- Dec 23, 2018
- 377 (0.17/day)
System Name | Asus TUF Gaming FA506IU Laptop |
Processor | AMD Ryzen 7 4800H with Radeon Graphics |
Motherboard | AMD K17.6 FCH, AMD K17.6 IMC |
Cooling | Dual Fans Design with Self-Cleaning Cooling |
Memory | Samsung DRR4 - 3200Mhz 16GB(8GBx2) |
Video Card(s) | GeForce GTX 1660 Ti (6 GB) |
Storage | WDC PC SN530 SDBPNPZ-256G-1002 + SHGP31-500GM-2 + ST1000LM035-1RK172 |
Display(s) | LM156LF-2F03 144HZ Adaptive SYNC |
Audio Device(s) | Realtek ALC256 @ AMD K17.6 |
Power Supply | ASUS Power Brick 180W |
Mouse | ROG SICA Gaming Mouse |
Benchmark Scores | CineBench R23 Single core:- 1290 points CineBench R23 Multi core:- 11111 points |
Hello everyone, I need testers from laptop users who got Intel WiFi AX210/AX211 chip. If you like to know the benefits of modifying this driver please continue reading. All I need from you is to provide a screenshot of your HWID from device manager like this to help me provide support for all Intel AX210/AX211 variants since they got Multiple HWID's with the same name.
I can do it also for AX1650 bec. they share the same HW spec.... so I can do AX1650 & upgrade the driver to be a AX1690 bec. they also share the HW spec...
Here's an example of what I need...
I have managed to convert WiFi chip from Intel AX211 to a AX411 since both have the exact hardware spec. Intel applied arbitrary limitations to AX211 WiFi chip so they can sell AX411... but it's now using the new NetAdapterCx (Network Adapter WDF Class Extension) with my modified driver on AX211!, Which they only did it for AX411 while they kept AX211 with an old ndis.sys one deliberately.
It's simply a driver limitation Intel put it on but HW supports it bec. AX210/AX211=AX411 literally. It also have DCT [Double Connect Tech.] Intel only did it for AX411 while leaving AX210/AX211 without DCT feature although I would need find a way to test it if DCT actually works with AX210/AX211 since I have the option to enable it on the driver settings through device manager.
Benefits & Features with NetAdapterCx driver support are...
https://techcommunity.microsoft.com...ver-model-for-the-next-generation/ba-p/339722
https://learn.microsoft.com/en-us/windows-hardware/drivers/netcx/wifi-wdf-class-extension-wificx
Here's some proof picture that I did it with success! + Technical detail about Intel dividing the features between AX210/AX211/AX411 through driver structure changes...
Using Windows 11 is a requirement to enjoy those benefits. Windows 10 doesn't support NetAdapterCx driver.
Once I get enough variants of Intel AX210/AX211/AX411 I will then create another thread and share the driver to the public as I will be supporting Intel AX210/AX211/AX411 as a whole
- Lower ndis.sys DPC routines
- Lower CPU utilization during high load networking
- Lower latency when compared between NetAdapterCx based drivers vs ndis.sys based drivers.
- DCT [Double Connect Tech.] which officially AX211 doesn't have it but supported in HW.
