- Oct 9, 2007
- 47,063 (7.59/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Thermaltake, the leading PC DIY premium brand for Case, Cooling, Gaming peripherals and enthusiast memory solutions, is delighted to present new members to the all-in-one liquid cooler family with two products: Floe RC Ultra 240/360 CPU & Memory AIO Liquid Cooler and TOUGHLIQUID Ultra 240/360 CPU AIO Liquid Cooler.
New to the Thermaltake AIO series, these two AIO Liquid Coolers have three main features in common: Firstly they both come with high-performance TOUGHFAN 12 Turbo radiator fans that are tuned to an impressive maximum speed of 2,500RPM, guaranteeing the strong airflow for an enhanced cooling result whether you are working or gaming. Secondly, they incorporate a bright 2.1" LCD display on the CPU water block (and another individual 3.9" LCD display for Floe RC Ultra memory water block), bringing great visual aesthetics, and giving users full customization options to create more personalized visual effects that include uploading fun GIFs or any pictures in jpg format you like. Last but not least, they are supported by the latest Thermaltake TT RGB PLUS 2.0 Software, allowing users to monitor real-time PC information such as CPU, GPU, and offering more customized lighting effects to reach the higher visual customization.
Thermaltake Floe RC Ultra 240/360 CPU & Memory AIO Liquid Cooler Features:
Exclusive & Comprehensive All-In-One Design
Floe RC Ultra is an advanced high-quality all-in-one cooling solution for cooling down your CPU and memory simultaneously. The cooler includes high static pressure fans and 2 fully customizable LCD water block displays to monitor your PC performance anytime, allowing you to minimize overheating problems. Compatible with TOUGHRAM RC memory modules, the Floe RC Ultra provides a simple and intuitive way that grants users unparalleled cooling performance.
Exceptional Cooling Performance
Optimized for CPU and RAM cooling, the flow design runs through the CPU water block, radiator and then memory water block to achieve maximum cooling efficiency and thermal dissipation.
Fully Customized with TT RGB Plus 2.0
Monitor frequency and real-time temperature directly from large LCD displays, and upload any images or GIFs to add extra flair with the TT RGB Plus 2.0 software.
Powerful 120 mm PWM Radiator Fans
Equipped with the TOUGHFAN Turbo Series which come at a maximum operating speed of 2500 RPM, the Floe RC Ultra provides enhanced airflow for superb cooling performance.
Paired with TOUGHRAM RC
The Floe RC Ultra requires TOUGHRAM RC memory modules to pair with, the ICs are thoroughly-screened for optimal frequency and response times. On top of that, you can also monitor real-time temperature, frequency and performance.
Thermaltake TOUGHLIQUID Ultra 240/360 CPU AIO Liquid Cooler Features:
2.1 Inch Rotational LCD Display
A 2.1 Inch Rotational LCS Display that presents real-time information and even play JPG and GIF files with 480*480 resolution, bringing great visual aesthetics and highly customizable functions to your All-in-One cooler.
Caution: The cap can only rotate from 0 to 270 degrees.
TOUGHFAN 12 Turbo Equipped
Equipped with two TOUGHFAN 12 Turbo fans for the TOUGHLIQUID Ultra 240 and three TOUGHFAN 12 Turbo fans for the TOUGHLIQUID Ultra 360, the TOUGHLIQUID Ultra boosts the fan speed up to 2500 RPM, ensuring the best cooling results whether you're working or gaming.
High-Performance Cold Plate
The high-performance copper base plate accelerates heat conductivity. The high-quality and reliable pump enables maximum water circulation, keeping the copper plate continuously cool. The low evaporation tube effectively decreases the loss of coolant; therefore, no refill is required.
Monitor frequency and real-time temperature directly from our 2.1-inch LCD Display, and upload any image or GIF file to add extra flair with the TT RGB Plus 2.0 software.
Caution: The TOUGHLIQUID Ultra Series is only supported by the TT RGB Plus 2.0.
