[Test Build] Fix for installation not working with Nv App
W1zzard
Administrator
27,958 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Attached. It should "just work"
Selecting NvApp should also prompt you to also add the minimal dependencies required for NvApp to function.
Ignore the message about incompatibility at the start. I will change the code to hide the popup on newer builds
Please test and feedback
Update Dec 21: new build uploaded that hides the message about incompatiblity
  • NVCleanstall.exe
geezteem
2 (2.00/day)
the only thing that didn't work was, it didn't fully install the nvidia app program. i had to manually download it off the website again and reinstall the app
W1zzard
Administrator
27,958 (3.71/day)
Memory 48 GB
It didnt? You check just nvapp and display driver, it tells you „dependencies?“ click yes and it will select the minimum needed for working nvapp. At least that’s how i it
If that doesn’t help, could you provide steps to reproduce?
geezteem
2 (2.00/day)
mistake, its beacuse i didn't choose shadow play and continued without it , i think that caused it not to install the nvidia app and you need all its dependencies.
reason i didn't choose shadowplay is because i dont use it at all
your fix works fine. thats my bad
pandaligx
6 (0.55/day)
Has the missing right-click menu feature of the NVIDIA Control Panel after installation 566.36 been fixed?
W1zzard
Administrator
27,958 (3.71/day)
Memory 48 GB
Yes, I tested that specifically you MUST install ShadowPlay or the App will not launch
I've seen the control panel in my right click menu on desktop indeed. Can you test it?
