Thermal paste instead of thermal putty/pads
163 (0.46/day)
System Name Mid-Range
Processor Ryzen 5 5600x
Motherboard ASUS TUF Gaming B550 Plus WiFi II
Cooling AiO LS 520 White edition(MX-6 thermal paste applied)
Memory 2x16GB DDR4 3600Mhz CL18 Corsair Vengeance RGB PRO SL
Video Card(s) RX 7700 XT Asrock Steel Legend 12GB
Storage TeamGroup Cardea A440 1TB 4gen Nvme /512GB WD black SN810 nvme / SSD Verbatim Vi 550 S3 512GB
Display(s) MSI G272QPF 27 inch 2560x1440p
Case NZXT H6 Flow ARGB + 2x140mm Lian Li Uni infinity mirror
Audio Device(s) RGB Kogaion Speakers
Power Supply EVGA Supernova G2 650Watts 80 plus Gold
Mouse Redragon RGB
Keyboard Koagion RGB
VR HMD no
Software Windows 10 64bit 22H2
Benchmark Scores 25093 Superposition Benchmark 1080p medium
So guys ,long story short I was repasting my laptop thermal paste on my ASUS TUF A15 FA507NVR and I didn't knew the mofsets and chokes and vrms use thermal putty(it came factory with putty not with pads) and I applied MX-6 thermal paste instead.Temperatures for gpu and cpu dropped down but I can't track VRM temps neither mofsets temps.There are no artifacting,shutdowns or smh like that but....Am I cooked ?
1,779 (3.97/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
What monitoring software?? Try HWInfo64 sensors only and see if you have a VR temp reading.
As a side note, most VRMs are safe past 100c. But laptops may have that setting lower to throttle earlier such as 80c.
163 (0.46/day)
Mouse Redragon RGB
VR HMD no
Hwinfo doesn't show any vrm on laptops I think.I tried and there are none.
837 (0.14/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
I don't think paste is a safe solution. If it were, the manufacturer who put paste on the core wouldn't waste money on obtaining the putty as an additional supply chain item to add to the bill of materials, and would have instead used paste on the VRM as well.
163 (0.46/day)
Mouse Redragon RGB
VR HMD no
I ordered upsiren u6 pro(10g) for the vrams and mofsets , hope it works.I was thinking between this one and ThermalGrizzly Putty Advanced (30g) ,but since I didn't found any info about the M/kw for TG i went with upsiren u6
The interesting thing is that the factory substance wasn't exactly like a putty but it was more like sillicone liquid.I removed heatsink without the laptop to been ON for 10+ hours at a 20C degree room temperature and it was liquid and sillicone like substance with white-blue-cyan blue color.I am thinking to put now Upsiren U6 Pro but its too thick , am I in the right way ?
837 (0.14/day)
Pacific Coast
Mouse EVGA TORQ X10
I don't know your laptop. I assumed it was putty because that's what you said. If it did have paste, then I would use paste.
965 (0.52/day)
Turkey
System Name MSI-MEG
Processor AMD Ryzen 9 3900X
Motherboard MSI MEG X570S ACE MAX
Cooling AMD Wraith Prism + Thermal Grizzly
Memory 32 GB
Video Card(s) MSI Suprim X RTX 3080
Storage 500 GB MSI Spatium nvme + 500 GB WD nvme + 2 TB Seagate HDD + 2 TB Seagate HDD
Display(s) 27" LG 144HZ 2K ULTRAGEAR
Case MSI MPG Velox Airflow 100P
Audio Device(s) Altec Lansing
Power Supply Seasonic 750W 80+ Gold
Mouse HP OMEN REACTOR
Keyboard Corsair K68
Software Windows10 LTSC 64 bit
It's cheaper
163 (0.46/day)
Mouse Redragon RGB
VR HMD no
No , I putted paste there where it should have been putty or grease or smh .Actually the factory substance wasn't thermal paste or putty but some white-blue sillicone like liquid.I can't identify what it was - it's on the picture I uploaded on the post.You can see the picture VRAMs and chokes and mofsets - this is how it came from factory and I don't know what it is but I removed it and replaced with thermal paste (MX-6). I wonder if I should put thermal putty there and if its safe because many people claim thermal paste is def not for vrams and chokes and mofsets :(
6 (0.00/day)
Thermal paste (MX-6) is definitely NOT for chokes and mosfets - too thin, won't fill gaps properly and will leach out REALLY fast. Replace with your Upsiren (great stuff in my experience). The stuff on your chokes / mosfets and the like is essentially the same as Upsiren - fills gaps and transfers heat - just a different brand / color / texture but same stuff where it matters.
163 (0.46/day)
Mouse Redragon RGB
VR HMD no
This was really really liquid like , nothing like Upsiren substance but yeah , some kind of jelly pads probabbly
MxPhenom 216
ASIC Engineer
13,062 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
Why do we have 2 threads created for the essentially the same topic?
the54thvoid
Super Intoxicated Moderator
13,262 (2.40/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
I've locked the other one.
