[Case Gallery] The Taz Machine
1,977 (0.30/day)
Fremont, Ohio
System Name The Darkside
Processor Ryzen 5 3600
Motherboard ASRock B550 Extreme4
Cooling OEM
Memory 16gb G.Skill Fortis
Video Card(s) MSI Seahawk 1070
Storage 500gb Mushkin Pilot NVMe
Display(s) 55" Samsung 4k UHD
Case Corsair iCue 465X RGB
Audio Device(s) Onboard Reltek
Power Supply Corsair AX860i
Specs:
AMD 5000+ Black Edition O/C'ed to 2.8Ghz
3 GB of mixed DDR2 at 667Mhz (temp. RAM)
BFG 8600GTS
Maxtor 160GB
Antec Basiq 350W
Cheap DVD burner
Mods:
I started with just cutting out all the fan grills and later lead to me cutting the side panel out for a acrylic window. I then cut a hole out for VGA cooling on the window and put a temporary 80mm fan then in future upgrade and cut a 120mm fan hole. I bondoed 3 of the 5 5.25" bays, from the outside of course :p, and cut another window up front in the face plate and put in a smoked out piece of acrylic with the name "TAZ" cut out to display it lit up when I get a 120mm fan put in. I painted it black, not the best job, its my first time in the painting field lol. Plus I remounted the power switch and power/HDD LEDs
The beige DVD drive is gone now with a black one, Its kinda hard to make out the "TAZ" in front
2,964 (0.45/day)
your local vending machine
System Name HTPC||Lenovo IBM ThinkPad
Processor AMD Phenom II x4 965 stock 3.4GHz||Intel C2D T9300 @ 2.5GHz
Motherboard Zotac 890GX-ITX WiFi||Lenovo 8918CTO
Cooling Stock 3x 120's||Stock stuff
Memory 8GB (2x4GB) DDR3 6-6-6-15||3GB DDR2
Video Card(s) Asus 3870x2||nVidia Quadro NVS 140M
Storage 1TB Seagate Barracuda, 1x 2TB WD EARX ||Hitachi 160GB 7200RPM
Display(s) Samsung T260HD||
Case SilverStone Grandia GD05||
Audio Device(s) on-board||on-board
Power Supply Cooler Master 450W||6-cell
Software Windows 7 Pro x64||Windows 7 Pro x64/Linux Mint x64
Nice window insertion mate! Very clean.
You have very nice cable management there.
Although, I can't see "TAZ" anywhere :( I'm pretty sure that looks pretty cool
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
Thank ya! Yea its kinda hard to see without light coming through it. Its on the bottom of the face plate.
2,964 (0.45/day)
http://www.techpowerup.com/gallery/2337/5.jpg
Pretty bawls mate! Again, nice handy work ;)
Duke_GuRu
70 (0.01/day)
Originally Egyptian now I work in Riyadh, Kingdom
System Name Duke the F1rst
Processor AMD PhenomII X4 940BE @ 3.5GHZ
Motherboard ASUS M3A78-T Mobo
Cooling Modded ThermalTake Bigwater 770 + 745 kits
Memory 2x2GB OCZ Fatal1ty DDR2 Dual-Channel Kit
Video Card(s) Sapphire HD4890 1GB
Storage 1x160GB + 1x500GB + 1xTB + 1x500GB External
Display(s) 22" Widescreen BenQ Full-HD + 32" SAMSUNG LCD
Case Self-Modded GIGABYTE Aurora Full-ATX Case
Power Supply ThermalTake Toughpower 700W
Software Vista Ultimate 64-bit
Nice work you done there Bro, but I can see that this paint is a fingerprint magnet, i'm sure it's a pain in the A**.
about bringing out the TAZ you can use a Matt black paint or a lighter color around the edges, it will show.
1,977 (0.30/day)
Fremont, Ohio
Cooling OEM
Yea it took a little bit of trial and error to get the TAZ to stand out lol. And thanks for the tip on the paint. Yea the clear coat is a fingerprint magnet I forgot to clean it up b4 I took some pics
