System Name | Ghetto Rigs z490|x99|Acer 17 Nitro 7840hs/ 5600c40-2x16/ 4060/ 1tb acer stock m.2/ 4tb sn850x |
Processor | 10900k w/Optimus Foundation | 5930k w/Black Noctua D15 |
Motherboard | z490 Maximus XII Apex | x99 Sabertooth |
Cooling | oCool D5 res-combo/280 GTX/ Optimus Foundation/ gpu water block | Blk D15 |
Memory | Trident-Z Royal 4000c16 2x16gb | Trident-Z 3200c14 4x8gb |
Video Card(s) | Titan Xp-water | evga 980ti gaming-w/ air |
Storage | 970evo+500gb & sn850x 4tb | 860 pro 256gb | Acer m.2 1tb/ sn850x 4tb| Many2.5" sata's ssd 3.5hdd's |
Display(s) | 1-AOC G2460PG 24"G-Sync 144Hz/ 2nd 1-ASUS VG248QE 24"/ 3rd LG 43" series |
Case | D450 | Cherry Entertainment center on Test bench |
Audio Device(s) | Built in Realtek x2 with 2-Insignia 2.0 sound bars & 1-LG sound bar |
Power Supply | EVGA 1000P2 with APC AX1500 | 850P2 with CyberPower-GX1325U |
Mouse | Redragon 901 Perdition x3 |
Keyboard | G710+x3 |
Software | Win-7 pro x3 and win-10 & 11pro x3 |
Benchmark Scores | Are in the benchmark section |
System Name | PLAHI |
Processor | I5-10400 |
Motherboard | MSI MPG Z490 GAMING PLUS |
Cooling | 120 AIO |
Memory | 32GB Corsair LPX 2400 Mhz DDR4 CL14 |
Video Card(s) | PNY QUADRO RTX A2000 |
Storage | Intel 670P 512GB |
Display(s) | Philips 288E2A 28" 4K + 22" LG 1080p |
Case | SilverStone Raven RV03 |
Audio Device(s) | Creative Sound Blaster Z OEM |
Power Supply | Fractal Design IntegraM 650W |
Mouse | Logitech Triathlon |
Keyboard | REDRAGON MITRA |
Software | Windows 11 Home x 64 |
Thanks for sharing your experience. I think blue ones look like they are 1.5mm but hard to tell what yellow and grey ones are. My guess would be 1mm!It looks at least 1,5mm to me. From my humble experience 0.5 is very thin and I haven't seen it used in GPU or laptop a lot. I would say get something thicker, it's easier to squash it, than having a microgap due to a very thin pad.
I would keep your suggestion in mind! Thanks!Hi,
Get a verity pack or large sheets for future projects
Most common are 0.5 & 1.0 & 1.5mm
Can I stack 0.5mm pads on each other and use them since I didn't buy 1mm ones? Will it work? Thanks!It looks at least 1,5mm to me. From my humble experience 0.5 is very thin and I haven't seen it used in GPU or laptop a lot. I would say get something thicker, it's easier to squash it, than having a microgap due to a very thin pad.
System Name | micropage7 |
Processor | Intel Xeon X3470 |
Motherboard | Gigabyte Technology Co. Ltd. P55A-UD3R (Socket 1156) |
Cooling | Enermax ETS-T40F |
Memory | Samsung 8.00GB Dual-Channel DDR3 |
Video Card(s) | NVIDIA Quadro FX 1800 |
Storage | V-GEN03AS18EU120GB, Seagate 2 x 1TB and Seagate 4TB |
Display(s) | Samsung 21 inch LCD Wide Screen |
Case | Icute Super 18 |
Audio Device(s) | Auzentech X-Fi Forte |
Power Supply | Silverstone 600 Watt |
Mouse | Logitech G502 |
Keyboard | Sades Excalibur + Taihao keycaps |
Software | Win 7 64-bit |
Benchmark Scores | Classified |
System Name | Barb's Domain |
Processor | i9 10850k 5.1GHz all cores |
Motherboard | MSI MPG Z490 GAMING EDGE WIFI |
Cooling | Deep Cool Assassin III |
Memory | 2*16gig Corsair LPX DDR4 3200 |
Video Card(s) | RTX 4080 FE |
Storage | 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD |
Display(s) | Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV |
Case | SilverStone Fortress FT04 |
Audio Device(s) | Bose Companion II speakers, Corsair - HS70 PRO headphones |
Power Supply | Corsair RM850x (2021) |
Keyboard | Logitech Orion Spectrum G910 |
VR HMD | Oculus Quest 2 |
Software | Windows 10 Pro 64 bit |
Benchmark Scores | https://www.3dmark.com/spy/34962882 |
some people think that when you tighten the heatsink, it will squeeze the thermal pad and it's fine. in some cases you gonna find bent pcb coz of itI would highly suggest making sure you use the right thickness pads. Do your research, make sure. You may think .5 mm isn’t enough to hurt anything, but just recently, I sold a rtx2070 fe. The person that bought it replaced the pads. He used 1.5 mm. 1 mm pads are what was suppose to be used. That .5 mm was enough to keep the heat sink from making contact with the GPU, causing almost instant overheating and crash.
I bought 0.5mm and 1.5mm of these ones: https://www.amazon.com/SOLUTIONS-GP...lid+Solutions+GP-Ultimate,aps,480&sr=8-4&th=1you can stack them and yeah just buy 0.5 or 1 mm incase you need something since most use that
Agreed! That's why I'm really confused as to which is the correct thickness for these stock thermal pads! I don't want to mess it up! I need to be really sure!I would highly suggest making sure you use the right thickness pads. Do your research, make sure. You may think .5 mm isn’t enough to hurt anything, but just recently, I sold a rtx2070 fe. The person that bought it replaced the pads. He used 1.5 mm. 1 mm pads are what was suppose to be used. That .5 mm was enough to keep the heat sink from making contact with the GPU, causing almost instant overheating and crash.
Processor | Intel i7 13900K |
Motherboard | Asus ROG Strix Z690-E Gaming |
Cooling | Arctic Freezer II 360 |
Memory | 32 Gb Kingston Fury Renegade 6400 C32 |
Video Card(s) | PNY RTX 4080 XLR8 OC |
Storage | 1 TB Samsung 970 EVO + 1 TB Samsung 970 EVO Plus + 2 TB Samsung 870 |
Display(s) | Asus TUF Gaming VG27AQL1A + Samsung C24RG50 |
Case | Corsair 5000D Airflow |
Power Supply | EVGA G6 850W |
Mouse | Razer Basilisk |
Keyboard | Razer Huntsman Elite |
Benchmark Scores | 3dMark TimeSpy - 26698 Cinebench R23 2258/40751 |
absolutely agree. Even 0.5 mm difference could be an issue.I would highly suggest making sure you use the right thickness pads. Do your research, make sure. You may think .5 mm isn’t enough to hurt anything, but just recently, I sold a rtx2070 fe. The person that bought it replaced the pads. He used 1.5 mm. 1 mm pads are what was suppose to be used. That .5 mm was enough to keep the heat sink from making contact with the GPU, causing almost instant overheating and crash.
I have no direct experience in that, but I'm not sure that stacking 2 x 0.5 mm would have the same thermal conduction of 1 piece 1 mm.you can stack them and yeah just buy 0.5 or 1 mm incase you need something since most use that
Thanks I bought all three thickness pads -> 0.5mm, 1.0mm & 1.5mm and a vernier caliper to measure stock pads thickness to be on the safe side!absolutely agree. Even 0.5 mm difference could be an issue.
Hey XT785! I know this is a super old thread but I also happen to have this same computer and had the same question about the thickness of each pad. Do you remember which pads you ended up using?Thanks I bought all three thickness pads -> 0.5mm, 1.0mm & 1.5mm and a vernier caliper to measure stock pads thickness to be on the safe side!![]()
