Thermal paste comparison question.
162 (0.14/day)
System Name Mypc
Processor AMD Ryzen 5 5600x
Motherboard MSI MAG B550M BAZOOKA
Cooling Coolermaster Hyper 212 Rgb
Memory Corsair 3600 mhz Cl16 ddr4 8x2
Video Card(s) Asus RX 6750 XT Rog Strix OC Edition
Storage Samsung 990 PRO 1TB + Samsung 980 Evo 50gb
Case Coolermaster TD500 Mesh White
Power Supply Corsair CX-650F RGB
Hey guys, i am going to reapply thermal paste on both my gpu and cpu.
Friend has coolermaster pro thermal paste in hand which has thermal conductivity of 9w/m-k.
I am thinking of purchasing the cooler master maker nano, which has a thermal conductivity of 11w/m-k and is made of diamond particles or something which i have heard is good, but i would need to spend 75 dollars on it.
Should i go buy the better one or will the former do just fine when slightly overclocking my gpu/cpu ?
How much of a difference would the better one make, in terms of temperatures ?
9,915 (1.83/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
temp not only affected by thermal paste, the contact area, the pressure, the heatsink, the airflow affect more than paste
if you wanna use the better paste it's ok but improving the airflow will give you better result than the thermal paste itself
7,423 (4.96/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
$75 on MasterGel Maker isn't worth it, I take it you'd be importing it? It's much, much cheaper than that. But Pro is going to handle your machine fine, even the Regular will, if you intend to use it on the 5600X you have on your specs. Alternatives would me Arctic MX-4, Noctua NT-H1, deepcool Z9, Gelid GC-Extreme (this one tends to be pricier, but it's what I use, it's fantastic for high-end CPUs), or Thermal Grizzly Aeronaut, do some scouting on the prices for these, any you'd get will be fine.
355 (0.38/day)
System Name EA-ZEN
Processor AMD Ryzen 7 5800X3D with -50mW UV
Motherboard Asus X570
Cooling Big Air
Memory 2x16 GB DDR4 3600 CL16
Video Card(s) Asus RTX 2080 Ti Strix highly OC’ed
Storage 1 TB NVME, 500 GB SSD etc
Display(s) 2x 27”, main: curved 144Hz SVA with BLS and HDR
Case Full Tower
Audio Device(s) Z906 5.1 and Audeze Headphones, Shure SM7B mic
Power Supply Enough
Mouse Old but gold
Keyboard Mechanical Cherry Brown
Benchmark Scores A lot
Not long ago I read a review about thermal paste, very extensive one with all included, i learned my ancient MX 2 is only 1.5° C worse than the best thermal paste, so I didn’t bother ordering something else. Thermal paste is overrated, the only thing that makes big difference is liquid metal instead of regular paste. Keep this in mind.
2,260 (1.23/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
213 (0.20/day)
Processor Ryzen 5 5600X
Motherboard Asus B550-F Gaming WiFi
Cooling Be Quiet! Dark Rock Pro 4
Memory 64GB G.Skill Ripjaws V 3600 CL18
Video Card(s) Gigabyte RX 6600 Eagle (de-shrouded)
Storage Samsung 970 Evo 1TB M.2
Display(s) 2 x Asus 1080p 60Hz IPS
Case Antec P101 Silent
Audio Device(s) Ifi Zen DAC V2
Power Supply Be Quiet! Straight Power 11 650W Platinum
Mouse JSCO JNL-101k
Keyboard Akko 3108 V2 (Akko Pink linears)
Having done a lot of my own thermal paste testing in the past, I can tell you right away that thermal conductivity is a very unreliable indication of actual performance. Look at any bar chart of a thermal paste performance test and you'll find that it doesn't correlate at all with their respective thermal conductivity values.
Great example right here (look at the thermal conductivity values in relation to ranking):
This may help you find something
28,808 (6.82/day)
That's great stuff, go with it.
No, the difference is NOT worth $75. Go with the stuff you already have on hand and enjoy!
162 (0.14/day)
System Name Mypc
Thanks for the replies guys, went with my friend's paste. Completely cleaned my pc and reapplied thermal paste. Temps are much better now, about 10 degrees cooler in fact. Idle is around 35degrees celsius and load is around 60 on cpu. Gpu doesnt exceed 70 degrees celsius.
