The easy way to de-lid a processor!
newtekie1
Semi-Retired Folder
28,473 (3.97/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I went to pull the heatsink on this processor to see what it was. I knew it was a 478 Pentium 4, but I wasn't sure which one. It was in a Gateway with a blown motherboard(every cap had blown on the board:twitch:). I wasn't too concerned about killing the processor, just curious what it was before I tossed the machine in the dumpster.
Anyway, I pulled the heatsink and the CPU came with it. Normally I'd twist the heatsink first, but Gateway's lovely design left absolutely no room to twist the heatsink. So I expected the processor to come with the heatsinks.
However, what I didn't expect was that the processor would be cemented totally to the heatsink! I didn't have a heatgun to warm the processor up so I could pop it off the heatsink properly, so I just took a flathead screwdriver and started prying.
Suddenly it popped and I though I had it... Then I pulled the processor the rest of the way off and to my surprise the IHS had popped off!:roll:
I've never seen thermal compound that had a stronger bond than the epoxy Intel uses to seal the IHS on.:laugh:
Anyway, in the end I found out it was just a piece of shit 1.8GHz Northwood. So no loss if it is dead, but I think I'll make a keychain out of the IHS(I did eventually get it off after soaking it in goo gone). The keychain is probably worth more to me than the processor.:D
Cool... I've never seen that before.
wow, never seen that before, always had the cpu pop off before the ihs.
Dont try to pop the tops on any i3 i5 or i7's intel has soldered the die to the IHS
Wow man I have never seen that before because I don't know about this easiest way to de-lid a processor idea.
A lot of the 775 processors were this way also. I think they started using solder in the Pentium D days.
Kind of a misleading thread title :(
I was hoping for something really spectacular, but instead I get reminded about the shitty thermal glue manufactures use on our loved chips :laugh:
When I started prying on it with a screwdriver, the love was pretty much gone.:roll:
now that we're at it :D
old sempron lol
Should have made the title says,"Easy way to make a Mobile P4 from a Desktop P4":laugh: At least when this happens you don't get bent pins...AMD:shadedshu
