Video Card(s) Asus RTX 3080 Rog Strix Gaming OC
Storage 250 GB Samsung Evo 850 / 1tb WD Black / 4tb WD Blue / 512GB Adata XPG Pro SX8200
Display(s) Acer Predator XB271HU |Asus VX239H 23" AH-IPS Led
Case Phanteks Enthoo Pro M TG
Audio Device(s) On Board Realtek HD | Steelseries Arctis Nova Pro Wireless
Power Supply Seasonic Focus GX V4 850 Watts ATX 3.1
Mouse Logitech G903
Keyboard AKKO 5098N (Otemu Cocoa Brown Lubed) | Tecware Spectre 96 (Akko Lavander Purple V3 lubed)
Software Windows 11 Pro 24H2
Install went fine on your latest update on 1st post. No problems here so far.
(Did not use the cloud flare bypass). Everything went smoothly.
Thanks!
W1zzard
Administrator
28,620 (3.74/day)
Memory 48 GB
no need unless you live in countries where censorship is blocking cloudflare, e.g russia and spain
30 (0.00/day)
3rd rock
System Name The Beast Mark A
Processor AMD Ryzen 9 3950X
Motherboard MSI MEG X570 GODLIKE (MS-7C34)
Cooling Arctic Liquid Freezer III 420 RGB
Memory Corsair Vengeance RGB Pro 128 GB (4 x 32 GB) DDR4-3600 CL18 Memory
Video Card(s) EVGA RTX 3080 Ti XC3 ULTRA GAMING (12G-P5-3955)
Storage 3x Samsung SSD 980 PRO 2TB, 3x Sabrent Rocket 4.0 1TB
Display(s) 3x ES07D03 (EVE0001)
Case Fractal Design Define 7 XL Dark
Audio Device(s) Onboard Realtek controller, SteelSeries Arctis Nova Pro Wireless, Heavys H1H
Power Supply PC Power & Cooling’s Silencer Series 1050 Watt, 80 Plus Platinum
Mouse Logitech MX Master 3S, MX Master 3 for Business
Keyboard SteelSeries Apex Pro (gen 1)
Software Windows 11 current (24H2, build 26100.3902)
I used the old 1.18 to make a build off 576.xx before seeing this thread, thankfully I didn't try to install it yet lol. Just downloaded 1.18.3 above to re-create the custom driver.
This is also on a completely clean install of Windows 11 24H2, also. Speaking of which - where does NVCleanStall save the settings (that can be pulled up by the 'use previous settings') when configuring the driver settings, @W1zzard?
W1zzard
Administrator
28,620 (3.74/day)
Memory 48 GB
HKEY_CURRENT_USER\Software\techPowerUp\NVCleanstall
30 (0.00/day)
3rd rock
Crap. I didn't copy anything from the registry on the previous build.
Oh, well. Guess I need to re-research some of those advanced settings again and see if I need them or not.
Cheers, and thanks for such a great utility and your continued development on it!
Question - if at all possible, can you build a function into the NVCleanStall app to export the settings to a local reg file for restoring when clean installing Windows?
Yes, I know how to easily do this myself - but I had no idea it was in the registry, instead assuming it was saved in a file somewhere in AppData lol. And I know it is a long shot ask, so not expecting a yes answer, and won't be mad if you say no.
Just asking, nothing more.
In the meantime I've had a problem and am trying again, if it still manifests I'll report here in a bit.
OK, running the 1.18.3 build, Checking driver only, then nvidia app, and accepting the addition of all the other components that nvidia app needs.
When I go to build the package, I've gotten this. Done it twice, slightly differing points of pkg building, but still, it is breaking.
First run:
Second run:
No sure what is going on.
@W1zzard
Windows 11 (Build 26100.3902)
NVCleanStall 1.18.3
System specs: https://valid.x86.fr/20gzlc
(128 GB RAM, 3x 2 TB Samsung 980 Pro NVMe SSDs...)
I've attached the options used to build below.
  • NVCleanStall-Options.zip
W1zzard
Administrator
28,620 (3.74/day)
Memory 48 GB
Just export from Regedit and import by double click or reg command
"Can't allocate memory" .. I think this is an issue due to the 32-bit build of 7zip used. Will check if there's any command line arguments to mitigate
30 (0.00/day)
3rd rock
@W1zzard Would it make a difference if I manually installed 7-zip x64 on my computer?
