The power plug get too hot
177 (0.38/day)
Processor 5900x
Motherboard MSI 570s
Cooling AIO 240
Memory 32 GB G.Skill @ 3200MHz
Video Card(s) 6800 xt
Storage Many
Display(s) Two QHD
Power Supply SilverStone Hela 1200W
Hi
I changed my PSU from several months to Silver Ston 1200W but recently I noticed that the power plug get worm until few days ago when I spent more time on games I found out that plug become too hot to touch but fortunately the plastic plug did not melt . I have card RX 6800 XT is there a way to prevent this heat for safety or this is normal ?
Thanks
371 (1.68/day)
Mitten State, USA
System Name Sim Racing PC/Dell XPS 15 7590
Processor AMD Ryzen 7 5800x/Intel Core i7-9750h
Motherboard ASUS TUF B450-Plus II/Dell Laptop MB
Cooling Arctic Freezer A35 CO/laptop cooling
Memory 2*8 GB G.Skill Ripjaws V DDR4-3200/2*8 GB Crucial DDR4-2666 SO-DIMM
Video Card(s) XFX SWFT309 RX 6700 XT/Laptop GTX 1650
Storage 1 TB Crucial 3400 PCIe Gen 4 SSD/Ediloca EN605 512 GB PCIe Gen 3 SSD
Display(s) 77" LG OLED TV (4K@120Hz)/15" Dell integrated panel (1080p@60Hz) and 30" Dell U3011 (1600p@60 Hz)
Case Cougar MX330-G Air / XPS 15 7590 chassis
Audio Device(s) Beyerdynamic DT 770 Pro via Yamaha HT receiver/Integrated speakers or Creative Pebble Plus
Power Supply EVGA 600 BA / Dell 130W laptop brick
Mouse Logitech K400+ / Cherry MW 4500
Keyboard Logitech K400+ / Dell L100 or integrated keyboard
VR HMD Meta Quest 2
Software Windows 11 Home/Ubuntu 24.04.1
On what end is the plug getting too hot: the PSU end or the outlet end?
177 (0.38/day)
Processor 5900x
Cooling AIO 240
Storage Many
Display(s) Two QHD
I am using electricity subscriber (is that the right name ?) what it get too hot is the plug in this subscriber. I use it to power up my PC + Two monitors + speakers. With my old PSU 750w this problem never occurred
freeagent
9,992 (4.22/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Aqua Elite 360 V3, 6x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 30-36-36-68 1.35v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
That looks a little inadequate.
Looks like 3 lamps would get it warm..
177 (0.38/day)
Processor 5900x
Cooling AIO 240
Storage Many
Display(s) Two QHD
I dont understand . the picture is for demonstration only. Mine has no lamps and with 5 outlets
freeagent
9,992 (4.22/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Oh ok, so you showed a picture of something you don't have.
Pretty helpful..
You will probably have to get a beefier power strip if its getting hot.
818 (0.12/day)
GA, USA
System Name Gamer
Cooling Apogee XL, MCR360, MCP655, Micro-rez
Video Card(s) Red Dragon RX 6800 XT
Case Rocketfish (Lian Li) e-ATX
Audio Device(s) Harman Kardon HK695 2.1
Power Supply Seasonic Focus GM-750
Mouse HP Gaming wired
Keyboard Logitech G110 wired
VR HMD HP WMR 1440^2
Software Win10 Pro 64bit
In the US we call that a power strip with an extension cord. Some of them can be extremely low quality and have under-sized wire in the cord.
Make sure all the connections are tightly fitted. A loose connection can cause heating. If everything seems tight and it still gets hot, replace it with one that has a more heavy duty cord as freeagent suggests.
4,872 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
either end is bad when it's too hot to touch, i would replace the power cable and see if that helps
freeagent
9,992 (4.22/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I am just picturing the super thin gauge brass or copper in that strip carrying that power..
4,872 (0.97/day)
your PSU powered your monitor and speakers, are you talking about a UPS
this as well
freeagent
9,992 (4.22/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Interesting, the strip doesn't get warm with the 750, but the new one it does.
That is a good question, and trust me, Its been rattling around my skull since you posted.
177 (0.38/day)
Processor 5900x
Cooling AIO 240
Storage Many
Display(s) Two QHD
Never saw beefier power strip. It all come with same thickness as a standard . The thickness exactly like the picture I posted
No
2,189 (0.66/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
Hi
Thanks
Isolate the issue.
Plug PSU cord directly into wall socket and see if it still gets very warm. If it does we can start examining what is wrong with it and whether you should warranty it. One easy way to do this is trying your PC in a different outlet and seeing if the cord still gets very warm.
Second test would be to unplug everything but one monitor and PSU from the power strip and see if it gets very warm. Unlike some I realize the standards that are legally upheld in products using that plug type are high, compared to say the free and wild US.
543 (0.99/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
A 1200W power supply won't draw more power than a 750W with the same load unless it's less efficient. Just making a point (that some people are not aware of) that increased capacity does not mean it always uses more power.
That said, the heat there is from high resistance causing a voltage drop at that point. Voltage*current=power and thus heat. So if we assume your power supply is functioning correctly (because you haven't reported any issues with the system), there is likely an issue with the cable itself, or the power strip. You can say "a power strip is a power strip they're all the same", but if it has a defect, it's not the same as others. The high resistance I mentioned is usually from poor contact due to corroded metal, or a bad crimp. If you think about stranded wire for example, let's say there are normally 40 strands of copper that get crimped into a terminal to carry all the load. If there was a mistake somewhere and only 7 strands are now carrying that load, it will still function and seem completely normal until the current increases. Then it will get really hot and potentially even melt/fuse open. That's just one common defect in electrical assemblies. I don't have enough information to say this is definitely the problem you have, but it's possible and is one example of an issue that could cause the heat you're experiencing.
2,189 (0.66/day)
Storage 1TB 980 Pro
Software W11 Pro
In any case you want to put the least amount of strain on PC possible to figure out the problem.
13,740 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
^^^This^^^ Start here. Assuming the cable that gets hot is detachable from its power supply, try a different cable. And, as a test, plug it directly into the wall outlet and not your power strip. If the second cable gets hot when plugged into the wall, that's a big problem.
Heat like this indicates "excessive" current - not good.
Does the power strip's plug where it plugs into the wall get hot too?
As nomdeplume points out, you need to isolate the problem to determine if the power cord plug is getting hot because the power supply is demanding too much power, or if the original power cable is inadequate or damaged and thus getting hot, or if your power strip/extension cord is getting hot, making the power cable hot.
Is the PSU the only change? If nothing else changed in the computer, the power demand from the computer, and thus from the wall will be the same. That is, if the computer (motherboard, graphics, CPU, drives, RAM, etc.) demand 350W, the PSU will deliver 350W, regardless if the PSU is a 500W PSU, or 750W or 1200W. And the demand from the wall will be 350W too, regardless the PSU capacity, plus a little extra due to PSU inefficiency. And I would expect the Silver Stone to very similar efficiencies (if not better) than your Corsair RM750.
For the record, a power cable that gets slightly warm after an extended period of heavy use is acceptable. But it should never get "hot" and especially not "too hot to touch". That could lead to potential fire and worse. :(
I suspect your power strip current capability is inadequate but you need to verify for sure.
244 (0.21/day)
Unless you've got X-ray vision, you cannot be certain the internal construction of the metal contacts is excellent, good, merely adequate, poor, or downright dangerous. They're supposed to meet safety standards, but not all of them are fully compliant.
An ATX PSU mains lead plug may seem a tight fit in the extension socket, but contacts inside may still be sloppy. This possible if the earth pin is a tight fit, but the line or neutral pins are loose, causing high resistance, potential arcing and overheating.
Cheap power strips are often poorly constructed inside, despite being marked CE, UL, UKPA (pick your nation's electrical safety standard marking).
The only time I've had a "hot" mains plug is when running a 3kW fan heater (plugged directly into the wall) for many hours. The 13A fuse fitted in UK plugs gets decidedly warm when run at its nominal rated current. It's not unknown for white 13A plugs to turn brown over the fuse, especially when run at over 2kW for hundreds of hours. For desk lamps, I fit 2A or 3A fuses in the 13A plug. For ATX PSU's, I fit a 7A or 10A fuse.
The fewer power strips, adapters, etc., you have between the ATX PSU and the wall outlet, the better. Each additional series connection is a potential source of trouble.
177 (0.38/day)
Processor 5900x
Cooling AIO 240
Storage Many
Display(s) Two QHD
I buy only known brands of power strips but is there another way to make sure it is high quality or not ?
3,913 (2.57/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
For some more testing, plug another large consumer of electricity into the same power strip, same socket. Perhaps a hair dryer or a space heater that draws around 1200-1500 watts - a bit above the maximum for your PSU. You'll know without guessing what the actual power is because it's specified on the label on the heater. A good power strip may become warm after a few minutes, but no part of it should get too hot to touch. A bad one may become too hot to touch in a few seconds so be careful. If it's bad, it's bad, there's no repairing.
560 (2.79/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
+1 for immediate diagnosis/replacement of all power cables/power strips involved. That is a potentially very dangerous situation. I'd use it as little as possible (or not at all) until you have it figured out conclusively.
13,740 (2.02/day)
Nebraska, USA
Mouse Logitech M190
Not really. Even if you felt comfortable opening it up, if you knew what you were looking for, you could inspect the wiring for proper size and the soldering joints to make sure they were good. But odds are, other than researching part numbers for specs (assuming they are there and readable), it is unlikely you could tell their quality.
Going with brand name devices and buying from reputable retailers helps, but sadly, even reputable retailers have been known to sell counterfeit parts unknowingly (and sometimes knowingly :()
IMO, the suggestions given above (different power cable, directly into wall outlet, different supply, different strip) to see if the connect still heats up is you best bet right now.
3,033 (2.03/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
why would you touch power connectors?
do they melt?, smell like burnt plastic or smoke? No? why does it bother you.
just because a human feels pain at 50-60°C does not mean plastic or hardware does.
